<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Start Raspberry Pi with TV]]></title><description><![CDATA[<p dir="auto">Hello!</p>
<p dir="auto">I have an old TV without HDMI CEC so it won’t startup when I’m starting the Pi. I’m going to connect a <a href="https://www.amazon.com/Sonoff-Electrical-Household-Appliances-Compatible/dp/B07BDFDHX9/ref=sr_1_2?keywords=sonoff&amp;qid=1551451656&amp;s=gateway&amp;sr=8-2" target="_blank" rel="noopener noreferrer nofollow ugc">Sonoff</a> as a remote switch to turn everything off when I’m not home, but when I turn the power back on the TV is in standby and to start it I’ll have to use a remote.</p>
<p dir="auto">Is there a way to make the Raspberry Pi send a signal to the TV and wake it up?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9928/start-raspberry-pi-with-tv</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 01:35:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9928.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Mar 2019 14:52:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Start Raspberry Pi with TV on Thu, 21 Mar 2019 20:52:52 GMT]]></title><description><![CDATA[<p dir="auto">I should of mentioned these things, doh!</p>
<p dir="auto"><a href="https://www.aliexpress.com/item/Original-New-Broadlink-RM-Mini3-Black-Bean-Smart-Home-Universal-Intelligent-WiFi-IR-4G-Wireless-Remote/32647630434.html?spm=2114.search0104.3.23.2fe91284aQbOSk&amp;ws_ab_test=searchweb0_0,searchweb201602_4_10065_10068_10130_10547_319_317_10548_10696_10192_10190_453_10084_454_10083_10618_10307_10820_10301_10821_10303_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_16,ppcSwitch_0&amp;algo_expid=28da5b57-2352-4519-88f0-0f130177d914-3&amp;algo_pvid=28da5b57-2352-4519-88f0-0f130177d914&amp;transAbTest=ae803_3" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/item/Original-New-Broadlink-RM-Mini3-Black-Bean-Smart-Home-Universal-Intelligent-WiFi-IR-4G-Wireless-Remote/32647630434.html?spm=2114.search0104.3.23.2fe91284aQbOSk&amp;ws_ab_test=searchweb0_0,searchweb201602_4_10065_10068_10130_10547_319_317_10548_10696_10192_10190_453_10084_454_10083_10618_10307_10820_10301_10821_10303_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_16,ppcSwitch_0&amp;algo_expid=28da5b57-2352-4519-88f0-0f130177d914-3&amp;algo_pvid=28da5b57-2352-4519-88f0-0f130177d914&amp;transAbTest=ae803_3</a></p>
<p dir="auto">But basically a Pi with an IR LED</p>
]]></description><link>https://forum.magicmirror.builders/post/54699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54699</guid><dc:creator><![CDATA[stuartiannaylor]]></dc:creator><pubDate>Thu, 21 Mar 2019 20:52:52 GMT</pubDate></item><item><title><![CDATA[Reply to Start Raspberry Pi with TV on Wed, 20 Mar 2019 17:50:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stuartiannaylor" aria-label="Profile: stuartiannaylor">@<bdi>stuartiannaylor</bdi></a></p>
<p dir="auto">Took your advice and now it’s working perfectly. Big thanks for the help!</p>
]]></description><link>https://forum.magicmirror.builders/post/54616</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54616</guid><dc:creator><![CDATA[Hallonpaj]]></dc:creator><pubDate>Wed, 20 Mar 2019 17:50:09 GMT</pubDate></item><item><title><![CDATA[Reply to Start Raspberry Pi with TV on Fri, 01 Mar 2019 19:33:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hallonpaj" aria-label="Profile: hallonpaj">@<bdi>hallonpaj</bdi></a> Yeah of course it could you can get a 3.3v relay and its a 2 wire job to GPIO</p>
<p dir="auto">But what are you going to wire it to?</p>
<p dir="auto">What you do is put an IR Led on a wire and your Pi is now a universal remote for any device in range via LIRC.<br />
Its a LED + resistor and two wires.</p>
<p dir="auto"><a href="http://www.lirc.org/" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.lirc.org/</a></p>
