    install MM2.18 on win10 pc
    22 Posts 2 Posters 10.0k Views 3 Watching
      Johans
      Re: Installing Magic mirror on windows 10
      Hi, trying to run MM on a win10 PC - followed the instructions from Mykle1
      but when I run npm start I get following message
      error MM.PNG image url)
      (I already removed DISPLAY… from Package.json)
      how to fix this?
        sdetweil @Johans
        @johans see this issue comment
        https://github.com/MichMich/MagicMirror/issues/2779#issuecomment-1011124060
        J 1 Reply Last reply Reply Quote 2
          Johans @sdetweil
          @sdetweil - thanks for the info. now it is working fine .
            Johans
            I got MM working under Win10 and most of the apps are working.
            but in the end I prefere more the linux, so I installed debian, git, nodejs, and MM.
            When to start the MM i get following message
            Although I updated the package.json file and corrected accoring the instructions, I still get an error message.
            What else is missing?
            S 3 Replies Last reply Reply Quote 0
              sdetweil @Johans
              @johans
              well, the output says that the \ wasn’t right as it removed all the slashes and made 1 big string…
              because u posted screenshots and not text I can’t show more
              what node/npm versions did u install ??
              npm -v
              node -v
              J 3 Replies Last reply Reply Quote 0
                Johans @sdetweil
                npm is version 8.5.2
                node = 17.7.2
                  Johans @sdetweil
                  @sdetweil said in install MM2.18 on win10 pc:
                  Do you want the content of the package.json file?
                  	"name": "magicmirror",
                  	"version": "2.18.0",
                  	"description": "The open source modular smart mirror platform.",
                  	"main": "js/electron.js",
                  	"scripts": {
                  		"start": "node_modules\\.bin\\electron js\\electron.js",
                  		"start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                  		"server": "node ./serveronly",
                  		"install": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error",
                  		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error",
                  		"postinstall": "npm run install-fonts && echo \"MagicMirror installation finished successfully! \n\"",
                  		"test": "NODE_ENV=test jest -i --forceExit",
                  		"test:coverage": "NODE_ENV=test nyc --reporter=lcov --reporter=text jest -i --forceExit",
                  		"test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                  		"test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                  		"test:unit": "NODE_ENV=test jest --selectProjects unit -i --forceExit",
                  		"test:prettier": "prettier . --check",
                  		"test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json",
                  		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                  		"test:calendar": "node ./modules/default/calendar/debug.js",
                  		"config:check": "node js/check_config.js",
                  		"lint:prettier": "prettier . --write",
                  		"lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json --fix",
                  		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                  		"lint:staged": "pretty-quick --staged",
                  		"prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                    Johans @sdetweil
                    I also installed MM on Ubuntu V20.4 and I have exactly the same message as I get on Debian.
                      sdetweil @Johans
                      @Johans is it the same node and npm?
                      we havent tested on node 17.
                      only node 14 and 16
                        Johans @sdetweil
                        @sdetweil On Ubuntu I used node 16.14.2 and npm 8.5.5 while on Debian I used node 17.7.2 and npm 8.5.2. And both seems to give me the same error message
                          sdetweil @Johans
                          @Johans on linux, if you use my script, it does everything… installs node, npm … tools (git, …) etc
                          trying to recreate now
                          I use Ubuntu as my desktop and dev environment, so i know it works there…
                          you don’t use sudo, install as normal user, not root.
                          must have the desktop version of OS (as the browsers draws graphics which requires the graphical env)
                          show me the ~/install.log
                          (you can send to my email, same userid at gmail)
                            sdetweil @Johans
                            @Johans on my windows 11 with 16.9.0 (node version) and package.js start line like this
                            I see this is the startup messages
                            > node_modules\.bin\electron js\electron.js
                            I see the same results on node 17.7.2
                              sdetweil @Johans
                              @Johans sorry, I missed this line
                              so, you do NOT change the package.json for linux… only for windows…
                                Johans @sdetweil
                                @sdetweil Sorry but i’m new on Linux, where to find install log?
                                  sdetweil @Johans
                                  @Johans the file is saved in the users home folder
                                  on linux that is called ~
                                  cd ~ will take you to the home folder
                                  and u can reference any file there the same way
                                  ~/install.log
                                  is the same as
                                  /home/{username}/install.log
                                  using the environment info
                                  /home/$USER/install.log
                                  unix/linux was born on slow teletype terminals… so there are shortcuts for everything to reduce typing and shorten output…
                                  thats why cd is the same as the long name chdir
                                    Johans @sdetweil
                                    @sdetweil I don’t seem to find such a file in the root directory.
                                      sdetweil @Johans
                                      @Johans said in install MM2.18 on win10 pc:
                                      not in the root /
                                      in the users home
                                      you CANNOT do MM as root…
                                      you MUST logon as a normal user (in my case sam on my ubuntu system)
                                        Johans @sdetweil
                                        @sdetweil I have the icon under windows and when I start, Ubuntu it starts with the user I created during installation. ubuntulogin.png
                                        So I guess this is my normal user?
                                        I installed node & MM from jstal@DESKTOP-HF7R0J9 As I think this is correct - or not?
                                          sdetweil @Johans
                                          @Johans wait. you are running Ubuntu in lsw?
                                          that’s text mode. electron won’t run there
                                            Johans @sdetweil
                                            @sdetweil , yes lsw2 that is how I installed it. So that is not good? How do I then make a proper installation on a windows PC? Do you have a link-guide to follow?
