<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Volume]]></title><description><![CDATA[<h1>MMM-Volume</h1>
<p dir="auto">Volume controller for MagicMirror</p>
<h2>Screenshot</h2>
<p dir="auto"><img src="https://raw.githubusercontent.com/eouia/MMM-Volume/master/mmm-volume.png" alt="Screenshot" class=" img-fluid img-markdown" /></p>
<h2>Main Features</h2>
<ul>
<li>Getting current volume ( 0-100% )</li>
<li>Setting volume</li>
<li>Setting volume on start of MM.</li>
<li>Storing current volume and Restoring</li>
<li>Volume meter will be disappeared after some seconds not to interfere other module.</li>
<li>controllable by definable notifications</li>
<li>controllable by <code>MMM-TelegramBot</code></li>
</ul>
<h2>Notice</h2>
<p dir="auto">Not fully tested on RPI. I’m waiting your bug report.</p>
<h2>Download</h2>
<p dir="auto">[card:eouia/MMM-Volume]</p>
]]></description><link>https://forum.magicmirror.builders/topic/9864/mmm-volume</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 17:46:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9864.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Feb 2019 17:57:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Volume on Mon, 08 Nov 2021 06:45:23 GMT]]></title><description><![CDATA[<p dir="auto">@A Former User said in <a href="/post/55787">MMM-Volume</a>:</p>
<p dir="auto">amixer sget</p>
<p dir="auto">nevermind, i got it working on MagicMirror :) with Raspberry Pi 3B</p>
]]></description><link>https://forum.magicmirror.builders/post/96122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96122</guid><dc:creator><![CDATA[Jonae]]></dc:creator><pubDate>Mon, 08 Nov 2021 06:45:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Sun, 07 Nov 2021 21:50:23 GMT]]></title><description><![CDATA[<p dir="auto">i get volume: null, any idea why?</p>
]]></description><link>https://forum.magicmirror.builders/post/96119</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96119</guid><dc:creator><![CDATA[Jonae]]></dc:creator><pubDate>Sun, 07 Nov 2021 21:50:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Fri, 12 Apr 2019 08:34:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lovesicker" aria-label="Profile: lovesicker">@<bdi>lovesicker</bdi></a><br />
Sorry, I haven’t tesed with that speaker (I don’t have).<br />
If you can control your speaker volume with shell command, I think it possible.<br />
Is it available to control volume on terminal shell? like, <code>amixer sget</code> or <code>amixer sset</code> or any other command.</p>
]]></description><link>https://forum.magicmirror.builders/post/55787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55787</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 12 Apr 2019 08:34:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Fri, 12 Apr 2019 08:28:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi @Sean</p>
<p dir="auto">Your modules are always useful and indispensable!</p>
<p dir="auto">My raspberry 3b sound card is Respeaker 2-Mic. Does MMM-Volume module support this sound card?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/55786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55786</guid><dc:creator><![CDATA[lovesicker]]></dc:creator><pubDate>Fri, 12 Apr 2019 08:28:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Sun, 10 Mar 2019 08:36:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ejay-ibm" aria-label="Profile: ejay-ibm">@<bdi>ejay-ibm</bdi></a> I will take a look as fast as i can. It is deffinitly a problem with the code i added</p>
<p dir="auto">Edit: Added a pull request which should fix the issue</p>
]]></description><link>https://forum.magicmirror.builders/post/54011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54011</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Sun, 10 Mar 2019 08:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Sat, 09 Mar 2019 22:19:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> Thanks for the improvement you bring to the module<br />
The fading is a cool thing to have</p>
<p dir="auto">I have raised a new issue with the new implementation in the code :<br />
<a href="https://github.com/eouia/MMM-Volume/issues/6" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-Volume/issues/6</a></p>
<p dir="auto">I think Sean didn’t get time yet to look at it yet. So if you can help that’s welcome :)</p>
<p dir="auto">Ejay</p>
]]></description><link>https://forum.magicmirror.builders/post/54009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54009</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Sat, 09 Mar 2019 22:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Fri, 08 Mar 2019 17:19:17 GMT]]></title><description><![CDATA[<p dir="auto">@Sean All things i needed are merged now; i archived my repostory and added a hint to yours to the readme</p>
]]></description><link>https://forum.magicmirror.builders/post/53950</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53950</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Fri, 08 Mar 2019 17:19:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Thu, 07 Mar 2019 11:19:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a><br />
Of course, sure. I always prefer ready-mades by others than hand-made by myself. But nobody have made so I should have done it. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/53849</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53849</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 07 Mar 2019 11:19:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Thu, 07 Mar 2019 11:16:28 GMT]]></title><description><![CDATA[<p dir="auto">@Sean I wish i had seen your Module a view days earlier. Last week i desided to develop a volume control Module by my self (<a href="https://github.com/Tom-Hirschberger/MMM-VolumeControl" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Tom-Hirschberger/MMM-VolumeControl</a>). Your Module has nearly the same functionaltiy but looks nicer than mine. Mayby we can join forces. I try to take a closer look to your Module the next days. If something is missing i try to add it and make a pull request?</p>
]]></description><link>https://forum.magicmirror.builders/post/53848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53848</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Thu, 07 Mar 2019 11:16:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Volume on Thu, 21 Feb 2019 21:43:42 GMT]]></title><description><![CDATA[<p dir="auto">Awesome! thank you for this volume manager modules. I needed it you made it!<br />
Works like a charm!<br />
Thanks to QA tester ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/52955</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52955</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Thu, 21 Feb 2019 21:43:42 GMT</pubDate></item></channel></rss>