<p dir="auto">Yeah a pi could with the right interface also do powerline comms but your TV can not so that would be a bit pointless<br />
<a href="https://www.aliexpress.com/item/3-3V-5V-12V-24V-1-Channel-Relay-Module-Low-Level-Trigger-Optocoupler-Isolation-Relay-Module/32849672414.html?src=google&amp;albslr=221170259&amp;src=google&amp;albch=shopping&amp;acnt=494-037-6276&amp;isdl=y&amp;slnk=&amp;plac=&amp;mtctp=&amp;albbt=Google_7_shopping&amp;aff_platform=google&amp;aff_short_key=UneMJZVf&amp;&amp;albagn=888888&amp;albcp=1706973087&amp;albag=65008162765&amp;trgt=296904914040&amp;crea=en32849672414&amp;netw=u&amp;device=c&amp;gclid=Cj0KCQiAzePjBRCRARIsAGkrSm7WKqheLphSYy6d32kQd-7D9xInwCfxCdYzlxHx6C493on_yqY7e-gaAvVHEALw_wcB&amp;gclsrc=aw.ds" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/item/3-3V-5V-12V-24V-1-Channel-Relay-Module-Low-Level-Trigger-Optocoupler-Isolation-Relay-Module/32849672414.html?src=google&amp;albslr=221170259&amp;src=google&amp;albch=shopping&amp;acnt=494-037-6276&amp;isdl=y&amp;slnk=&amp;plac=&amp;mtctp=&amp;albbt=Google_7_shopping&amp;aff_platform=google&amp;aff_short_key=UneMJZVf&amp;&amp;albagn=888888&amp;albcp=1706973087&amp;albag=65008162765&amp;trgt=296904914040&amp;crea=en32849672414&amp;netw=u&amp;device=c&amp;gclid=Cj0KCQiAzePjBRCRARIsAGkrSm7WKqheLphSYy6d32kQd-7D9xInwCfxCdYzlxHx6C493on_yqY7e-gaAvVHEALw_wcB&amp;gclsrc=aw.ds</a></p>
]]></description><link>https://forum.magicmirror.builders/post/53490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53490</guid><dc:creator><![CDATA[stuartiannaylor]]></dc:creator><pubDate>Fri, 01 Mar 2019 19:33:02 GMT</pubDate></item><item><title><![CDATA[Reply to Start Raspberry Pi with TV on Fri, 01 Mar 2019 19:05:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hallonpaj" aria-label="Profile: hallonpaj">@<bdi>hallonpaj</bdi></a> sure, can do… but someone will probably has to write code (module) to make that happen…</p>
]]></description><link>https://forum.magicmirror.builders/post/53484</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53484</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Mar 2019 19:05:54 GMT</pubDate></item><item><title><![CDATA[Reply to Start Raspberry Pi with TV on Fri, 01 Mar 2019 18:50:34 GMT]]></title><description><![CDATA[<p dir="auto">There’s no way to make the Raspberry Pi send a button prompt or some kind of electric signal via the GPIO?</p>
]]></description><link>https://forum.magicmirror.builders/post/53482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53482</guid><dc:creator><![CDATA[Hallonpaj]]></dc:creator><pubDate>Fri, 01 Mar 2019 18:50:34 GMT</pubDate></item><item><title><![CDATA[Reply to Start Raspberry Pi with TV on Fri, 01 Mar 2019 16:04:04 GMT]]></title><description><![CDATA[<p dir="auto">You sort of need to do this in reverse.</p>
<p dir="auto"><a href="https://hackaday.com/2017/04/23/the-raspberry-pi-as-an-ir-to-wifi-bridge/" target="_blank" rel="noopener noreferrer nofollow ugc">https://hackaday.com/2017/04/23/the-raspberry-pi-as-an-ir-to-wifi-bridge/</a></p>
<p dir="auto">But yeah I would do some googling on the pi being a ir reciever / sender</p>
<p dir="auto"><a href="https://www.hackster.io/austin-stanton/creating-a-raspberry-pi-universal-remote-with-lirc-2fd581" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/austin-stanton/creating-a-raspberry-pi-universal-remote-with-lirc-2fd581</a></p>
<p dir="auto"><a href="http://alexba.in/blog/2013/01/06/setting-up-lirc-on-the-raspberrypi/" target="_blank" rel="noopener noreferrer nofollow ugc">http://alexba.in/blog/2013/01/06/setting-up-lirc-on-the-raspberrypi/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/53469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53469</guid><dc:creator><![CDATA[stuartiannaylor]]></dc:creator><pubDate>Fri, 01 Mar 2019 16:04:04 GMT</pubDate></item></channel></rss>
