    Trying to update to version 2.25
    13 Posts 2 Posters 4.4k Views 2 Watching
    • V
      vandam3b
      Hi, I am trying to update to version 2.25. I am not a coder by any stretch. I typed this in (git pull && npm run install-mm) and received this message:
      hint: Pulling without specifying how to reconcile divergent branches is
      hint: discouraged. You can squelch this message by running one of the following
      hint: commands sometime before your next pull:
      hint:
      hint: git config pull.rebase false # merge (the default strategy)
      hint: git config pull.rebase true # rebase
      hint: git config pull.ff only # fast-forward only
      hint:
      hint: You can replace “git config” with “git config --global” to set a default
      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
      hint: or --ff-only on the command line to override the configured default per
      hint: invocation.
      Updating e87f50e6…343e7de7
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      Please commit your changes or stash them before you merge.
      Aborting
      Any help would be appreciated. Thank you.
      • V
        vandam3b
        Hi, I just wanted to let you know. I used your script to reinstall and all went well. Thanks again.
          sdetweil @vandam3b
          @vandam3b how did you install mm?
          manual or with my script?
          see
          • V
            vandam3b
            Hi, I installed it manually.
              sdetweil @vandam3b
              @vandam3b rename the MagicMirror folder to some other name
              and then run my install script.
              I don’t know why your git config has this problem
              or maybe restore this file
              package-lock.json
              git checkout package-lock.json
              • V
                vandam3b
                I will give it a try. Thank you very much.
                • V
                  vandam3b @vandam3b
                  @vandam3b
                  Hi, I installed your scripts and now get this when I try to run MagicMirror with npm start.
                  magicmirror@2.25.0 start
                  DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                  sh: 1: ./node_modules/.bin/electron: not found
                    sdetweil @vandam3b
                    @vandam3b what platform is this?
                    can u send me the ~/install.log to my email
                    same userid at gmail
                    try this too
                    cd ~/MagicMirror
                    npm install electron@26.2.4
                    then if its sucessful
                    npm start
                    • V
                      vandam3b
                      Hi, I tried it but I still got the same error. I don’t know where to find the install.log. I appreciate your help and do not want to take any more of your time. I will just uninstall everything and then start from scratch. Thanks again.
                        sdetweil @vandam3b
                        @vandam3b use my install script after u flash the SD card again
                        see
                        https://github.com/sdetweil/MagicMirror_scripts/tree/master
                        • V
                          vandam3b
                          I will. Thanks
                            sdetweil @vandam3b
                            @vandam3b said in Trying to update to version 2.25:
                            thats why I am here… to help
                            • V
                              vandam3b
                                sdetweil @vandam3b
                                @vandam3b cool, thanks for the feedback!
