    Simple Text that reads a .txt file
    15 Posts 2 Posters 5.9k Views 2 Watching
      Jackkt
      Hey,
      So I have a python script that uses facial recognition and prints out the name of the person. I want this to display on the magic mirror. Guidance on how to do it would be welcome as well.
        sdetweil @Jackkt
        @Jackkt you need to use the node_helper module to launch your python script, and capture the output of the python script… then send that up to the module.js via sendSocketNotification…
        then the module needs to signal updateDom() to tell MM there is new content, and it will call back at getDom() to get the new content, where u format your html to be shown.
        node_helper
        const { exec } = require('child_process');
        exec('python your_script', (error, stdout, stderr) => {
          if (error) {
            console.error(`exec error: ${error}`);
            return;
          console.log(`stdout: ${stdout}`);
           this.sendSocketNotification('some id string', stdout);
          console.log(`stderr: ${stderr}`);
        module.js
           if( notification ==='some id string') {
           var save_payload=payload)
           this.updateDom(1000)
        getDom: function (){
           create the html here using save_payload)
           return created_html
           MM will inject the html in the div for your module
        you can use my sample module for starters…
        https://github.com/sdetweil/SampleModule
        check out the difference between exec (one time) and spawn (send multiple responses over time)
          Jackkt @sdetweil
          @sdetweil Thanks for the response. Im having trouble making the module(I have no experience and the "Head first developing MM module for extreme beginner"didnt work). Also The python script can run in the background and can output into a .txt file. Can I just edit helloworld to just print the thing in the text file? Sorry if this is stupid.
            Jackkt @Jackkt
            @Jackkt Also the text file updates every 5 seconds by the results of the python script
              sdetweil @Jackkt
              @Jackkt if the python script can be changed to just write to the screen, you can use spawn instead. And it can send u info every time it writes
                Jackkt @sdetweil
                @sdetweil Hey, I get a syntax error from “const { exec } = require(‘child_process’); unexpected token {” its the one before exec. Get the same from spawn.
                  Jackkt @Jackkt
                  @Jackkt Also without the {} the error is “unexpected identifier” for
                  “spawn”
                    sdetweil @Jackkt
                    @Jackkt that leading quote shouldn’t be there
                      Jackkt @sdetweil
                      @sdetweil I was just quoting sorry it looks like:
                      and
                      const exec = require(‘child_process’);
                        sdetweil @Jackkt
                        @Jackkt ok. I just cut/pasted it from a working module.
                        When posting code or config in the forum, please use the markup syntax. 3 backticks (key left of number 1) before your content on a separate line
                        And 3 more after on a separate line
                        S J 2 Replies Last reply Reply Quote 1
                          @sdetweil also, it doesn’t just go anywhere… I didn’t give u exact code, but close
                            Jackkt @sdetweil
                            @sdetweil What module was that working module? Sorry im just not good at this stuff so I rather cut down a working module then make my own.
                              sdetweil @Jackkt
                              @Jackkt I don’t remember. I am away til Sunday.
                                sdetweil @Jackkt
                                @Jackkt come to the discord chat and I will post you a zip file with a display of repeating data from a background python process. I am sam, $5710
                                  Jackkt
                                  It works, thank you soo much.
