    MMM-Remote-Control
    11 Posts 3 Posters 5.1k Views 3 Watching
    • Y Offline
      yorickmolema
      Hello,
      I have a problem with the remote control of the MM. I have it up and running, but I can’t edit the view in the browser on any device. Any help?
      > magicmirror@2.7.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.7.1
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-NowPlayingOnSpotify.
      No helper found for module: MMM-SmartWebDisplay.
      Module helper loaded: MMM-Remote-Control
      No helper found for module: phone_notification.
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/p6u2bqfvvaio8srmslosp192ads3ot45%40import.calendar.google.com/public/basic.ics - Interval: 300000
      Create new news fetcher for url: https://www.nu.nl/rss/Algemeen - Interval: 300000
      Create new news fetcher for url: https://www.nu.nl/rss/Internet - Interval: 300000
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/yorickmolema%40gmail.com/private-65a92b2f70cf000d5254428a6bc5fdf9/basic.ics - Interval: 300000
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/c3e3hs5p6e569ge27fk5c8joks%40group.calendar.google.com/private-49bb398870c9b92031f815bf7563c766/basic.ics - Interval: 300000
      Not initialized, have you opened or refreshed your browser since the last time you started MagicMirror?
      In the browser i get the same pop-up. I have added my ip-address to the whitelist so i can acces it. The only thing I can’t do is edit the view.
      • Y Offline
        yorickmolema
        This is my config:
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
         //address: "localhost", // Address to listen on, can be:
         address: "0.0.0.0",
        	port: 8080,
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.123.X"], // Set [] to allow all IP addresses
        	language: "nl",
        	timeFormat: 24,
        	units: "metric",
        			module: "newsfeed",
        			position: "top_bar",
        				feeds: [
        						title: "Nu.nl",
        						url: "https://www.nu.nl/rss/Algemeen"
        						title: "Nu.nl",
        						url: "https://www.nu.nl/rss/Internet"
        				showSourceTitle: false,
        				showPublishDate: false
        			module: "clock",
        			position: "top_left"
        		module: 'MMM-SmartWebDisplay',
        		position: 'middle_center',	// This can be any of the regions.
        			logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
        			height:"100%", //hauteur du cadre en pixel ou %
        			width:"100%", //largeur
                       		updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
                        	NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                        	displayStateInfos: false,	//to display if the module is on autoloop, or stop.
                        	displayLastUpdate: true, //to display the last update of the URL
        			displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                        	url: [""], //source of the URL to be displayed
                        	scrolling: "no" // allow scrolling or not. html 4 only
        	        module: 'MMM-Remote-Control',
        	        // uncomment the following line to show the URL of the remote control on the mirror
        	        // , position: 'bottom_left'
        	        // you can hide this module afterwards from the remote control itself
        		position: "bottom_left",
        	          customCommand: {},  // Optional, See "Using Custom Commands" below
        	        customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
        	        showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                	apiKey: "",         // Optional, See API/README.md for details
        			module: "currentweather",
        				locationID: "2750947",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "c3494d09f5358b30a53a3167af88d38d"
        			module: "weatherforecast",
        			header: "Weather Forecast",
        			module: "compliments",
        			position: "",	// This can be any of the regions.
        										// Best results in one of the middle regions like: lower_third
        				compliments: {
        					day_sunny: [
        						"Today is a sunny day",
        						"It's a beautiful day"
        					snow: [
        						"Snowball battle!"
        					rain: [
        						"Don't forget your umbrella"
        					anytime: [
        						"Hey there sexy!"
        					morning: [
        						"Good morning, handsome!",
        						"Enjoy your day!",
        						"How was your sleep?",
        						"Good morning, sunshine!",
        					        "Who needs coffee when you have your smile?",
               						"Go get 'em, Tiger!"
        					afternoon: [
        						"Hello, beauty!",
        						"You look sexy!",
        						"Looking good today!",
        					        "Hitting your stride!",
        					        "You are making a difference!",
                					"You're more fun than bubble wrap!"
        					evening: [
        						"Wow, you look hot!",
        						"You look nice!",
        						"Hi, sexy!",
        						"You made someone smile today, I know it.",
        					        "You are making a difference.",
                					"The day was better for your efforts."
        • Y Offline
          yorickmolema
          This post is deleted!
          • T Offline
            teitlebot @yorickmolema
            @yorickmolema
            Having the same issue. any luck?
            • Y Offline
              yorickmolema @teitlebot
              @teitlebot Nope, I have updated all the software on my pi, but that didn’t help.
              • T Offline
                @yorickmolema It actually fixed itself by me but im not sure what I did. It tried moving things around in the config file but not sure what else. I also dont get my IP address on screen but thats a separate issue.
                • Y Offline
                  @teitlebot Can you send your config?
                  • Y Offline
                    yorickmolema
                    If I click away the error and press save I get the following error in the terminal where I started MM:
                    undefined
                    TypeError: Cannot read property 'length' of undefined
                        at Class.saveDefaultSettings (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:898:44)
                        at Object.callback (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:679:56)
                        at Object.run (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:547:26)
                        at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:555:28)
                        at ontimeout (timers.js:427:11)
                        at tryOnTimeout (timers.js:289:5)
                        at listOnTimeout (timers.js:252:5)
                        at Timer.processTimers (timers.js:212:10)
                    • T Offline
                      @yorickmolema
                       * MIT Licensed.
                      var config = {
                      	address: "0.0.0.0", // Address to listen on, can be:
                      	port: 8080,
                      	ipWhitelist: ["127.0.0.1", "192.168.1.1/24"],
                      	language: "en",
                      	timeFormat: 12,
                      	units: "imperial",
                      			module: "alert",
                      disabled: true,
                      disabled: false,
                          position: 'bottom_left',
                      • Y Offline
                        @teitlebot I have the following config now:
                        /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                        var config =
                          address: '0.0.0.0',
                          electronOptions: {},
                          ipWhitelist: ['127.0.0.1','::ffff:127.0.0.1','::1', '192.168.123.26','192.168.123.28','192.168.123.25',],
                          language: 'nl',
                        	disabled: false,
                        		customCommand: {},
                        		customMenu: 'custom_menu.json',
                        		showModuleApiMenu: 'true',
                        		apikey: '',
                        		module: "newsfeed",
                        		position: "bottom_bar",	// This can be any of the regions. Best results in center regions.
                        			// The config property is optional.
                        			// If no config is set, an example calendar is shown.
                        			feeds: [
                        					title: "New York Times",
                        					url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                        					title: "BBC",
                        					url: "http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk",
                          paths: {
                            modules: 'modules',
                            vendor: 'vendor'
                        And it doesn’t work yet. I couldn’t copy your config cause then i got an error that the text editor wouldn’t save it.
                          seso
                          Hi @teitlebot , please can you share your config file as i am tried to edit mine to bypass the problem and can’t figure it out
