    Black screen after adding modules.
    13 Posts 2 Posters 2.7k Views 3 Watching
    • L Offline
      ljhig
      Hi all,
      Forgive my inept attempt to explain the problems I’m encountering, I have every intention to learn.
      I am using a Pi 3b with a clean install from a noobs SD.
      I installed MagicMirror following the website instructions and the default config works fine. Because of my screen size I wanted to edit the layout to cycle modules in the centre whilst keeping the clock and compliments static.
      I have added the modules following instructions and included them in the config file, yet when I run the Magic Mirror I get a black screen.
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	zoom: 0.9,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-UK",
      	timeFormat: 24,
      	units: "metric",
                              module: 'MMM-Carousel',
                                      transitionInterval: 20000,
                                      ignoreModules: [],
                                      mode: 'positional',
                                      middle_centre: {enabled: true}
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_centre"
      			module: "compliments",
      			position: "bottom_centre"
                              module: 'MagicMirror-QuoteCatalog',
                              header: 'The Quote Catalog',
                              position: 'middle_centre',
                                      timeFormat: 3600
                              module: "MMM-NowPlayingOnSpotify",
                              position: "middle_centre",
                                      clientID: "removed for post",
                                      clientSecret: "removed for post",
                                      accessToken: "removed for post ",
                                      refreshToken: "removed for post"
      			module: "weather",
      				type: "current",
      				locationID: "2644210", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "removed for post"
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      Apologies if it’s sloppy I’m working on an iPad using VNC.
      pi@raspberrypi:~/MagicMirror $ npm run start
      npm WARN npm npm does not support Node.js v10.24.0
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
      npm WARN npm You can find the latest version at https://nodejs.org/
      > magicmirror@2.16.0 start /home/pi/MagicMirror
      [03.10.2021 12:05.53.187] [LOG]   Starting MagicMirror: v2.16.0
      [03.10.2021 12:05.53.196] [LOG]   Loading config ...
      [03.10.2021 12:05.53.210] [LOG]   Loading module helpers ...
      [03.10.2021 12:05.53.214] [LOG]   No helper found for module: MMM-Carousel.
      [03.10.2021 12:05.53.216] [LOG]   No helper found for module: alert.
      [03.10.2021 12:05.53.561] [LOG]   Initializing new module helper ...
      [03.10.2021 12:05.53.563] [LOG]   Module helper loaded: updatenotification
      [03.10.2021 12:05.53.564] [LOG]   No helper found for module: clock.
      [03.10.2021 12:05.53.566] [LOG]   No helper found for module: compliments.
      [03.10.2021 12:05.53.568] [LOG]   No helper found for module: MagicMirror-QuoteCatalog.
      [03.10.2021 12:05.54.480] [LOG]   Initializing new module helper ...
      [03.10.2021 12:05.54.482] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
      [03.10.2021 12:05.54.484] [LOG]   No helper found for module: weather.
      [03.10.2021 12:05.54.486] [LOG]   All module helpers loaded.
      [03.10.2021 12:05.54.680] [LOG]   Starting server on port 8080 ...
      [03.10.2021 12:05.54.706] [LOG]   Server started ...
      [03.10.2021 12:05.54.709] [LOG]   Connecting socket for: updatenotification
      [03.10.2021 12:05.54.711] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
      [03.10.2021 12:05.54.712] [LOG]   Sockets connected & modules started ...
      [03.10.2021 12:05.55.131] [LOG]   Launching application.
      [03.10.2021 12:05.58.030] [ERROR] (node:2398) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [03.10.2021 12:05.58.317] [LOG]   Refreshed access token because it has expired. Expired at: 12:05:58 now is: 12:05:58
      [03.10.2021 12:06.01.802] [LOG]   Shutting down server...
      [03.10.2021 12:06.01.805] [LOG]   Stopping module helper: updatenotification
      [03.10.2021 12:06.01.806] [LOG]   Stopping module helper: MMM-NowPlayingOnSpotify
      S 1 Reply Last reply Reply Quote -1
        sdetweil @ljhig
        @ljhig u need to upgrade to node v14 for this version of electron. u are on node 10
        use nvm to upgrade. have to install nvm first
        google search how to do
        after node upgrade
        run my upgrade script
        see https://github.com/sdetweil/MagicMirror_scripts
        u will have to use force as the parm instead of apply
        L 2 Replies Last reply Reply Quote 1
        • L Offline
          ljhig @sdetweil
          @sdetweil thank you for taking the time to reply, I appreciate it.
          I’m new to the forum too btw, so apologies if I’ve posted in the wrong place/generic problem (due to downvotes).
          I will follow your instruction as soon as I’m home.
