<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror @ Munich]]></title><description><![CDATA[<p dir="auto">Basically I rebuilt our Magic Mirror monitor in a very similar way like <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a>. I did order the same 24" monitor at Amazon (thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> for the great instruction). The installation of the software on the raspi3 was really simple and showed great results on a test monitor.</p>
<p dir="auto">What I could not imagine that it was nearly a nightmare to get a spy glass at a local glacier in Munich, however after many mails and phone calls, I was able to find a local glacier. (More details on this part of the story <a href="https://forum.magicmirror.builders/topic/756/where-to-get-cheap-acrylic-mirror-from-in-germany/31">here</a>.</p>
<p dir="auto">As promised in this separate thread here are some pictures of my MagicMirror.</p>
<p dir="auto">Let us start with the final result, and I am more than happy with it, the wife acceptance factor is great as well and especially my nine year old boy loves it, since he helped to do a lot of the assembly stuff together with me :).</p>
<p dir="auto"><img src="/uploads/files/1479238591992-anhang-9-1-resized.jpg" alt="finally_mounted_mirror.jpg" class=" img-fluid img-markdown" /><br />
You can see at the right bottom a small IR sensor, since I do not have a 3D printer, I have sawn the casing yesterday manually, it still needs to be painted, currently I am testing it and trying to get the module running.<br />
What I did differently is the way to mount the mirror. I am using two pieces of wood cut in 45° angle enforcing a direct fit and very reliable and stable mounting position of the MagicMirror. Details you can see in the following pictures. Note: If you are wondering about the power supply, I simply drilled a hole through the wall, since a power plug was much nearer that at the mounting position.<br />
<img src="/uploads/files/1479239004860-anhang-1-1-resized.jpg" alt="Mounting_at_wall_inclusive_power_supply.jpg" class=" img-fluid img-markdown" /><br />
<img src="/uploads/files/1479239080857-anhang-2-1-resized.jpg" alt="Detailed_view_wall_mount.jpg" class=" img-fluid img-markdown" /><br />
<img src="/uploads/files/1479239143365-anhang-5-1-resized.jpg" alt="Mount_counterpart_in_MM.jpg" class=" img-fluid img-markdown" /><br />
The interior looks like this:<br />
<img src="/uploads/files/1479239258639-anhang-3-1-resized.jpg" alt="Interior_Overview.jpg" class=" img-fluid img-markdown" /><br />
There is one thing I am unsure about. I have noticed that the controller unit (inverter/ controller) of the monitor has slightly shifted. Maybe I “pressed” the HDMI cable  too much and therefore it got dislocated. You can see this in the last picture.<br />
Did anyone of you observe this as well ? I am considering to stabilize it again mechanically by construction something in wood.</p>
<p dir="auto">In case you have questions do not hesitate :).</p>
<p dir="auto">Regards<br />
Stefan</p>
]]></description><link>https://forum.magicmirror.builders/topic/994/magic-mirror-munich</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 20:50:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/994.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Nov 2016 19:54:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror @ Munich on Fri, 20 Jan 2017 12:01:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steff" aria-label="Profile: Steff">@<bdi>Steff</bdi></a> said in <a href="/post/7988">Magic Mirror @ Munich</a>:</p>
<p dir="auto">There is one thing I am unsure about. I have noticed that the controller unit (inverter/ controller) of the monitor has slightly shifted. Maybe I “pressed” the HDMI cable  too much and therefore it got dislocated. You can see this in the last picture.</p>
<p dir="auto">Hi all,</p>
<p dir="auto">I encountered the same thing with my Viewsonic. It appears, the Controller units arent’t riveted or bolted (or even glued) to the backpanel. They are just taped together with a silverisch tape. My Monitor has a VESA-Mount at the back, so I thought of bolting the wonitor to the wall with a slim VESA-Mount - which worked for 12hours, then the panel fell off - fortunatetly everything is still working.<br />
So I’m thinking - either you have to tape it more thoroughly or use a two-component metal glue for a stable compound.</p>
<p dir="auto">In my case, I’m making a provisionary case with wood also, which holds the Monitor - and I’m not using the VESA-Mount anymore.</p>
]]></description><link>https://forum.magicmirror.builders/post/11738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11738</guid><dc:creator><![CDATA[binderth]]></dc:creator><pubDate>Fri, 20 Jan 2017 12:01:23 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror @ Munich on Fri, 20 Jan 2017 11:08:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steff" aria-label="Profile: Steff">@<bdi>Steff</bdi></a></p>
<p dir="auto">Nice work done. Your idea  with the LEDs is pretty cool.</p>
]]></description><link>https://forum.magicmirror.builders/post/11732</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11732</guid><dc:creator><![CDATA[PaulB]]></dc:creator><pubDate>Fri, 20 Jan 2017 11:08:50 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror @ Munich on Sun, 18 Dec 2016 20:59:33 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/tree/develop/modules/default/compliments" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/tree/develop/modules/default/compliments</a></p>
