<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Formula1 is not loading]]></title><description><![CDATA[<p dir="auto">Hello,<br />
i try to install the module and it shows still loading… I do not find the problem.<br />
The clone from git was successfully. All other modules are running without any problems.</p>
<p dir="auto">Does someone has an idea what the problem could be?<br />
Thanks!</p>
<p dir="auto">my config:</p>
<p dir="auto">{<br />
module: ‘MMM-Formula1’,<br />
position: ‘top_right’,<br />
header: ‘Formel 1’,<br />
config: {<br />
season: ‘current’,<br />
type: ‘DRIVER’,<br />
maxRows: 10 ,<br />
calendar: false,<br />
fade: true,<br />
fadePoint: 0.3,<br />
reloadInterval: 30 * 60 * 1000,       // every 30 minutes<br />
animationSpeed: 2.5 * 1000,           // 2.5 seconds<br />
}<br />
},</p>
]]></description><link>https://forum.magicmirror.builders/topic/995/mmm-formula1-is-not-loading</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 16:54:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/995.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Nov 2016 21:09:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Formula1 is not loading on Fri, 18 Nov 2016 10:46:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/viper-sg2" aria-label="Profile: viper-sg2">@<bdi>viper-sg2</bdi></a> said in <a href="/post/8151">MMM-Formula1 is not loading</a>:</p>
<p dir="auto">Today, i reboot my mirror and i was amazed. The module was loading…<br />
yesterday i delete the module and cloned it again. I restart my MM and: No Loading - the module didn’t start properly. Annoyed i switched off the rasberry.</p>
<p dir="auto">Today morning, after the boot of my MM: Surprise - the module is loading!?</p>
<p dir="auto">I didn’t have any explanation, sorry <a class="plugin-mentions-user plugin-mentions-a" href="/user/frog" aria-label="Profile: frog">@<bdi>frog</bdi></a>, but maybe, clone the repo again und set up with no configuration, just i do. Restart the rasberry and see what happened.</p>
<p dir="auto">Not sure what you are sorry about - as I said, I removed all parameters in the config.js and was working again.</p>
]]></description><link>https://forum.magicmirror.builders/post/8165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8165</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Fri, 18 Nov 2016 10:46:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Formula1 is not loading on Fri, 18 Nov 2016 08:33:26 GMT]]></title><description><![CDATA[<p dir="auto">Today, i reboot my mirror and i was amazed. The module was loading…<br />
]]></description><link>https://forum.magicmirror.builders/post/8151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8151</guid><dc:creator><![CDATA[viper-sg2]]></dc:creator><pubDate>Fri, 18 Nov 2016 08:33:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Formula1 is not loading on Thu, 17 Nov 2016 23:57:46 GMT]]></title><description><![CDATA[<p dir="auto">Strange - Just got it back.</p>
<p dir="auto">I removed all parameters in the config - so just used the defaults.</p>
]]></description><link>https://forum.magicmirror.builders/post/8144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8144</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Thu, 17 Nov 2016 23:57:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Formula1 is not loading on Thu, 17 Nov 2016 22:28:04 GMT]]></title><description><![CDATA[<p dir="auto">I’m getting that too - not loading.</p>
<pre><code>0|mm       |     at Function.Module._load (module.js:403:25)
0|mm       |     at Module.require (module.js:483:17)
0|mm       |     at require (internal/module.js:20:19)
0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Formula1/node_helper.js:33:24)
0|mm       |     at Socket.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:98:10)
0|mm       |     at emitTwo (events.js:106:13)
0|mm       |     at Socket.emit (events.js:191:7)
0|mm       |     at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:348:8) code: 'MODULE_NOT_FOUND' }
]]></description><link>https://forum.magicmirror.builders/post/8135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8135</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Thu, 17 Nov 2016 22:28:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Formula1 is not loading on Wed, 16 Nov 2016 12:17:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/viper-sg2" aria-label="Profile: viper-sg2">@<bdi>viper-sg2</bdi></a> the module should print a lot of messages if it fails, check your console (where you start the mirror) or pm2 logs</p>
]]></description><link>https://forum.magicmirror.builders/post/8038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8038</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 16 Nov 2016 12:17:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Formula1 is not loading on Wed, 16 Nov 2016 08:24:51 GMT]]></title><description><![CDATA[<p dir="auto">OK, that’s strange :( did i need to configure something else? Set Up the api somewhere? Or is it possible to activate an error log?<br />
my steps:</p>
<ul>
<li>clone the repo to MagicMirror/modues/MMM-Formula1</li>
<li>copy/setup the config from MM, like above</li>
</ul>
<p dir="auto">Every other module works fine, like “Soccer-standings” for example.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/8029</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8029</guid><dc:creator><![CDATA[viper-sg2]]></dc:creator><pubDate>Wed, 16 Nov 2016 08:24:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Formula1 is not loading on Tue, 15 Nov 2016 21:40:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/viper-sg2" aria-label="Profile: viper-sg2">@<bdi>viper-sg2</bdi></a> those settings are working for me</p>
]]></description><link>https://forum.magicmirror.builders/post/8002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8002</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Tue, 15 Nov 2016 21:40:12 GMT</pubDate></item></channel></rss>
