    Cannot restart my mirror for months
    11 Posts 3 Posters 3.8k Views 3 Watching
    • R
      richardh151
      Please help, I have been trying to get my mirror fixed after my last upgrade. I have searched this site and others areas but cannot find the solution. Can anyone help make my mirror come back to life?
      This is the error messages are get when trying to start my mirror. Sorry in advance if this is easy for someone to fix.
      pi@raspberrypi:~/Documents/MagicMirrorJan2021 $ npm start
      npm ERR! Linux 5.10.63-v7+
      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
      npm ERR! node v6.11.0
      npm ERR! npm v3.10.10
      npm ERR! file /home/pi/Documents/MagicMirrorJan2021/package.json
      npm ERR! code EJSONPARSE
      npm ERR! Failed to parse json
      npm ERR! Unexpected token ‘/’ at 7:41
      npm ERR! “start”: “DISPLAY="${DISPLAY:=:0}"”./node_modules/.bin/electron js/electron
      npm ERR! ^
      npm ERR! File: /home/pi/Documents/MagicMirrorJan2021/package.json
      npm ERR! Failed to parse package.json data.
      npm ERR! package.json must be actual JSON, not just JavaScript.
      npm ERR!
      npm ERR! This is not a bug in npm.
      npm ERR! Tell the package author to fix their package.json file. JSON.parse
      K S 2 Replies Last reply
      • R
        richardh151 @sdetweil
        @sdetweil I managed to update it finally. Now I just have a black screen to fix to show my modules, so it feels close 😁
        • K
          Kelsoh @richardh151
          @richardh151 said in Cannot restart my mirror for months:
          Check your package.json file. Theres something wrong, probably at line 7.
            sdetweil @richardh151
            @richardh151
            your node and npm are way down level
            we are currently requiring node 14 and npm 6
            if you use my MagicMirror upgrade script it will also upgrade node and npm
            see
            BUT the upgrade script only works if mm is installed in ~/MagicMirror
            a quick workaround would be to create a linked folder
            cd ~
            ln -s realpath MagicMirror
            where realpath for you is Documents/MagicMirrorJan2021
            u can delete the linked folder after the update
            note update is a 2 part process.
            1st is a test run to see if there will be issues
            2nd does the update,big u use the apply parm
            but it will upgrade node/npm on the 1st pass
            • R
              richardh151
              I have tried your suggestions but it seems I’m struggling to update npm and node js versions. I continue to obtain an error message related to electron-chromedriver @13.0.0 install script.
              Does anyone have any suggestions, please ?
                @richardh151
                do this
                sudo npm install n -g
                n install 14
                  @richardh151 what pi is this?
                  R 3 Replies Last reply
                  • R
                    richardh151
                    @richardh151 Pi 3 Model B+
                    • R
                      @sdetweil does not work as my permission was denied ( code EACCES)
                      • R
                        • R
                          @sdetweil now Iam back and fully operational again. A huge thanks to you 👍😊
                            @richardh151 my update script fixes the black screen problems too
