<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[230V in the naked monitor]]></title><description><![CDATA[<p dir="auto">Hi :)<br />
I got an old flatscreen monitor that fits quite well into a magic mirror. The only problem is, it has an integrated power supply. That means the 230V AC (Germany) go right into the monitor that I have to free from its case, leaving bare metal. Which makes me feel extremely uneasy touching it or leaving it hanging from the wall (I know it shouldn’t be a problem, but still I really don’t like the idea).<br />
Any electricians / experts among you, what do you think? Is it safe to use a monitor with internal 230V power supply without the case?</p>
]]></description><link>https://forum.magicmirror.builders/topic/991/230v-in-the-naked-monitor</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 08:49:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/991.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Nov 2016 21:11:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 230V in the naked monitor on Sat, 19 Nov 2016 21:04:34 GMT]]></title><description><![CDATA[<p dir="auto">Alright, here’s the picture<br />
<img src="/uploads/files/1479589379257-resize-6-resized.jpg" alt="0_1479589366377_resize-6.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I checked with a multimeter, the whole case is connected to ground. That won’t be a problem then.<br />
But the monitor gets HOT, I can barely touch the part on the back that has little holes in it. I really need to think of a solution to that.</p>
]]></description><link>https://forum.magicmirror.builders/post/8244</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8244</guid><dc:creator><![CDATA[dbahn25]]></dc:creator><pubDate>Sat, 19 Nov 2016 21:04:34 GMT</pubDate></item><item><title><![CDATA[Reply to 230V in the naked monitor on Tue, 15 Nov 2016 21:40:30 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your ideas!<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a> mine looks quite a lot like yours. I took some photos and will post them on the weekend, but I won’t have any time this week.<br />
I also had the idea to check with the multimeter, but I didn’t know what exactly to connect to.<br />
I know that <em>theoretically</em> the metal shouldn’t carry a high voltage and be grounded anyway, but I still fear that something bad might happen, especially when the already-old monitor ages even further (I know, nobody can guarantee anything, but still it’s good to discuss the matter)<br />
Heat is another problem I didn’t think of at all yet, I’ll check that as well when I have time.</p>
]]></description><link>https://forum.magicmirror.builders/post/8003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8003</guid><dc:creator><![CDATA[dbahn25]]></dc:creator><pubDate>Tue, 15 Nov 2016 21:40:30 GMT</pubDate></item><item><title><![CDATA[Reply to 230V in the naked monitor on Tue, 15 Nov 2016 21:06:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dbahn25" aria-label="Profile: dbahn25">@<bdi>dbahn25</bdi></a></p>
<p dir="auto">Do you have got a picture ?</p>
<p dir="auto">Normaly the metall which you can touch (even after removing the plastic shell) should have no contact with high voltage, as far as i know. The powersupply is normaly in an isolated shell because otherwise your screen will be rosted ;-) The other thing is the heat which leaves the monitor espacially with an internal power supply - anything higher than 45-50°C i would not accept especially when you think about the other parts of your mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/7995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7995</guid><dc:creator><![CDATA[Novocain]]></dc:creator><pubDate>Tue, 15 Nov 2016 21:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to 230V in the naked monitor on Tue, 15 Nov 2016 16:16:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/done" aria-label="Profile: done">@<bdi>done</bdi></a> Ok, in this case I have no idea. But if it is about the heat, I would probably prefer a hot thing over an electrocuting thing around my walls and the mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/7982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7982</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Tue, 15 Nov 2016 16:16:15 GMT</pubDate></item><item><title><![CDATA[Reply to 230V in the naked monitor on Tue, 15 Nov 2016 13:41:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a> said in <a href="/post/7978">230V in the naked monitor</a>:</p>
<p dir="auto">doesn’t every monitor have the power supply inside somewhere?</p>
<p dir="auto">Mine has an external power supply like those for laptops.<br />
So I don’t have to remove the cover of the thing that converts 230 V to whatever.<br />
I was looking for this feature to be more flexible in terms of heat prevention.</p>
]]></description><link>https://forum.magicmirror.builders/post/7979</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7979</guid><dc:creator><![CDATA[done]]></dc:creator><pubDate>Tue, 15 Nov 2016 13:41:34 GMT</pubDate></item><item><title><![CDATA[Reply to 230V in the naked monitor on Tue, 15 Nov 2016 13:33:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">doesn’t every monitor have the power supply inside somewhere? I think, all the ones I have, do. Did you check, whether the bare metal that you <em>could</em> touch is grounded? You can do this for example, with a multimeter, by checking if current flows through it, after connecting the outer metal case and the ground of your plug (number 2 on the left side of this <a href="https://en.wikipedia.org/wiki/Schuko#/media/File:Schuko_plug_and_socket_annotated.png" target="_blank" rel="noopener noreferrer nofollow ugc">wikipedia image</a>. If so, you should be pretty safe, however of course I am not a qualified electrician and all information is supplied without liability.</p>
<p dir="auto">This is how mine looks and it is definitely safe to touch the outer case.</p>
<p dir="auto"><img src="/uploads/files/1479216550068-screenshot-from-2016-11-15-14-27-20.png" alt="0_1479216548977_Screenshot from 2016-11-15 14:27:20.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Best regards!</p>
]]></description><link>https://forum.magicmirror.builders/post/7978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7978</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Tue, 15 Nov 2016 13:33:27 GMT</pubDate></item><item><title><![CDATA[Reply to 230V in the naked monitor on Tue, 15 Nov 2016 09:17:47 GMT]]></title><description><![CDATA[<p dir="auto">i would not recommend it without having some form of isolation for the power supply.</p>
]]></description><link>https://forum.magicmirror.builders/post/7968</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7968</guid><dc:creator><![CDATA[Toast]]></dc:creator><pubDate>Tue, 15 Nov 2016 09:17:47 GMT</pubDate></item><item><title><![CDATA[Reply to 230V in the naked monitor on Mon, 14 Nov 2016 21:33:31 GMT]]></title><description><![CDATA[<p dir="auto">Good luck! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/7958</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7958</guid><dc:creator><![CDATA[done]]></dc:creator><pubDate>Mon, 14 Nov 2016 21:33:31 GMT</pubDate></item></channel></rss>
