<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Earth globe]]></title><description><![CDATA[<p dir="auto">hi! would anybody be interrsted to devlop/help to have a globe showing on the mirror??? something like : <img src="/uploads/files/1478995272221-capture-d-e-cran-2016-11-13-a-01.00.54.png" alt="0_1478995270976_Capture d’écran 2016-11-13 à 01.00.54.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/983/earth-globe</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 19:14:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/983.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Nov 2016 00:01:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Earth globe on Wed, 16 Nov 2016 09:40:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexyak" aria-label="Profile: alexyak">@<bdi>alexyak</bdi></a> Very nice job! it’s exactly what I had in mind when I open this topic. Sad that can’t be run on RPI…</p>
]]></description><link>https://forum.magicmirror.builders/post/8032</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8032</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Wed, 16 Nov 2016 09:40:27 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Tue, 15 Nov 2016 23:47:44 GMT]]></title><description><![CDATA[<p dir="auto">Here’s how the module based on WebGL looks like on my dev box:</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=1L9yofDD-Ic&amp;feature=youtu.be" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=1L9yofDD-Ic&amp;feature=youtu.be</a></p>
<p dir="auto">It displays twitter stream of the tweets that have location. Red lines signify the negative sentiment and green positive. White is neutral.</p>
]]></description><link>https://forum.magicmirror.builders/post/8012</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8012</guid><dc:creator><![CDATA[alexyak]]></dc:creator><pubDate>Tue, 15 Nov 2016 23:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Tue, 15 Nov 2016 15:29:53 GMT]]></title><description><![CDATA[<p dir="auto">Small correction about WebGL on RPI - the chromium/hardware will not even run. You will an error message that it’s not supported.</p>
]]></description><link>https://forum.magicmirror.builders/post/7981</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7981</guid><dc:creator><![CDATA[alexyak]]></dc:creator><pubDate>Tue, 15 Nov 2016 15:29:53 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Mon, 14 Nov 2016 21:43:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> Macbook Pro</p>
]]></description><link>https://forum.magicmirror.builders/post/7959</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7959</guid><dc:creator><![CDATA[alexyak]]></dc:creator><pubDate>Mon, 14 Nov 2016 21:43:19 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Mon, 14 Nov 2016 19:37:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexyak" aria-label="Profile: alexyak">@<bdi>alexyak</bdi></a> which is your dev box if i may ask?</p>
]]></description><link>https://forum.magicmirror.builders/post/7946</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7946</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Mon, 14 Nov 2016 19:37:49 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Mon, 14 Nov 2016 03:51:51 GMT]]></title><description><![CDATA[<p dir="auto">Yes I am also leaning heavy on creating a bigger mirror running on a much more powerful board.</p>
<p dir="auto">Can’t decide if I want to use a mini pc or itx board…</p>
]]></description><link>https://forum.magicmirror.builders/post/7910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7910</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 14 Nov 2016 03:51:51 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Mon, 14 Nov 2016 01:32:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> this code utilizes WebGL which brings RPI to its knees. You can run the MM on a different more powerful hardware, though. As for the module, I have got a POC working on my dev box with a sample data.</p>
]]></description><link>https://forum.magicmirror.builders/post/7905</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7905</guid><dc:creator><![CDATA[alexyak]]></dc:creator><pubDate>Mon, 14 Nov 2016 01:32:17 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 17:31:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukecodewalker" aria-label="Profile: LukeCodewalker">@<bdi>LukeCodewalker</bdi></a> wow! you made a <strong>great</strong> job here! thx alot for your time/work/involvment!</p>
]]></description><link>https://forum.magicmirror.builders/post/7895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7895</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 13 Nov 2016 17:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 17:07:37 GMT]]></title><description><![CDATA[<p dir="auto">So here it is =)<br />
<a href="https://forum.magicmirror.builders/topic/986/mmm-globe">https://forum.magicmirror.builders/topic/986/mmm-globe</a></p>
]]></description><link>https://forum.magicmirror.builders/post/7893</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7893</guid><dc:creator><![CDATA[LukeCodewalker]]></dc:creator><pubDate>Sun, 13 Nov 2016 17:07:37 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 16:33:11 GMT]]></title><description><![CDATA[<p dir="auto">small preview =)<br />
