<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PIR Sensor Install Problems]]></title><description><![CDATA[<p dir="auto">Hey guys,</p>
<p dir="auto">So I am using Cowboydude’s module for the PIR sensor to turn off and on the mirror. Following the instructions here</p>
<p dir="auto"><a href="https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/</a></p>
<p dir="auto">When I typed in “sudo chmod +x <a href="http://pir.py" target="_blank" rel="noopener noreferrer nofollow ugc">pir.py</a>”, it says the directory or file cannot be found. I know it says to install it in the root folder but I do not know how to do that. So I improvised and used sudo mv after installing it into /root. I do not know if that would provide the same results. Could anyone give me some guidance?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9977/pir-sensor-install-problems</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 07:39:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9977.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Mar 2019 00:04:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PIR Sensor Install Problems on Thu, 07 Mar 2019 01:59:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anhanyoung" aria-label="Profile: anhanyoung">@<bdi>anhanyoung</bdi></a> move (mv)  moves  single instance around</p>
<p dir="auto">Copy(cp) make another instance in another location.</p>
<p dir="auto">Depends on what u want to do.</p>
]]></description><link>https://forum.magicmirror.builders/post/53832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53832</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 07 Mar 2019 01:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor Install Problems on Thu, 07 Mar 2019 01:27:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> so i should use cp? i moved it to /root</p>
]]></description><link>https://forum.magicmirror.builders/post/53824</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53824</guid><dc:creator><![CDATA[anhanyoung]]></dc:creator><pubDate>Thu, 07 Mar 2019 01:27:22 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor Install Problems on Thu, 07 Mar 2019 00:08:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anhanyoung" aria-label="Profile: anhanyoung">@<bdi>anhanyoung</bdi></a> said in <a href="/post/53811">PIR Sensor Install Problems</a>:</p>
<p dir="auto">sudo mv after installing it into /roo</p>
<p dir="auto">mv is move… where did you move it to?  if not in root…</p>
<p dir="auto">installing in root is either copy (cp) from somewhere else to / (root)<br />
or editing there with nano, vi, gedit or whatever editor you like or use</p>
<p dir="auto">root is really a bad place…  but easy to find ls /</p>
]]></description><link>https://forum.magicmirror.builders/post/53812</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53812</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 07 Mar 2019 00:08:28 GMT</pubDate></item></channel></rss>
