<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Noob need support for MM2 Update to 2.2.2]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
based on my issue with the Wunderground API which is still expired I would like to install the DarkSkyForecast weather module which requires version MM 2.2.2 as a minimum. How can I update the system? The target is only the update without reinstalling or configuring my modules?<br />
Thanks Chris</p>
]]></description><link>https://forum.magicmirror.builders/topic/9964/noob-need-support-for-mm2-update-to-2-2-2</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 18:35:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9964.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Mar 2019 15:16:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Thu, 07 Mar 2019 00:31:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> said in <a href="/post/53794">Noob need support for MM2 Update to 2.2.2</a>:</p>
<p dir="auto">How can I mark to solved? Sorry…?</p>
<p dir="auto">Click the three vertical dots to the right of your post</p>
]]></description><link>https://forum.magicmirror.builders/post/53814</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53814</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 07 Mar 2019 00:31:31 GMT</pubDate></item><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Wed, 06 Mar 2019 20:33:27 GMT]]></title><description><![CDATA[<p dir="auto">How can I mark to solved? Sorry…?</p>
]]></description><link>https://forum.magicmirror.builders/post/53794</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53794</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 06 Mar 2019 20:33:27 GMT</pubDate></item><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Wed, 06 Mar 2019 17:58:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> cool. Can u mark this solved?</p>
]]></description><link>https://forum.magicmirror.builders/post/53775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53775</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Mar 2019 17:58:21 GMT</pubDate></item><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Wed, 06 Mar 2019 16:23:48 GMT]]></title><description><![CDATA[<p dir="auto">thanks - done and updated to MM ver 2.6.0</p>
]]></description><link>https://forum.magicmirror.builders/post/53770</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53770</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 06 Mar 2019 16:23:48 GMT</pubDate></item><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Wed, 06 Mar 2019 16:11:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> typo</p>
]]></description><link>https://forum.magicmirror.builders/post/53769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53769</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Mar 2019 16:11:14 GMT</pubDate></item><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Wed, 06 Mar 2019 15:55:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> what do you mean with nom install in their folder?</p>
]]></description><link>https://forum.magicmirror.builders/post/53765</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53765</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 06 Mar 2019 15:55:12 GMT</pubDate></item><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Wed, 06 Mar 2019 15:51:39 GMT]]></title><description><![CDATA[<p dir="auto">during npm install I got the following info: npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none was installed.</p>
<p dir="auto">How can I check which version is installed?</p>
]]></description><link>https://forum.magicmirror.builders/post/53764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53764</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Wed, 06 Mar 2019 15:51:39 GMT</pubDate></item><item><title><![CDATA[Reply to Noob need support for MM2 Update to 2.2.2 on Wed, 06 Mar 2019 16:10:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> current MM version is 2.6.0</p>
<p dir="auto">Update, go to the mm folder, do a git pull.  Then npm install, and for any modules w a package.json file do the same, npm install,  in their folder</p>
]]></description><link>https://forum.magicmirror.builders/post/53761</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53761</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Mar 2019 16:10:57 GMT</pubDate></item></channel></rss>
