    MMM-Fuel error ECONNREFUSED
    12 Posts 2 Posters 3.5k Views 2 Watching
      db1mso
      Can`t connect to tankerkoenig.
      Hello, this is my first try to use MMM-Fuel. Dependencies already installed with npm install
      I get this error every seconds in the MM-Logfile:
      0|MagicMirror | { FetchError: request to https://creativecommons.tankerkoenig.de/json/list.php?lat=47.551609&lng=10.251099&rad=3&type=all&apikey=API_KEY&sort=dist failed, reason: connect ECONNREFUSED 188.68.35.147:443
      0|MagicMirror | at ClientRequest. (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/node-fetch/lib/index.js:1455:11)
      0|MagicMirror | at ClientRequest.emit (events.js:182:13)
      0|MagicMirror | at TLSSocket.socketErrorListener (_http_client.js:382:9)
      0|MagicMirror | at TLSSocket.emit (events.js:182:13)
      0|MagicMirror | at emitErrorNT (internal/streams/destroy.js:82:8)
      0|MagicMirror | at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
      0|MagicMirror | at process._tickCallback (internal/process/next_tick.js:63:19)
      0|MagicMirror | message:
      0|MagicMirror | ‘request to https://creativecommons.tankerkoenig.de/json/list.php?lat=47.123456&lng=10.123456&rad=3&type=all&apikey=API_KEY&sort=dist failed, reason: connect ECONNREFUSED 188.68.35.147:443’,
      0|MagicMirror | type: ‘system’,
      0|MagicMirror | errno: ‘ECONNREFUSED’,
      0|MagicMirror | code: ‘ECONNREFUSED’ }
      The URL works just fine in a Browser and shows up the Gas-Stations near to me.
      My config file:
      			module: "MMM-Fuel",
      			disabled: false,
      				provider: "tankerkoenig",
      				api_key: "API_KEY",
      				lat: 47.123456,
      				lng: 10.123456,
      				types: ["e5"],
      				sortBy: "e5",
      				radius: 3,
      				max: 3,
      				updateInterval: 15,
      Thanks for any hint.
      Sincerly Olli
        sdetweil @db1mso
        @db1mso i used your url string above (with the fake api_key), and i got a good string back, says ‘bad api_key’
        {“status”:“error”,“ok”:false,“message”:“apikey nicht angegeben, falsch, oder im falschen Format”
        D 3 Replies Last reply Reply Quote 0
          db1mso @sdetweil
          @sdetweil sorry i can`t fully reply. AKISMET SPAM :-(
          Sincerly Olli
            db1mso @sdetweil
            @sdetweil Thanks for testing.
            Yes, the url works perfekt in a Browser - but not in MMM-Fuel.
            Best of all: it works perfekt and show up in MM.
            Maybe it runs too often and was rejected by tankerkoenig.de. The Logfile from tankerkoenig API shows up the massive requests --i can’t append the logfile–
            UpdateInterval: 15 says 15 Minutes - right?
            Sincerly Olli
              db1mso @sdetweil
              Sincerly Olli
                sdetweil @db1mso
                @db1mso but your apikey=“API_KEY” is the wrong info
                you need to register on the site to get a key that allows you to connect
                my api=_key looks like this
                b0f70ce4-6ac6-bbed-67fd-225db01208be
                  db1mso @sdetweil
                  @sdetweil i never publish my own API_KEY :winking_face:
                  As i mentioned before, the url (with the right key in it) works perfekt in a Browser.
                  Sincerly Olli
                    sdetweil @db1mso
                    @db1mso ok, those requests are returning rc=200, which is good.
                    the apikey shown doesn’t work, as I modified the numbers.
                      db1mso @sdetweil
                      @sdetweil modifiying is another method :winking_face:
                      I think the problem was the number of request at a time. There list up to 9 Request at the same Timestamp.
                      EDIT: Error found by myself!
                      The value for UpdateInterval must set to 900000 //15min
                      RTFM!
                      Thanks for your time!
                      Sincerly Olli
                        sdetweil @db1mso
                        @db1mso cool… the doc doesn’t say MUST… but the code allows something shorter…
                        I opened an issue on MMM-Fuel
                        https://github.com/fewieden/MMM-Fuel/issues/38
                          db1mso @sdetweil
                          @sdetweil Thanks!
                          The option UpdateInterval is optional.
                          Anyway. Shorter than 5 min makes no sense because the database on tankerkoenig updates every 4 min.
                          Sincerly Olli
                            sdetweil @db1mso
                            @db1mso said in MMM-Fuel error ECONNREFUSED:
                            understood… but if shorter causes an error, then the module should enforce the minimum
