<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is MMM-AssistantMk2 compatible with PulseAudio?]]></title><description><![CDATA[<p dir="auto">I use PulseAudio with my PS3 eye camera microphone, is this program compatible with MMM-AssistantMk2? I would like to use this mic with this module if possible.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9930/is-mmm-assistantmk2-compatible-with-pulseaudio</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 10:42:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9930.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Mar 2019 18:16:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is MMM-AssistantMk2 compatible with PulseAudio? on Sat, 02 Mar 2019 16:19:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a> said in <a href="/post/53509">Is MMM-AssistantMk2 compatible with PulseAudio?</a>:</p>
<p dir="auto">How do I use a record to check if my mic records?</p>
<pre><code>arecord somefile.wav
<p dir="auto">then</p>
<pre><code>aplay somefile.wav
<p dir="auto">sometimes the default device isn’t setup… so</p>
<pre><code>arecord -l (letter L)
<p dir="auto">will give u the list of devices…</p>
]]></description><link>https://forum.magicmirror.builders/post/53534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53534</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Mar 2019 16:19:30 GMT</pubDate></item><item><title><![CDATA[Reply to Is MMM-AssistantMk2 compatible with PulseAudio? on Sat, 02 Mar 2019 16:14:23 GMT]]></title><description><![CDATA[<p dir="auto">This is fantastic. Hope will come with full guide and instruction in each step.</p>
]]></description><link>https://forum.magicmirror.builders/post/53532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53532</guid><dc:creator><![CDATA[audreyspency]]></dc:creator><pubDate>Sat, 02 Mar 2019 16:14:23 GMT</pubDate></item><item><title><![CDATA[Reply to Is MMM-AssistantMk2 compatible with PulseAudio? on Fri, 01 Mar 2019 21:27:38 GMT]]></title><description><![CDATA[<p dir="auto">@sean I use PulseAudio for my microphone because the mic uses a 4 mic array and the default program doesn’t like that, I thinks it’s Alsa or something, but anyways, I use the speakers connected to the TV I am using via the HDMI output, and it works to play an MP3 I downloaded as well as using Shairport-sync. How do I use a record to check if my mic records? When I open pulse audio and speak into my mic it registers as picking up sound, is that enough? Or do I need to use arecord?</p>
]]></description><link>https://forum.magicmirror.builders/post/53509</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53509</guid><dc:creator><![CDATA[jmartin1009]]></dc:creator><pubDate>Fri, 01 Mar 2019 21:27:38 GMT</pubDate></item><item><title><![CDATA[Reply to Is MMM-AssistantMk2 compatible with PulseAudio? on Fri, 01 Mar 2019 19:01:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmartin1009" aria-label="Profile: jmartin1009">@<bdi>jmartin1009</bdi></a><br />
I’m using pulseaudio for BT external speaker in ATB, and it works well.<br />
The only things you should check are;</p>
<ul>
<li>get a mic recording with arecord</li>
<li>output sound with aplay or other player</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/53483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53483</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 01 Mar 2019 19:01:58 GMT</pubDate></item></channel></rss>
