<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Globe]]></title><description><![CDATA[<p dir="auto">Hey guys,<br />
here is a module for displaying live pictures of our planet on your mirror.<br />
The pictures are taken from the Himawari-8 satellite.<br />
It’s also possible to use custom pictures.</p>
<p dir="auto">[card:LukeSkywalker92/MMM-Globe]</p>
<p dir="auto">Preview:<br />
<img src="/uploads/files/1479056786695-screenshot-resized.png" alt="0_1479056785269_screenshot.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hope you’ll enjoy it =)</p>
]]></description><link>https://forum.magicmirror.builders/topic/986/mmm-globe</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 03:56:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/986.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Nov 2016 17:06:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Globe on Thu, 03 Aug 2023 15:42:29 GMT]]></title><description><![CDATA[<p dir="auto">I wish this worked with MMM-GoogleAnalytics</p>
]]></description><link>https://forum.magicmirror.builders/post/110486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110486</guid><dc:creator><![CDATA[arthurross]]></dc:creator><pubDate>Thu, 03 Aug 2023 15:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Mon, 27 Jul 2020 12:08:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jherndon" aria-label="Profile: JHerndon">@<bdi>JHerndon</bdi></a> - Go to Google’s calendar web page and look for your calendar on the left hand side. When you hover over it with your mouse, you’ll see the 3 dots for the menu. Click on the dots and select “Settings and Sharing”.</p>
<p dir="auto">On the next page, scroll down to “integrate calendar”. Use those URLs (iCal format), no password required.</p>
]]></description><link>https://forum.magicmirror.builders/post/79219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79219</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Mon, 27 Jul 2020 12:08:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Fri, 24 Jul 2020 02:42:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dhruvgami1989" aria-label="Profile: dhruvgami1989">@<bdi>dhruvgami1989</bdi></a> [unrelated] how do you use a private google calendar with a user/pass setup? I haven’t been able to find a tutorial for this.</p>
]]></description><link>https://forum.magicmirror.builders/post/79100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/79100</guid><dc:creator><![CDATA[JHerndon]]></dc:creator><pubDate>Fri, 24 Jul 2020 02:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Sat, 09 May 2020 04:05:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> Thanks for the tip. It came up exactly after 10 mins! Very weird. And no, the globe does not update</p>
]]></description><link>https://forum.magicmirror.builders/post/74888</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74888</guid><dc:creator><![CDATA[dhruvgami1989]]></dc:creator><pubDate>Sat, 09 May 2020 04:05:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Fri, 08 May 2020 06:43:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dhruvgami1989" aria-label="Profile: dhruvgami1989">@<bdi>dhruvgami1989</bdi></a> my current weather appears after 10 minutes but I don’t know why.<br />
Does your globe module update the Picture?<br />
My globe module does not update.</p>
]]></description><link>https://forum.magicmirror.builders/post/74850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74850</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Fri, 08 May 2020 06:43:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Fri, 08 May 2020 04:36:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dhruvgami1989" aria-label="Profile: dhruvgami1989">@<bdi>dhruvgami1989</bdi></a> - I wonder if the globe image is pushing the upper three regions higher? I have a couple things to try, but I don’t have a solution really.</p>
<ul>
<li>Turn off the compliments temporarily and put the globe module in lower_third.</li>
<li>Reduce your globe image size and see if the weather forecast reappears</li>
<li>Move the globe to full_screen below, which should remove it from the shuffling that comes with the module positions.</li>
</ul>
<p dir="auto">I hope one of these works for you.</p>
]]></description><link>https://forum.magicmirror.builders/post/74847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/74847</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 08 May 2020 04:36:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Fri, 10 Jan 2020 19:49:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/flatpepsi" aria-label="Profile: FlatPepsi">@<bdi>FlatPepsi</bdi></a> it is not working…</p>
]]></description><link>https://forum.magicmirror.builders/post/67829</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67829</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Fri, 10 Jan 2020 19:49:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Fri, 10 Jan 2020 18:48:09 GMT]]></title><description><![CDATA[<p dir="auto">I see in the latest code that it is appending the date &amp; time to avoid caching.</p>
<p dir="auto">I’ve added a number of console log messages to the code, and it looks like it’s never refreshing. Can anyone confirm that MMM-Globe really does refresh for them, after the initial page load?</p>
<p dir="auto">I’ve temporarily switched my mirror to MMM-iFrameReloaded, which does indeed refresh, but doesn’t scale the image to the size I need.</p>
]]></description><link>https://forum.magicmirror.builders/post/67824</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67824</guid><dc:creator><![CDATA[FlatPepsi]]></dc:creator><pubDate>Fri, 10 Jan 2020 18:48:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Fri, 04 Oct 2019 00:33:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shgmongohh" aria-label="Profile: shgmongohh">@<bdi>shgmongohh</bdi></a> said in <a href="/post/61949">MMM-Globe</a>:</p>
<p dir="auto">Every hour the picture is updated with the same adress.<br />
I thought that Globe updated the picture with the update intervall.</p>
<p dir="auto">Well, if that is the case then it should update the image in the module. I don’t use this module. Perhaps someone that does use it will chime in with there findings, or fixes.</p>
]]></description><link>https://forum.magicmirror.builders/post/62119</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62119</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 04 Oct 2019 00:33:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 03 Oct 2019 22:20:02 GMT]]></title><description><![CDATA[<p dir="auto">Cool and interesting! Im gonna try it out and see how it works.</p>
]]></description><link>https://forum.magicmirror.builders/post/62112</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/62112</guid><dc:creator><![CDATA[jhoney]]></dc:creator><pubDate>Thu, 03 Oct 2019 22:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Tue, 01 Oct 2019 13:41:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I don´t think that it is static. Every hour the picture is updated with the same adress.<br />
