<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Anyone know how to use MMM-ShairportMetadata?]]></title><description><![CDATA[<p dir="auto">I have Shairport-Sync working, but i can’t find a good guide on how to install the ShairportMetadata module. The GitHub page doesn’t seem to give much of a guide, unless literally all you have to do is copy the code into the array and it works. All help is appreciated, thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/9906/anyone-know-how-to-use-mmm-shairportmetadata</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 18:00:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9906.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Feb 2019 01:01:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Mon, 07 Dec 2020 06:32:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> did you ever figure this out? Running into some trouble as well</p>
]]></description><link>https://forum.magicmirror.builders/post/85493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85493</guid><dc:creator><![CDATA[monkeyjb123]]></dc:creator><pubDate>Mon, 07 Dec 2020 06:32:13 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Sat, 25 Apr 2020 06:28:41 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Hello, and thank you for this module.<br />
I need your help because I don’t really understand how to add the code “metadata”</p>
<p dir="auto">Regards,</p>
<p dir="auto"><img src="/assets/uploads/files/1587796119301-capture-d-%C3%A9cran-2020-04-25-%C3%A0-08.27.55.png" alt="Capture d’écran 2020-04-25 à 08.27.55.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/73535</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73535</guid><dc:creator><![CDATA[amaralia]]></dc:creator><pubDate>Sat, 25 Apr 2020 06:28:41 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Fri, 01 Mar 2019 00:31:06 GMT]]></title><description><![CDATA[<p dir="auto">Can anyone help? I did</p>
<pre><code>cat /tmp/shairport-sync-metadata
<p dir="auto">And it still isn’t working, could use help from anyone! Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/53445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53445</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Fri, 01 Mar 2019 00:31:06 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 13:00:22 GMT]]></title><description><![CDATA[<p dir="auto">@sean do I have to have anything to receive the metadata or anything? I know that’s a thing but I don’t know if it applys to this module, all I have is shairport-sync set up and then I set up mmm-shairportmetadata and idk if I need anything else. I can’t seem to find much on the module itself so idk what’s going wrong :/</p>
]]></description><link>https://forum.magicmirror.builders/post/53300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53300</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Wed, 27 Feb 2019 13:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 08:31:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a><br />
Hmmm… .with my previous experience, If you set pipe properly (both of module and Shairport) there might not be so much thing to do. Weird…</p>
]]></description><link>https://forum.magicmirror.builders/post/53289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53289</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 27 Feb 2019 08:31:38 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 02:04:45 GMT]]></title><description><![CDATA[<p dir="auto">@sean also, it is playing music due to the shairport-sync i set up, but nothing at all is displayed on screen when music is played.</p>
]]></description><link>https://forum.magicmirror.builders/post/53274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53274</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Wed, 27 Feb 2019 02:04:45 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 02:02:25 GMT]]></title><description><![CDATA[<p dir="auto">@sean the pipe names/adresses match up, but what about the address? how does that come into play? I have it set to the default value that it came with and also says on Github, but if it needs to be changed what do i change it to? Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/53273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53273</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Wed, 27 Feb 2019 02:02:25 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:56:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a><br />
is a song been playing on default iphone “Music” app with AirPlay? You can set output stream to your shairport device name on the music app of iphone Then song will be played on MM via shairport.<br />
If just cover or title is not shown but song is played,  check pipe and address.</p>
]]></description><link>https://forum.magicmirror.builders/post/53272</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53272</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:56:44 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:44:19 GMT]]></title><description><![CDATA[<p dir="auto">@sean Well, unfortunately i edited to metadata stuff and i put the code in the modules array in config.js, but the module isn’t appearing on the screen when i have music playing. Is there something i am missing?</p>
]]></description><link>https://forum.magicmirror.builders/post/53271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53271</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:35:45 GMT]]></title><description><![CDATA[<p dir="auto">@sean got it, thank you so much! Very new to this so not always sure what to do even for the “easy” stuff haha :smiling_face_with_open_mouth_cold_sweat:</p>
]]></description><link>https://forum.magicmirror.builders/post/53270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53270</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:30:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a><br />
Open it with ‘sudo’</p>
]]></description><link>https://forum.magicmirror.builders/post/53269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53269</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:29:54 GMT]]></title><description><![CDATA[<p dir="auto">@sean i went into the .conf file and i changed the values for the metadata section, but when i try to save it says “permission denied”. What do i have to do to let it let me save the file?</p>
]]></description><link>https://forum.magicmirror.builders/post/53268</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53268</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:29:54 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:31:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a><br />
Yes, that is all. Basically this module’s purpose is showing album art and song title of current playing via Shairport. That’s all, so there be not so many things to do.</p>
]]></description><link>https://forum.magicmirror.builders/post/53267</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53267</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:31:12 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:21:43 GMT]]></title><description><![CDATA[<p dir="auto">so all i have to do is modify that file in the way it is on the Github page and then copy the code for the module into the module array and that’s it?</p>
]]></description><link>https://forum.magicmirror.builders/post/53265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53265</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:21:43 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone know how to use MMM-ShairportMetadata? on Wed, 27 Feb 2019 01:20:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a><br />
Open Shairport Sync configuration file at /etc/shairport-sync.conf (note that in FreeBSD it will be at /usr/local/etc/shairport-sync.conf).<br />
Then modify content by sample of MMM-ShairprtMetadata instruction. There aren’t so many things to do…</p>
]]></description><link>https://forum.magicmirror.builders/post/53264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53264</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 27 Feb 2019 01:20:22 GMT</pubDate></item></channel></rss>
