<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can you call a module multiple times with different parameters?]]></title><description><![CDATA[<p dir="auto">Maybe you can, but I am using mmm-pages.<br />
Is there anyway to do it or do you just copy and rename modules?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9849/can-you-call-a-module-multiple-times-with-different-parameters</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 05:10:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9849.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Feb 2019 17:43:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can you call a module multiple times with different parameters? on Wed, 20 Feb 2019 18:10:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Yeap works just the same.</p>
<p dir="auto">Starting to get to grips with things Pages just suspends and restarts scripts for each page they are allocated.<br />
So it just needs to be referenced once in pages.</p>
]]></description><link>https://forum.magicmirror.builders/post/52863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52863</guid><dc:creator><![CDATA[stuartiannaylor]]></dc:creator><pubDate>Wed, 20 Feb 2019 18:10:06 GMT</pubDate></item><item><title><![CDATA[Reply to Can you call a module multiple times with different parameters? on Wed, 20 Feb 2019 18:02:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stuartiannaylor" aria-label="Profile: stuartiannaylor">@<bdi>stuartiannaylor</bdi></a> sorry, I don’t use pages</p>
]]></description><link>https://forum.magicmirror.builders/post/52861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52861</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Feb 2019 18:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to Can you call a module multiple times with different parameters? on Wed, 20 Feb 2019 18:01:49 GMT]]></title><description><![CDATA[<p dir="auto">If I am using pages which is which.<br />
I will give it a go and see.</p>
]]></description><link>https://forum.magicmirror.builders/post/52860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52860</guid><dc:creator><![CDATA[stuartiannaylor]]></dc:creator><pubDate>Wed, 20 Feb 2019 18:01:49 GMT</pubDate></item><item><title><![CDATA[Reply to Can you call a module multiple times with different parameters? on Wed, 20 Feb 2019 18:00:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stuartiannaylor" aria-label="Profile: stuartiannaylor">@<bdi>stuartiannaylor</bdi></a> sure, just add another { module:…} block to the config… it will have a different ID than some other instance</p>
]]></description><link>https://forum.magicmirror.builders/post/52858</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52858</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Feb 2019 18:00:26 GMT</pubDate></item></channel></rss>
