<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2 Calendar modules do not line up]]></title><description><![CDATA[<p dir="auto">Any idea why these 2 calendar modules do not properly line up on the left? Note that the top one is a combination of 2 gmail and 1 work calendar and the bottom one is a iCloud calendar. But I do not see how that could possible matter. For some reason the 2nd calendar data is pushed to the left about 10px.</p>
<p dir="auto"><img src="/assets/uploads/files/1552080068348-screen-shot-2019-03-08-at-3.18.20-pm.png" alt="0_1552080067992_Screen Shot 2019-03-08 at 3.18.20 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/9998/2-calendar-modules-do-not-line-up</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 15:09:01 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/9998.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Mar 2019 21:22:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2 Calendar modules do not line up on Wed, 10 Mar 2021 13:26:39 GMT]]></title><description><![CDATA[<p dir="auto">@mr-fliffer<br />
I never resolved the problem either. I went ahead and just used a single module for my purposes.</p>
]]></description><link>https://forum.magicmirror.builders/post/89353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89353</guid><dc:creator><![CDATA[mlcampbe]]></dc:creator><pubDate>Wed, 10 Mar 2021 13:26:39 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Calendar modules do not line up on Tue, 09 Mar 2021 20:01:38 GMT]]></title><description><![CDATA[<p dir="auto">Hey mlcampbe,<br />
i have the same issue at my MM, but no idea how to fix this. I set up different time formats for different urls. But how can this effect the allignment of the left side?.</p>
]]></description><link>https://forum.magicmirror.builders/post/89347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89347</guid><dc:creator><![CDATA[Mr.Fliffer]]></dc:creator><pubDate>Tue, 09 Mar 2021 20:01:38 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Calendar modules do not line up on Thu, 18 Apr 2019 21:05:31 GMT]]></title><description><![CDATA[<p dir="auto">Actually no this has not fixed itself. It keeps coming back. I think it has to do with the time element on the righthand side.</p>
<p dir="auto">Note that this is 2 different calendar modules running 1 - for myself and 1 for my wife. What I believe is happening is that when the time contains the string “Tomorrow at xx” or “Saturday at xx” in 1 of the calendars but not the other then the DIV and SPAN elements get pushed around causing the indention to get messed up.</p>
<p dir="auto">If I put all of the calendar info into a single module then there are no problems.</p>
<p dir="auto">Has anyone else seen this and if so how do you fix it?</p>
]]></description><link>https://forum.magicmirror.builders/post/56156</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56156</guid><dc:creator><![CDATA[mlcampbe]]></dc:creator><pubDate>Thu, 18 Apr 2019 21:05:31 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Calendar modules do not line up on Mon, 11 Mar 2019 21:19:37 GMT]]></title><description><![CDATA[<p dir="auto">Seems this has taken care of itself. I suspect that the overall length of something was causing the issue but not sure what it was.</p>
]]></description><link>https://forum.magicmirror.builders/post/54115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54115</guid><dc:creator><![CDATA[mlcampbe]]></dc:creator><pubDate>Mon, 11 Mar 2019 21:19:37 GMT</pubDate></item></channel></rss>