<img src="/uploads/files/1479054516392-screenshot-resized.png" alt="0_1479054514162_screenshot.png" class=" img-fluid img-markdown" /><br />
I’ll have to write a readme, then I’m done.<br />
If you want to use a custom picture you just have to put your link in the config file and the module automatically uses this image.</p>
]]></description><link>https://forum.magicmirror.builders/post/7890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7890</guid><dc:creator><![CDATA[LukeCodewalker]]></dc:creator><pubDate>Sun, 13 Nov 2016 16:33:11 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 15:10:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> I think you have to clone it to the modules folder. otherwise MagicMirror won’t find it. Just do it the normal way.</p>
]]></description><link>https://forum.magicmirror.builders/post/7886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7886</guid><dc:creator><![CDATA[LukeCodewalker]]></dc:creator><pubDate>Sun, 13 Nov 2016 15:10:01 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 14:58:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukecodewalker" aria-label="Profile: LukeCodewalker">@<bdi>LukeCodewalker</bdi></a> wow that’s great! i will test it tonight :) noob question : is it ok to git clone your files anywhere or it should be located in MM modules folder?</p>
]]></description><link>https://forum.magicmirror.builders/post/7884</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7884</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 13 Nov 2016 14:58:38 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 14:20:14 GMT]]></title><description><![CDATA[<p dir="auto">So I made a small test here:<br />
[card:LukeSkywalker92/MMM-Globe]</p>
<p dir="auto">so I could easily make the image update every x minutes and make configs for image-size and image-style just by changing the image-path.</p>
]]></description><link>https://forum.magicmirror.builders/post/7880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7880</guid><dc:creator><![CDATA[LukeCodewalker]]></dc:creator><pubDate>Sun, 13 Nov 2016 14:20:14 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 13:49:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gizzmo" aria-label="Profile: gizzmo">@<bdi>gizzmo</bdi></a> <a href="http://rammb.cira.colostate.edu/ramsdis/online/himawari-8.asp" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> is also very interesting. It’s from the Himawari-8 satellite and almost live. there you could have very easily four different styles and you don’t need an api-key. I think your suggestions would be very complex to implement. What do you think about these pictures?</p>
]]></description><link>https://forum.magicmirror.builders/post/7879</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7879</guid><dc:creator><![CDATA[LukeCodewalker]]></dc:creator><pubDate>Sun, 13 Nov 2016 13:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 12:47:52 GMT]]></title><description><![CDATA[<p dir="auto">I like the idea of having some sort of dynamic data representation of earth, but im not a big fan of the nasa data.<br />
I like this model beter … <a href="https://earth.nullschool.net/" target="_blank" rel="noopener noreferrer nofollow ugc">Link</a></p>
]]></description><link>https://forum.magicmirror.builders/post/7876</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7876</guid><dc:creator><![CDATA[gizzmo]]></dc:creator><pubDate>Sun, 13 Nov 2016 12:47:52 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 12:26:51 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukecodewalker" aria-label="Profile: LukeCodewalker">@<bdi>LukeCodewalker</bdi></a>,<br />
thx for your feedback and help, it’s much appriciated :) i agree with the static image and your idea with Nasa is interesting. what i had in mind when i open this post was regarding this <a href="https://www.chromeexperiments.com/globe" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>  what is your opinion about it?<br />
greetings</p>
]]></description><link>https://forum.magicmirror.builders/post/7874</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7874</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 13 Nov 2016 12:26:51 GMT</pubDate></item><item><title><![CDATA[Reply to Earth globe on Sun, 13 Nov 2016 11:47:35 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a>,<br />
that should be no problem. I think it would be interesting to use NASA’s EPIC (Earth Polychromatic Imaging Camera) API. There you would get two day old pictures of the globe. Here’s an example image:<br />
<img src="http://epic.gsfc.nasa.gov/epic-archive/natural/png/epic_1b_20161110203427_01.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">You can also view the images <a href="http://epic.gsfc.nasa.gov" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">So if you would like to do that I can help you.</p>
<p dir="auto">Displaying only an static image would not be very interesting for me.</p>
<p dir="auto">greets Luke</p>
]]></description><link>https://forum.magicmirror.builders/post/7871</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7871</guid><dc:creator><![CDATA[LukeCodewalker]]></dc:creator><pubDate>Sun, 13 Nov 2016 11:47:35 GMT</pubDate></item></channel></rss>
