<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adjust the brightness of the MagicMirror]]></title><description><![CDATA[<p dir="auto">Is there a way to increase and save the brightness of the MagicMirro?</p>
]]></description><link>https://forum.magicmirror.builders/topic/9990/adjust-the-brightness-of-the-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 02:33:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9990.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Mar 2019 09:02:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adjust the brightness of the MagicMirror on Mon, 11 Mar 2019 05:07:20 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I will do it. Many Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/54062</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54062</guid><dc:creator><![CDATA[CyruS1337]]></dc:creator><pubDate>Mon, 11 Mar 2019 05:07:20 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust the brightness of the MagicMirror on Sun, 10 Mar 2019 18:10:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyrus1337" aria-label="Profile: CyruS1337">@<bdi>CyruS1337</bdi></a><br />
That’s weird because it doesn’t happen to me. Try conatct the author of the module. He may give you more help.</p>
]]></description><link>https://forum.magicmirror.builders/post/54034</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54034</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Sun, 10 Mar 2019 18:10:21 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust the brightness of the MagicMirror on Fri, 08 Mar 2019 13:21:58 GMT]]></title><description><![CDATA[<p dir="auto">Actually, yes, I slide the slider all the way to the right and go left to save. But somehow this is always lost</p>
]]></description><link>https://forum.magicmirror.builders/post/53931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53931</guid><dc:creator><![CDATA[CyruS1337]]></dc:creator><pubDate>Fri, 08 Mar 2019 13:21:58 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust the brightness of the MagicMirror on Fri, 08 Mar 2019 12:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyrus1337" aria-label="Profile: CyruS1337">@<bdi>CyruS1337</bdi></a><br />
Do you save your settings? If you don’t they won’t appear after a reboot. In my MM everytime I restart it or the pi after MM reloads I get my last settings from remote control.</p>
]]></description><link>https://forum.magicmirror.builders/post/53925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53925</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Fri, 08 Mar 2019 12:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust the brightness of the MagicMirror on Fri, 08 Mar 2019 11:57:59 GMT]]></title><description><![CDATA[<p dir="auto">I installed this module on only three PI’s and already tried to adjust the brightness. But after each reboot, the storage of the brightness is lost.</p>
]]></description><link>https://forum.magicmirror.builders/post/53923</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53923</guid><dc:creator><![CDATA[CyruS1337]]></dc:creator><pubDate>Fri, 08 Mar 2019 11:57:59 GMT</pubDate></item><item><title><![CDATA[Reply to Adjust the brightness of the MagicMirror on Fri, 08 Mar 2019 11:00:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyrus1337" aria-label="Profile: CyruS1337">@<bdi>CyruS1337</bdi></a><br />
I don’t know if there is another way but I made it by instlling <a href="https://github.com/Jopyth/MMM-Remote-Control" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-RemoteControl</a> where you can control our MM from your mobile or pc via web browser. With this module you can show/hide  modules and abjust the brightness and save it too. I hope this will help you.</p>
]]></description><link>https://forum.magicmirror.builders/post/53921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53921</guid><dc:creator><![CDATA[Anthony]]></dc:creator><pubDate>Fri, 08 Mar 2019 11:00:09 GMT</pubDate></item></channel></rss>
