<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Infrared Touch Frame - rotate?]]></title><description><![CDATA[<p dir="auto">Hi there! I have my MagicMirror up and running in portrait mode and works well. I have just added a 42" Infrared Touch Frame Overlay but the touch cursor moves the wrong direction (ie. the touch cursor stuck to landscape)<br />
How does one calibrate the touch cursor to portrait mode? I slide my finger up the mirror and the cursor moves right ~ lol.</p>
<p dir="auto">I have installed xinput but not sure how or where to adjust the settings.</p>
<p dir="auto">Any help appreciated!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9843/infrared-touch-frame-rotate</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 06:09:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9843.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Feb 2019 05:17:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Infrared Touch Frame - rotate? on Fri, 22 Feb 2019 04:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> That worked!  Nice :)<br />
In Terminal I entered: chmod +x <a href="http://portrait.sh" target="_blank" rel="noopener noreferrer nofollow ugc">portrait.sh</a><br />
Then executed the <a href="http://portrait.sh" target="_blank" rel="noopener noreferrer nofollow ugc">portrait.sh</a> file I made<br />
and the touch IR is now set to portrait.</p>
<p dir="auto">So happy, thanks for your help buddy!</p>
<p dir="auto">I’ve re-ran the “Calibrate Touchscreen” in Preferences again too. It reads:</p>
<p dir="auto">&lt; Calibrating standard Xorg driver “Multi touch   overlay device” current calibration values: min_x=0, max_x=65535 and min_y=0, max_y=65535<br />
If these values are estimating wrong, either supply it manually with the - -precalib option, or run the ‘get_precalib.sh’ script to automatically get it (through HAL).  &gt;</p>
<p dir="auto">I find the touch curser doesn’t reach the the edges of my monitor. Example I can’t simply click on the Raspberry Icon in the corner. The curser is diaginally 2 inches away?</p>
<p dir="auto">Where can I set or adjust this? Any thoughts?</p>
<p dir="auto">Fun!</p>
]]></description><link>https://forum.magicmirror.builders/post/52959</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52959</guid><dc:creator><![CDATA[peemoeller]]></dc:creator><pubDate>Fri, 22 Feb 2019 04:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Infrared Touch Frame - rotate? on Thu, 21 Feb 2019 19:35:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peemoeller" aria-label="Profile: peemoeller">@<bdi>peemoeller</bdi></a> he made apps(launcher) in the ubuntu graphical interface.  So he could switch orientations just from a menu.</p>
<p dir="auto">If u are doing just once, u won’t need that.</p>
<p dir="auto">But he may have left out a step.<br />
From the command shell, where your little script is located, do</p>
<pre><code>chmod +x portrait.sh
<p dir="auto">To make the script executable</p>
]]></description><link>https://forum.magicmirror.builders/post/52940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52940</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 21 Feb 2019 19:35:34 GMT</pubDate></item><item><title><![CDATA[Reply to Infrared Touch Frame - rotate? on Thu, 21 Feb 2019 19:29:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Awesome thanks!</p>
<p dir="auto">In his website link I created the <a href="http://portrait.sh" target="_blank" rel="noopener noreferrer nofollow ugc">portrait.sh</a> file but don’t wuite understand this 2nd part in his instructions:<br />
————————-<br />
“Afterwards, I also made launchers to automatically run each shell script when I tapped on them (this is possible in Xubuntu, Ubuntu MATE, and many other Ubuntu flavours). To do so, go to your panel, right-click, click on “add to panel” (or equivalent, for all these subsequent commands, too), create a custom application launcher. For portrait’s launcher, put in this command:</p>
<p dir="auto">sh /home/username/Scripts/portrait”<br />
—————————</p>
<p dir="auto">Are you able to elaborate?  I am somewhat new to this :)<br />
Appreciate the guidance!<br />
~ Eric.</p>
]]></description><link>https://forum.magicmirror.builders/post/52939</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52939</guid><dc:creator><![CDATA[peemoeller]]></dc:creator><pubDate>Thu, 21 Feb 2019 19:29:48 GMT</pubDate></item><item><title><![CDATA[Reply to Infrared Touch Frame - rotate? on Thu, 21 Feb 2019 18:09:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peemoeller" aria-label="Profile: peemoeller">@<bdi>peemoeller</bdi></a> see here<br />
<a href="https://askubuntu.com/questions/368317/rotate-touch-input-with-touchscreen-and-or-touchpad" target="_blank" rel="noopener noreferrer nofollow ugc">https://askubuntu.com/questions/368317/rotate-touch-input-with-touchscreen-and-or-touchpad</a></p>
]]></description><link>https://forum.magicmirror.builders/post/52938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52938</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 21 Feb 2019 18:09:21 GMT</pubDate></item><item><title><![CDATA[Reply to Infrared Touch Frame - rotate? on Thu, 21 Feb 2019 17:55:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> Hello, yes and just finished running the xinput touch calibrator program under preferences (it had me touch the 4 red crosses). No issues there but I don’t know how or where to change the touch programming to “portrait” mode. I slide my finger up the monitor and the curser moves left.<br />
Would you have any instructions?  Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/52934</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52934</guid><dc:creator><![CDATA[peemoeller]]></dc:creator><pubDate>Thu, 21 Feb 2019 17:55:40 GMT</pubDate></item><item><title><![CDATA[Reply to Infrared Touch Frame - rotate? on Thu, 21 Feb 2019 11:14:15 GMT]]></title><description><![CDATA[<p dir="auto">Did you install xinput_calibrator?<br />
<a href="https://github.com/tias/xinput_calibrator/" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/tias/xinput_calibrator/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/52910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52910</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Thu, 21 Feb 2019 11:14:15 GMT</pubDate></item></channel></rss>
