    Problems with calender and Nextcloud
    44 Posts 6 Posters 24.4k Views 6 Watching
      sdetweil @Pakmann
      @Pakmann I got no clue… we are using the latest request module (2.88.0)
      it does say special parms required for SSL 3 (and there is currently no way to pass something like this into be used)
      https://www.npmjs.com/package/request#tlsssl-protocol
      I do see in the calendar code, setup for the request id info
      	"User-Agent": "Mozilla/5.0 (Node.js "+ nodeVersion + ")
      • C Offline
        Corin Corvus
        Hey,
        3 month later and no solution?
        i tried with newest version. wget nextcloud_calender_url get the calender in special format. The Name is “7863TJr9N2JJRgfG?export” and not *.ics.
        i tried official documentation. Add i “auth” with copy and paste, i get a config error.
        in the newest build of Nextcloud i can copy a abo-link. i can download the “.ics” with this link without credentials.
        how i can use it for mm calender? its a puplic calender link now but i dont get any calender infos.
        my config:
        	header: "Kalender", // see help for more information
        		colored: true,
        		coloredSymbolOnly: false,
        				url: 'https://domain.tld/nextcloud/remote.php/dav/public-calendars/7812hello1232JJRgfG?export',
        				symbol: 'calendar'
          sdetweil @Corin Corvus
          @Corin-Corvus said in Problems with calender and Nextcloud:
          that url doesn’t work here… domain.tld not found
          no one interested in looking at the code to fix it… this is all volunteer…
          if u have the ics file,
          copy the ics file into the default calendar folder
          the url would then be
          file:///home/pi/MagicMirror/modules/default/calendar/???.ics
            jacktar
            Ok, I realise it’s been a while but, for the sake of other who might hit this problem (or one like it), us Nextcloud users are generally using it because we’re security-conscious and like to keep our data private.
            If you’re like me, you might have enabled 2FA which means if you enter your ‘usual’ password in your config file, you can’t then enter your second authentication method.
            If this is the case, you’ll need to create a ‘one-time’ password in Nextcloud and use this instead of your ‘normal’ password. Get one by going to Nextcloud settings, Security and scroll to bottom. Hit ‘Create new app password’ and copy to the URL in the config.
            • 5 / 5