]]></description><link>https://forum.magicmirror.builders/post/61949</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61949</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Tue, 01 Oct 2019 13:41:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Tue, 01 Oct 2019 12:00:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shgmongohh" aria-label="Profile: shgmongohh">@<bdi>shgmongohh</bdi></a> said in <a href="/post/61936">MMM-Globe</a>:</p>
<p dir="auto">EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg’</p>
<p dir="auto">Mykle1 said</p>
<p dir="auto">. . . then that address would need to update with a new picture for the module to retrieve and display it. <strong>If that address is a static picture then the module will only be able to display that.</strong></p>
]]></description><link>https://forum.magicmirror.builders/post/61947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61947</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2019 12:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Tue, 01 Oct 2019 06:58:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saljoke" aria-label="Profile: saljoke">@<bdi>saljoke</bdi></a><br />
I also replaced the URL but the image doesn´t update.<br />
Has anybody a solution, how to update the image automatically?</p>
<pre><code>       ownImagePath:'https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg',
        updateInterval: 10*60*1000
]]></description><link>https://forum.magicmirror.builders/post/61936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61936</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Tue, 01 Oct 2019 06:58:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 20 Jun 2019 14:18:55 GMT]]></title><description><![CDATA[<p dir="auto">I replace the URL own image path with <a href="https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">https://eumetview.eumetsat.int/static-images/latestImages/EUMETSAT_MSG_RGBNatColourEnhncd_LowResolution.jpg</a><br />
There are different of quality but is the better I found</p>
]]></description><link>https://forum.magicmirror.builders/post/58101</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58101</guid><dc:creator><![CDATA[saljoke]]></dc:creator><pubDate>Thu, 20 Jun 2019 14:18:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Mon, 17 Jun 2019 20:21:09 GMT]]></title><description><![CDATA[<p dir="auto">I replaced the own image path in the css with “<a href="http://gif.keraunos.org/nuageseu.gif" target="_blank" rel="noopener noreferrer nofollow ugc">http://gif.keraunos.org/nuageseu.gif</a>”.<br />
The part of the css is looking now:</p>
<p dir="auto">‘’’<br />
{</p>
<pre><code>module: 'MMM-Globe',
position: 'middle_center',
	style: 'europeDiscNat',
	imageSize: 500,
	ownImagePath:'http://gif.keraunos.org/nuageseu.gif',
	updateInterval: 1*60*1000 // ervery 2 minutes
<p dir="auto">},<br />
‘’’<br />
It’s not a real globe, but a good animated gif for the weather forecast with clouds…</p>
]]></description><link>https://forum.magicmirror.builders/post/58040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58040</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Mon, 17 Jun 2019 20:21:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 13 Jun 2019 14:48:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> perfekt thank you …</p>
]]></description><link>https://forum.magicmirror.builders/post/57924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57924</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 13 Jun 2019 14:48:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Thu, 13 Jun 2019 00:50:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a></p>
<p dir="auto">If you are using . . .</p>
<pre><code>ownImagePath:'https://eumetview.eumetsat.int/static-images/MSG/RGB/NATURALCOLOR/FULLRESOLUTION/IMAGESDisplay/VazIBqHF9k665',
<p dir="auto">. . . then that address would need to update with a new picture for the module to retrieve and display it. If that address is a static picture then the module will only be able to display that.</p>
]]></description><link>https://forum.magicmirror.builders/post/57907</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57907</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 13 Jun 2019 00:50:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 12 Jun 2019 20:59:09 GMT]]></title><description><![CDATA[<p dir="auto">until now - no update… still the same picture since 2 hours…</p>
]]></description><link>https://forum.magicmirror.builders/post/57900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57900</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 12 Jun 2019 20:59:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 12 Jun 2019 20:41:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> i hope so</p>
]]></description><link>https://forum.magicmirror.builders/post/57899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57899</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Wed, 12 Jun 2019 20:41:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 12 Jun 2019 20:40:18 GMT]]></title><description><![CDATA[<p dir="auto">yes - and now I still have the question if the picture will be updated automatically. With the old configuration (on the EUMETSAT server) I got a new picture every 15 minutes…</p>
]]></description><link>https://forum.magicmirror.builders/post/57898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57898</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 12 Jun 2019 20:40:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 12 Jun 2019 20:31:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> this is the link from the picture of the Earth on the eumesat webpage…</p>
]]></description><link>https://forum.magicmirror.builders/post/57897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57897</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Wed, 12 Jun 2019 20:31:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 12 Jun 2019 19:01:13 GMT]]></title><description><![CDATA[<p dir="auto">Great!!!</p>
<p dir="auto">It’s working with the link… where did you find it?</p>
<p dir="auto">Regards, Christoph</p>
]]></description><link>https://forum.magicmirror.builders/post/57892</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57892</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 12 Jun 2019 19:01:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Globe on Wed, 12 Jun 2019 06:11:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> ist that ok?</p>
]]></description><link>https://forum.magicmirror.builders/post/57879</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57879</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Wed, 12 Jun 2019 06:11:20 GMT</pubDate></item></channel></rss>
