Nice! Don’t forget to add it to the module list 🙂
Module Developers
You have developed a module for the MagicMirror? Join the group and get a "Module Developer" badge!
RE: MMM-ModulesGroupsRotation - simple alternative to MMM-pages
Nice. Don’t forget to add it to the module list 🙂
Did you also gave MMM-Carousel a chance?
RE: Lego MM
@elisa Neat. I’d be worried about loosening structure over time, but, nice,
RE: Wyze Cams
@robertjunior24 the problem is that RTSP isn’t supported by Web protocals.
Here’s what I’m currently doing for my Reolink cameras:
I use an PI 4 with Motion Eye OS (Discontinued, but still kinda works, there is betas of an attempt to bring MotionEye back) to convert the RTSP streams to Web streams. Then using MMM-EmbedURL, I’m able to pick up the web streams to use on my mirror.
What I’d like to do is use something faster and more reliable - (Scrypted?) to do the conversion. Currently, there’s a lag that will form within the motioneye software, so I tend to reboot the pi once an hour (overdone, but it works) to keep it reasonable.
If I use the Framed version of the URLs that MotionEyeOS provides me (like
http://192.168.0.7/picture/2/frame/
) - I don’t have to have MMM-Embed URL reset the picture, the system will provide a temporary “No Camera” image while it’s down.+Important note: Pi 5 (and newer, eventually) will NOT run what’s required for the old software, so Pi4 is what’s recommended.
RE: MMM-SynologySurveillance
@wishmaster270 and through use of an old pi for MotionEyeOS, I use it to embed a near-direct stream from my Reolink cameras. :)
RE: MMM-CalendarExt2 not working
@veny Ahh, ext3agenda has a minimonth display, or if you’d like another take on it, my module, MMM-Multimonth does another style of mini calendar display. Both use the very same calendar base, and both will be supported.
Lots of options for better supported calendar operations. Please take a look at the 3rd Party modules in the title bar above. The List icon " " will lead the way.
@m3iaz Hi,
the Reolink cams provide a fluent and a high quality stream.
You can select three different stream types in the Surveillance Station. The MJPEG stream is generated of the one for reduced speed which in my setup is the fluent stream of the Reolink cam.
I can select a 640x stream in my Reolink but it may depend of the camera.I do not have much time to program at the moment but you may checkout my EmbedURL module. It is able to embed images and a refresh rate can be configured. Some people use it to embed JPEG of public webcams already.
@veny I see you’re using google. They may have discontinued the access methods used within Ext2. You should upgrade to Ext3.
RE: MMM-OpenWeatherForecast - for daily forecast, can the first day displayed be today instead of tomorrow?
@atltiger81 In that case, I’d use something like MMM-ProfileSwitcher and switch between two configs of the module on a timed basis.
I currently have that set up with my cameras so that I can cycle through the cameras.
@atltiger81 that’s what the hourly forecast is for… The next 24 hours as frequent as you have it set.
