    Error while starting Magic Mirror
    29 Posts 2 Posters 9.0k Views 2 Watching
    • 1 Offline
      1BlauNitrox
      Hey guys,
      I am not able to start my Magic Mirror with the command pm2 start MagicMirror.
      There is always this error:
      [21.01.2022 14:17.17.199] [ERROR] Whoops! There was an uncaught exception...
      [21.01.2022 14:17.17.201] [ERROR] TypeError: Cannot read properties of undefined (reading 'on')
          at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:104:5)
          at Module._compile (node:internal/modules/cjs/loader:1101:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
          at Module.load (node:internal/modules/cjs/loader:981:32)
          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
          at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
      I have only installed Spotify and calender_monthly module. Yesterday everythink works fine, now nothing works without changing anything
        sdetweil @1BlauNitrox
        @1blaunitrox that looks like a bad position for a module
        module:
        position: ???
        see the list here
        https://docs.magicmirror.builders/modules/configuration.html
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1BlauNitrox @sdetweil
          This is my config:
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			module: "calendar_monthly",
          			module: "weather",
          				type: "current",
          				locationID: "cityID", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				apiKey: "mykey"
          			module: "weather",
          			header: "Wettervorhersage",
          				type: "forecast",
          				apiKey: "mykey"
                      		 module: "MMM-NowPlayingOnSpotify",
           			 position: "bottom_left",
             				 clientID: "myid",
              				 clientSecret: "myid",
              				 accessToken: "mytoken",
              				 refreshToken: "mytoken"
            @1blaunitrox I don’t see a calendar_monthly module
            • 1 Offline
              @sdetweil What do you mean?
              https://github.com/KirAsh4/calendar_monthly/
                @1blaunitrox thx… I used your module list and dont see any issues…
                you did npm install in both new module folders, right?
                • 1 Offline
                  @sdetweil no, it worked without
                  S 1 2 Replies Last reply Reply Quote 0
                    @1blaunitrox both modules provide a package.json file, which means u must
                    npm install
                    in their folders
                    • 1 Offline
                      1BlauNitrox @1BlauNitrox
                      @1blaunitrox my mistake. I did it
                        @1blaunitrox did u update MM?? git pull?
                        did you npm install after?
                        • 1 Offline
                          @sdetweil what do you mean “update”. Is there a new update?
                            @1blaunitrox just trying to see what changed
                            every 3 months MM releases a new version… 2.18 now… (January 1)
                            • 1 Offline
                              @sdetweil I can try to update. Where should I execute the command “git pull”?
                                @1blaunitrox use my script
                                see
                                • 1 Offline
                                  @sdetweil I can execute the command from any location?
                                    @1blaunitrox which command?
                                    from my scripts? yes, they figure it out
                                    • 1 Offline
                                      @sdetweil I executed bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" but the Error is the same
                                        @1blaunitrox notice that upgrade is a TWO part process…
                                        part 1, no parameter, does a TEST to checkout if there are any issues
                                        then
                                        part 2, with apply at the end will DO the upgrade…
                                        looks like you only did part 1
                                        • 1 Offline
                                            @1blaunitrox ok, so on latest… when did u do that?
