    How can I update my chart?
    21 Posts 3 Posters 8.8k Views 3 Watching
      doridol
      I want to update my chart without getDom(), other people use Mychart.update() How can I use it?? please help korean noob…
      My module code
      Module.register("MMM-Chart", {
              defaults: {
                  updateInterval: 3000,
              getScripts: function () {
                  return ["modules/" + this.name + "/node_modules/chart.js/dist/Chart.min.js"];  // use right file name
              start: function () {
                  // Log.info("Starting module: " + this.name);
                  // requiresVersion: "2.1.0";
                  // this.loaded = false
                  this.scheduleUpdate();
                  // this.config = Object.assign({}, this.defaults, this.config);
              scheduleUpdate: function () {
                  setInterval(() => {
                      this.getData();
                  this.config.updateInterval);
                  this.getData();
              getData: function() {
                  this.sendSocketNotification('GET_TEXT_DATA', this.config);
              socketNotificationReceived: function (notification, payload) {
                  if (notification === "TEXT_RESULT") {
                      this.textDataRecived = payload;
                      this.loaded = true;
                  this.myChart.data.datasets.push([{
                      data: this.textDataRecived,
                      backgroundColor: 'rgba(255,255,255,0.3)',
                      borderColor: 'white',
                      borderWidth: 2,
                      fill: true,
              getDom: function () {
                  const wrapper = document.createElement("div");
                  this.ctx = document.createElement("canvas");
                  this.ctx.style.width = "700px";
                  this.ctx.style.height = '700px';
                  wrapper.appendChild(this.ctx)
                  labels = [2,4,6,8]
                  this.myChart = new Chart(this.ctx, {
                      type: 'line',
                      data: {
                          labels: labels,
                          datasets: [{
                              borderWidth: 2,
                              fill: true,
                      options: {
                          title: {
                                  display: true,
                                  text: 'Air-Quality',
                          scales: {
                              xAxes: [{
                                  gridLines: {
                                      color: 'rgba(255,255,255,0.2)',
                  return wrapper;
      My node_helper.js code
      const spawn = require('child_process').spawn;
      const NodeHelper = require("node_helper");
      var self;
      i = 1;
      a = 1;
      b = 1;
      c = 1;
              self = this;
              console.log("Starting node_helper for: " + this.name);
          getData: function () {
              // const result = spawn('python', ['/home/pi/MagicMirror/modules/MMM-Chart/Dust_Db.py']);
              // result.stdout.on('data', function(data) {
              //     recivedData = data.toString();
              //     recivedData = recivedData.split(/[^0-9]/g)
              //     for (var i in recivedData) {
              //         if (recivedData[i] == '') {
              //             recivedData.splice(i, 1)
              //     // console.log(recivedData)
              //     self.sendSocketNotification('TEXT_RESULT', recivedData);
              // process.on('exit', function() {
              // if (x) {
              //     x.kill();
              recivedData = [i, a, b, c];
              i = i + 1
              a = a + 3
              b = b + 7
              c = c + 2
              if (notification === 'GET_TEXT_DATA') {
                  self.getData();
        sdetweil @doridol
        @doridol this.mychart.update()?
          doridol @sdetweil
          Yes Yes it seems like other people use it. I’ve also tried to change my chart data with this.myChart.data.datasets.data.push(textDataRecived) in socketNotificationReceived but it doesn’t work…
          How can I update myChart data in the socketNotificationReceived function?
            sdetweil @doridol
            @doridol said in How can I update my chart?:
            it should work. you might need to check if ‘this’ is pointing to your module data. use the developers window sources view and put a stop on the notification routine
              doridol @sdetweil
              I changed socketNotificationReceived like this
                              this.loaded = true;
                          this.myChart.data.datasets.data.push(this.textDataRecived)
                          this.myChart.update();
                          // this.updateDom(60000);
              And I got error like these
                sdetweil @doridol
                @doridol stop on the push, and mouse over ‘this’
                check each part of your data path
                  doridol @sdetweil
                  @sdetweil I’m so sorry that I asked same question twice although you answered my questions.
                  I found that this.myChart in socketNotificationReceived doens’t pointing the this.myChart in getDom how can I point this.myChart in socketNotificationReceived exactly to this.myChart in getDom??
                    sdetweil @doridol
                    @doridol try
                    change
                    to this
                    socketNotificationReceived:  (notification, payload) => {
                    the arrow function should retain the context of ‘this’.
                      doridol @sdetweil
                      @sdetweil I changed my socketNotificationReceived like this
                                      this.loaded = true;
                                  console.log(this.myChart)
                                  // this.myChart.data.datasets.data = this.textDataRecived
                      I add console.log(this.myChart) to check it point this.myChart in getDom but it print undefined… what did I do wrong??
                      Really thanks for your so many helps
                        sdetweil @doridol
                        @doridol the 1st time thru the chart doesn’t exist yet, right?
                                        // gets the data for chart
                                        this.loaded = true;
                                    // chart may NOT be drawn yet
                                   // getDom has not been called yet since data arrived
                                   if(this.myChart !==  undefined )
                          doridol @sdetweil
                          @sdetweil aaaaah!! I understood! I’ll try it
                            doridol @sdetweil
                            @sdetweil I tried it but nothing is printed in develop console window :anxious_face_with_sweat:
                              sdetweil @doridol
                              @doridol did u get an update for the chart? (another socketnotification?)
                              also, where do u define myChart?
                              should be after defaults
                              myChart: null,
                                doridol @sdetweil
                                @sdetweil I define myChart in getDom like this
                                            labels = [2,4,6,8]
                                                type: 'line',
                                                data: {
                                                    labels: labels,
                                                    datasets: [{
                                                        data: [1,2,3,4],
                                                        borderWidth: 2,
                                                        fill: true,
                                                options: {
                                                    title: {
                                                            display: true,
                                                    scales: {
                                                        xAxes: [{
                                                            gridLines: {
                                            return wrapper;
                                and I’ll only update myChart in socketNotificationReceived
                                  sdetweil @doridol
                                  @doridol that is USE, not really define
                                  I don’t like side effects… create on 1st use… ugh.
                                  also, you will UPDATE in notification, but need to CREATE in getdom, or somewhere
                                    doridol @sdetweil
                                    @sdetweil oh… it is very difficult to update chart… really thanks for your help I seem I have to study more…
                                      doridol @sdetweil
                                      @sdetweil I have really really last question I changed my socketNotificationReceived like this
                                                      this.loaded = true;
                                                  if(count < 2)
                                                      this.updateDom();
                                                      count = count + 1;
                                                  else
                                                      console.log(this.myChart.data.datasets.data)
                                      and console.log(this.myChart.data.datasets.data) successfully print this.textDataRecived but my chart is not updated in the screen why???
                                        sdetweil @doridol
                                        @doridol i do not know anything about the chart.update() method… I don’t use it.
                                          doridol @sdetweil
                                          @sdetweil okay thanks for you a lot of help:beaming_face_with_smiling_eyes:
                                            sdetweil @doridol
                                            @doridol i use destroy() and then build another
