<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with pm2 (package.json) after installing the first module]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">currently I am building a new MM and have at the beginning unusual problems.<br />
I installed the MM blank and take my old config.js from my old MM. After that the MM starts normally via pm2.<br />
As soon as I installed the first module, the MM does not start anymore via pm2.<br />
The pm2-Logs are</p>
<pre><code>pi@raspberrypi:~ $ pm2 logs MagicMirror
[TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
/home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
0|MagicMir | All module helpers loaded.
0|MagicMir | Starting server on port 8080 ...
0|MagicMir | Server started ...
0|MagicMir | Connecting socket for: calendar
0|MagicMir | Starting node helper for: calendar
0|MagicMir | Connecting socket for: newsfeed
0|MagicMir | Starting module: newsfeed
0|MagicMir | Sockets connected &amp; modules started ...
0|MagicMir | Launching application.
0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/…/…/private-xxxxxxxxxx/basic.ics - Interval: 300000
0|MagicMir | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
0|MagicMir | Shutting down server...
0|MagicMir | Stopping module helper: calendar
0|MagicMir | Stopping module helper: newsfeed
/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | { Error: ENOENT: no such file or directory, open 'package.json'
0|MagicMir | at Object.fs.openSync (fs.js:660:18)
0|MagicMir | at Object.fs.readFileSync (fs.js:565:33)
0|MagicMir | at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/app.js:15:32)
0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:654:30)
0|MagicMir | at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
0|MagicMir | at Module.load (internal/modules/cjs/loader.js:566:32)
0|MagicMir | at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:498:3)
0|MagicMir | at Module.require (internal/modules/cjs/loader.js:598:17)
0|MagicMir | at require (internal/modules/cjs/helpers.js:11:18)
0|MagicMir | errno: -2,
0|MagicMir | code: 'ENOENT',
0|MagicMir | syscall: 'open',
0|MagicMir | path: 'package.json' }
<p dir="auto">When the MM start via pm2 the package.json file seems to be corrupt. When I start with DISPLAY =: 0 it works.</p>
<p dir="auto">I would be grateful if someone could help me.</p>
<p dir="auto">Thanks in advance.</p>
]]></description><link>https://forum.magicmirror.builders/topic/9979/problem-with-pm2-package-json-after-installing-the-first-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 11:01:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9979.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Mar 2019 10:33:31 GMT</pubDate><ttl>60</ttl></channel></rss>
