<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-nasaastropic no picture]]></title><description><![CDATA[<p dir="auto">I installed the module and it only shows the header and the the url of which should load the image from. But url says: <a href="https://apod.nasa.gov/apod/undefined" target="_blank" rel="noopener noreferrer nofollow ugc">https://apod.nasa.gov/apod/undefined</a>. What does this means?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9899/mmm-nasaastropic-no-picture</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:21:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9899.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Feb 2019 18:19:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-nasaastropic no picture on Tue, 13 Aug 2019 13:05:42 GMT]]></title><description><![CDATA[<p dir="auto">The error <code>https://apod.nasa.gov/apod/undefined</code> with <a href="https://github.com/nebulx29/MMM-nasaastropic" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-nasaastropic</a> can occur when the media published by NASA is not an image (a video for example).</p>
<p dir="auto">My new module <a href="https://github.com/grenagit/MMM-APOD" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-APOD</a> support image and video (thanks to <a href="https://api.nasa.gov/" target="_blank" rel="noopener noreferrer nofollow ugc">NASA API</a>) : <a href="https://github.com/grenagit/MMM-APOD" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/grenagit/MMM-APOD</a></p>
<p dir="auto"><img src="https://raw.githubusercontent.com/grenagit/MMM-APOD/master/MMM-APOD_screenshot.png" alt="MMM-APOD ScreenShots" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/60056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60056</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Tue, 13 Aug 2019 13:05:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-nasaastropic no picture on Fri, 01 Mar 2019 20:05:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stuartiannaylor" aria-label="Profile: stuartiannaylor">@<bdi>stuartiannaylor</bdi></a><br />
That worked! Thank you mate! I am changing the status of the topic as solved.</p>
]]></description><link>https://forum.magicmirror.builders/post/53494</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53494</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Fri, 01 Mar 2019 20:05:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-nasaastropic no picture on Thu, 28 Feb 2019 00:24:07 GMT]]></title><description><![CDATA[<p dir="auto">guess you could just add it in the code header.style.background = “gray”; just have it before the wrapper code and set it there.<br />
But think you can just add a style class in config.js</p>
]]></description><link>https://forum.magicmirror.builders/post/53366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53366</guid><dc:creator><![CDATA[stuartiannaylor]]></dc:creator><pubDate>Thu, 28 Feb 2019 00:24:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-nasaastropic no picture on Wed, 27 Feb 2019 19:08:38 GMT]]></title><description><![CDATA[<p dir="auto">Does anyone knows who can change the title color of the module if it doesn’t have css file? I tried many different entries in my custom css but nothing worked. Thank you in advance.</p>
]]></description><link>https://forum.magicmirror.builders/post/53340</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53340</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Wed, 27 Feb 2019 19:08:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-nasaastropic no picture on Wed, 27 Feb 2019 06:49:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a><br />
I tried the link and it is working but it shows a video instead of a picture. Is that why it doesn’t show on my MM? And that means that every time that NASA will upload a video intstead of a picture I will get the udefined url? I already have installed NASA.</p>
]]></description><link>https://forum.magicmirror.builders/post/53283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53283</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Wed, 27 Feb 2019 06:49:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-nasaastropic no picture on Tue, 26 Feb 2019 22:54:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anthony" aria-label="Profile: anthony">@<bdi>anthony</bdi></a></p>
<p dir="auto">It most likely means that the url to the picture is broken. Having made several modules that use the NASA API I would bet this is the problem. NASA has been known to change their API data.</p>
<p dir="auto">You can send a message and/or create an issue at the repo and see if the author responds. His last commit to this module was 2 years ago.</p>
<p dir="auto">In the meantime, if you are interested in this type of module then you could try <a href="https://github.com/mykle1/MMM-NASA" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mykle1/MMM-NASA</a></p>
]]></description><link>https://forum.magicmirror.builders/post/53253</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53253</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 26 Feb 2019 22:54:31 GMT</pubDate></item></channel></rss>
