<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-FUEL Icon Issue when Default Calendar is activated]]></title><description><![CDATA[<p dir="auto">Hi guys i have a problem with the MMM-Fuel module.<br />
The arrow for price list isn`t showing if i have activate the default Calendar module.</p>
<p dir="auto">default Calendar module activated</p>
<p dir="auto"><img src="/assets/uploads/files/1551040822371-fehler.png" alt="0_1551040819918_fehler.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">default Calendar module deactivated</p>
<p dir="auto"><img src="/assets/uploads/files/1551040902211-ohnefehler.png" alt="0_1551040900570_ohnefehler.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks for help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9879/mmm-fuel-icon-issue-when-default-calendar-is-activated</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 17:19:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9879.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Feb 2019 20:42:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-FUEL Icon Issue when Default Calendar is activated on Tue, 05 Mar 2019 21:56:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Jeff i changed the Icon in the MMM-fuel.js</p>
<p dir="auto"><img src="/assets/uploads/files/1551822973128-mmmfuel.png" alt="0_1551822971934_mmmfuel.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/53715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53715</guid><dc:creator><![CDATA[icke]]></dc:creator><pubDate>Tue, 05 Mar 2019 21:56:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-FUEL Icon Issue when Default Calendar is activated on Mon, 25 Feb 2019 16:24:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/icke" aria-label="Profile: icke">@<bdi>icke</bdi></a> I’m going to guess that both modules are using fontawesome for the icons, but the default calendar is using a local copy that does not include the icon that the MMM-Fuel  needs, and it is likely overriding the MMM-Fuel version.</p>
<p dir="auto">A couple of things you can do:</p>
<ul>
<li>examine the fontawesome CSS file in the calendar module to see if there is a different name for the same icon included, then use some custom CSS to apply it to the MMM-Fuel module</li>
<li>override  fontawesome in your custom CSS with a more complete version, either calling the CDN version directly, or a local copy that includes all the icons you need.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/53142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53142</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Mon, 25 Feb 2019 16:24:19 GMT</pubDate></item></channel></rss>