          Thanks again :)
          • L Offline
            ljhig @sdetweil
            @sdetweil said in Black screen after adding modules.:
            again, apologies for my ignorance but how would I do this? node has been updated and ran your update script buy still getting black screen.
              sdetweil @ljhig
              @ljhig when u did phase 2 of update you were told to use ‘apply’ as parameter
              use ‘force’ instead
              because my script checks, if u already have the latest, then there is nothing to do.
              but I think u have the missing library problem.
              if u use pm2 to launch mm, then do
              pm2 logs --lines=100
              look for ‘module not found’
              just in case, to minimize the MM screen do, alt-spacebar, then n
              (just like on windows)
              • L Offline
                ljhig @sdetweil
                @sdetweil I don’t believe I use PM2, I type:
                cd MagicMirror/
                npm run start
                That works for the original config but not the adjusted one. Should I learn how to install/use pm2 to launch to find out what the missing library problem is?
                  sdetweil @ljhig
                  @ljhig don’t need pm2… just scroll the window up where you do npm start
                  if u want pm2, then use my script to add it… see the end of the list of stuff on my scripts page
                  • L Offline
                    ljhig @sdetweil
                    @sdetweil I will eventually use your script once I’ve got this working, I think it’s really useful and will fit my purpose brilliantly. Gift for my sister who is less tech savvy then me!
                    > magicmirror@2.17.1 start /home/pi/MagicMirror
                    [03.10.2021 17:34.32.637] [LOG]   Starting MagicMirror: v2.17.1
                    [03.10.2021 17:34.32.650] [LOG]   Loading config ...
                    [03.10.2021 17:34.32.663] [LOG]   Loading module helpers ...
                    [03.10.2021 17:34.32.667] [LOG]   No helper found for module: MMM-Carousel.
                    [03.10.2021 17:34.32.669] [LOG]   No helper found for module: alert.
                    [03.10.2021 17:34.32.709] [LOG]   Initializing new module helper ...
                    [03.10.2021 17:34.32.712] [LOG]   Module helper loaded: updatenotification
                    [03.10.2021 17:34.32.715] [LOG]   No helper found for module: clock.
                    [03.10.2021 17:34.32.716] [LOG]   No helper found for module: compliments.
                    [03.10.2021 17:34.32.718] [LOG]   No helper found for module: MagicMirror-QuoteCatalog.
                    [03.10.2021 17:34.33.558] [LOG]   Initializing new module helper ...
                    [03.10.2021 17:34.33.559] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                    [03.10.2021 17:34.33.561] [LOG]   No helper found for module: weather.
                    [03.10.2021 17:34.33.562] [LOG]   All module helpers loaded.
                    [03.10.2021 17:34.33.754] [LOG]   Starting server on port 8080 ...
                    [03.10.2021 17:34.33.798] [LOG]   Server started ...
                    [03.10.2021 17:34.33.801] [LOG]   Connecting socket for: updatenotification
                    [03.10.2021 17:34.33.803] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                    [03.10.2021 17:34.33.805] [LOG]   Sockets connected & modules started ...
                    [03.10.2021 17:34.34.230] [LOG]   Launching application.
                    [03.10.2021 17:34.37.412] [ERROR] (node:1813) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    (Use `electron --trace-deprecation ...` to show where the warning was created)
                    [03.10.2021 17:34.37.791] [LOG]   Refreshed access token because it has expired. Expired at: 17:34:37 now is: 17:34:37
                    [03.10.2021 17:34.42.539] [LOG]   Shutting down server...
                    [03.10.2021 17:34.42.541] [LOG]   Stopping module helper: updatenotification
                    [03.10.2021 17:34.42.542] [LOG]   Stopping module helper: MMM-NowPlayingOnSpotify
                      sdetweil @ljhig
                      @ljhig I don’t know. I would start by disabling one module at a time til u find the villian
                      add
                      disabled:true,
                      after the
                      module:
                      line
                      for each module,
                      restart mm
                      L 2 Replies Last reply Reply Quote 0
                      • L Offline
                        ljhig @sdetweil
                        @sdetweil cheers, starting from scratch again and adding each module one by one, and running after every minor change. Should allow me to catch a problem before it becomes one.
                        • L Offline
                          ljhig @sdetweil
                          @sdetweil I have used your magic mirror auto start script, how do I disable/enable it so I can access the magic mirror?
                          Now when I type CTRL+Q it automatically reopens after 5-10 seconds.
                            sdetweil @ljhig
                            @ljhig pm2’s job is to keep mm running!
                            minimize, alt-spacebar, n
                            open terminal window
                            ctrl-alt-t
                            pm2 stop all
                            checkout the other pm2 commands
                            stop, start, restart, logs, flush
                            pm2 --help
                            L 1 Reply Last reply Reply Quote 1
                            • L Offline
                              ljhig @sdetweil
                              @sdetweil thank you! I know I’ve been an absolute pain but just know that I really appreciate experience users offering assistance to simple folk like myself. Have a brilliant day.