]]></description><link>https://forum.magicmirror.builders/post/9546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9546</guid><dc:creator><![CDATA[chrisfoerg]]></dc:creator><pubDate>Sun, 18 Dec 2016 20:59:33 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror @ Munich on Sun, 18 Dec 2016 20:55:20 GMT]]></title><description><![CDATA[<p dir="auto">How did you guys manage to change the greeting? That has been giving me trouble lately.</p>
]]></description><link>https://forum.magicmirror.builders/post/9544</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9544</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Sun, 18 Dec 2016 20:55:20 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror @ Munich on Sun, 18 Dec 2016 19:23:43 GMT]]></title><description><![CDATA[<p dir="auto">Some enhancements done in the meanwhile:<br />
a) The CPU temperature was always above 60°C so I added two <a href="https://www.amazon.de/gp/r.html?C=14IUM7CL72TPO&amp;K=ATHW4Q9M9THLU&amp;R=1ETD8B91ND06X&amp;T=C&amp;U=https%3A%2F%2Fwww.amazon.de%2Fdp%2FB00W7BXTH6%2Fref%3Dpe_386171_51767411_TE_dp_2&amp;A=MEJ4VS1OIREI3KFAWYAF80IFXPOA&amp;H=9A89E5BP5AEAWRAMMROPPDLAGPMA&amp;ref_=pe_386171_51767411_TE_dp_2" target="_blank" rel="noopener noreferrer nofollow ugc">heatsinks</a> and one small <a href="https://www.amazon.de/gp/r.html?C=14IUM7CL72TPO&amp;K=ATHW4Q9M9THLU&amp;R=1ETD8B91ND06X&amp;T=C&amp;U=https%3A%2F%2Fwww.amazon.de%2Fdp%2FB00UWIB68U%2Fref%3Dpe_386171_51767411_TE_dp_1&amp;A=TLCHQXNIAA7ML9PYFTQC7AUSPSYA&amp;H=EKSHRPLHLHU4LDGCP3L7NLUHRYIA&amp;ref_=pe_386171_51767411_TE_dp_1" target="_blank" rel="noopener noreferrer nofollow ugc">ventilator</a>. Since then my CPU temperature is always below 50°C (mostly around 40-44 °C).<br />
<img src="/uploads/files/1482088606321-img_0191-resized.jpg" alt="0_1482088604417_IMG_0191.jpg" class=" img-fluid img-markdown" /><br />
b) I did ask in my first post whether someone had the problem that the inverter of the monitor did move. Well, in my case I did have this problem, so added some wooden holders to ensure that the inverter stays at the place intended to be.<br />
<img src="/uploads/files/1482088575776-img_0193-resized.jpg" alt="0_1482088573094_IMG_0193.jpg" class=" img-fluid img-markdown" /><br />
c) In the area where I mounted the mirror on the wall it is even during daylight quite dark. So the mirror did not really show its intended mirror effect. In order to get more light directly in the area of the mirror I mounted <a href="https://www.amazon.de/gp/r.html?C=14IUM7CL72TPO&amp;K=ATHW4Q9M9THLU&amp;R=1ETD8B91ND06X&amp;T=C&amp;U=https%3A%2F%2Fwww.amazon.de%2Fdp%2FB00YMI0KEM%2Fref%3Dpe_386171_51767411_TE_dp_1&amp;A=A5OGCB1GACXFBTNR7VOLULXERI0A&amp;H=JAADYRREYDAK2K71T0LTGHPBSF8A&amp;ref_=pe_386171_51767411_TE_dp_1" target="_blank" rel="noopener noreferrer nofollow ugc">3 LED spots</a> on top of the mirror. Now I do have extremely good conditions. :)<br />
View of the 3 LED spots:<br />
<img src="/uploads/files/1482088822455-img_0192-resized.jpg" alt="0_1482088819617_IMG_0192.jpg" class=" img-fluid img-markdown" /><br />
View with the LED spots in operation:<br />
<img src="/uploads/files/1482089015922-img_1415.jpg" alt="0_1482089014841_IMG_1415.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/9537</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9537</guid><dc:creator><![CDATA[Steff]]></dc:creator><pubDate>Sun, 18 Dec 2016 19:23:43 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror @ Munich on Tue, 15 Nov 2016 22:08:52 GMT]]></title><description><![CDATA[<p dir="auto">Following modules are currently used:<br />
MMM-PIR-Sensor<br />
MMM-Wunderlist<br />
MMM-WunderGround<br />
clock<br />
calendar referring to my personal google calendar<br />
compliments<br />
newsfeed referring to the rss of Sueddeutsche Zeitung</p>
<p dir="auto">That´s it.<br />
I am thinking of implementing additionally some picture slide show for my kids, however firstly I have to get the PIR running, currently the PIR is correctly detecting, however not yet switching off my hdmi, that is something I have to work on…</p>
]]></description><link>https://forum.magicmirror.builders/post/8006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8006</guid><dc:creator><![CDATA[Steff]]></dc:creator><pubDate>Tue, 15 Nov 2016 22:08:52 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror @ Munich on Tue, 15 Nov 2016 20:55:33 GMT]]></title><description><![CDATA[<p dir="auto">Great job!<br />
Can you tell me which modules you are using? e.g. which weather modul and so on… :)<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/7993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7993</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 15 Nov 2016 20:55:33 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror @ Munich on Tue, 15 Nov 2016 20:38:53 GMT]]></title><description><![CDATA[<p dir="auto">Looks great, good job Stefan.</p>
]]></description><link>https://forum.magicmirror.builders/post/7992</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7992</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 15 Nov 2016 20:38:53 GMT</pubDate></item></channel></rss>
