<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ELECTRON window starts on top of MM window after clean install!]]></title><description><![CDATA[<p dir="auto">Hi.<br />
Firstly, thanks for awesome programming!</p>
<p dir="auto">Now, I have followed this tutorial EXACTLY:<br />
<a href="https://howchoo.com/g/ntcymzbimjv/how-to-install-magic-mirror-on-your-raspberry-pi" target="_blank" rel="noopener noreferrer nofollow ugc">https://howchoo.com/g/ntcymzbimjv/how-to-install-magic-mirror-on-your-raspberry-pi</a> exactly.</p>
<p dir="auto">And at <strong>step 8</strong> (see my screenshot) after the reboot a stupid blank black “electron” window shows up on top of my MagicMirror window. So I have to go on to my pi gui and minimize it.<br />
If I try to close it another new “Electron window” pops up on top.<br />
:(</p>
<p dir="auto">I’m using the Raspberry Pi 3 B+.</p>
<p dir="auto">How can I get rid of the “electron window”???</p>
<p dir="auto">Kindest regards, Håkan</p>
<p dir="auto"><img src="/assets/uploads/files/1551337059553-sk%C3%A4rmavbild-2019-02-27-kl.23.06.25.png" alt="0_1551337057444_Skärmavbild 2019-02-27 kl. 23.06.25.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/9916/electron-window-starts-on-top-of-mm-window-after-clean-install</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 08:33:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9916.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Feb 2019 06:58:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ELECTRON window starts on top of MM window after clean install! on Fri, 01 Mar 2019 18:02:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: axled">@<bdi>axled</bdi></a><br />
Ok, yes. I think this was the issue. So when I removed the autostart from pm2 it now only boots up the one MagicMirror.<br />
Now I’m just having problems to show the MMM-Globe module even though I have activated the OpenGL on the pi.</p>
<p dir="auto">After I removed the autostart from <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> my “pm2 ls” command now shows:<br />
┌─────────────┬────┬───────┬────────┬─────────┬───────┬────────┬──────────┐<br />
│ Name        │ id │ mode  │ status │ ↺       │ cpu   │ memory │<br />
├─────────────┼────┼───────┼────────┼─────────┼───────┼────────┼──────────┤<br />
│ MagicMirror │ 0  │ 2.6.0 │ fork   │ online  │ 1     │ 0%     │ 2.5 MB   │<br />
│ mm          │ 1  │ N/A   │ fork   │ stopped │ 34555 │ 0%     │ 0 B      │<br />
└─────────────┴────┴───────┴────────┴─────────┴───────┴────────┴──────────┘<br />
Use <code>pm2 show &lt;id|name&gt;</code> to get more details about an app</p>
]]></description><link>https://forum.magicmirror.builders/post/53479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53479</guid><dc:creator><![CDATA[Gryglas]]></dc:creator><pubDate>Fri, 01 Mar 2019 18:02:32 GMT</pubDate></item><item><title><![CDATA[Reply to ELECTRON window starts on top of MM window after clean install! on Thu, 28 Feb 2019 19:10:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gryglas" aria-label="Profile: Gryglas">@<bdi>Gryglas</bdi></a><br />
If you enter <code>pm2 list</code> in a console, what is the result?<br />
I guess your pm2 starts MagicMirror twice, as it will be installed by default from the MagicMirror installer script.</p>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/53440</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53440</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Thu, 28 Feb 2019 19:10:32 GMT</pubDate></item><item><title><![CDATA[Reply to ELECTRON window starts on top of MM window after clean install! on Thu, 28 Feb 2019 16:21:02 GMT]]></title><description><![CDATA[<p dir="auto">So, what I did was I stopped <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> and removed the autostart and also removed the <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> and now it only boots up one magic mirror windows. Where this is coming from I have no idea but it works.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/53421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53421</guid><dc:creator><![CDATA[Gryglas]]></dc:creator><pubDate>Thu, 28 Feb 2019 16:21:02 GMT</pubDate></item></channel></rss>
