    Issue with MMM-GoogleTrafficTimes: Google Traffic Module
    11 Posts 3 Posters 1.5k Views 3 Watching
    • E
      ethanmaxim
      I have been struggling with getting this module to work after many attemps. This is the only module I havent been able to get work. I wanted to see if anyone can notice a dumb issue I may be not seeing. I’ve been going crazy trying to get this to work and I keep getting an error when running it.
                  module: 'MMM-GoogleTrafficTimes',
                  position: 'top_left',
                      key: 'AIzaSyBgXWdpBmbL-pMhx95YNNM7fT_mutMKuts',
                      origin: '11111 Inglewood Blvd Los Angeles CA 90040',
                      destinations: [
      			        	address: "2000 E 7th Place Los Angeles 90021"
                      updateInterval: 900000,
                      avoidHighways: false,
                      avoidTolls: false,
                      mode: 'driving',
                      language: "en-EN",
                      offsetTime: 25,
      		        lastUpdate: true,
      		        timeLastUpdateWarning: 1,
                      horizontalLayout: false,
                      schedules: [],
                      debug: false
      S E 2 Replies Last reply Reply Quote 0
      • H
        HarrieV
        Could be a faulty installation…
        At the 3rd Party Modules page on GitHub you’ll find 2 different versions of the MMM-GoogleTrafficTimes module; an old one from pjestico and a newer one from Jacopo1891.
        I couldn’t get the Jacopo1891 version working, so I tried the pjestico version (on MacOS), and got the following error at installation:
        npm ERR! Your cache folder contains root-owned files, due to a bug in
        npm ERR! previous versions of npm which has since been addressed.
        npm ERR!
        npm ERR! To permanently fix this problem, please run:
        npm ERR!   sudo chown -R 501:20 "/Users/harriev/.npm"
        It fixed the problem indeed, the module worked fine afterwards.
        Then, I removed the old module, installed the Jacopo1891 version and that
        worked as well.
          sdetweil @ethanmaxim
          @ethanmaxim what’s the error?
          • E
            ethanmaxim @ethanmaxim
            @ethanmaxim This is what the terminal spits out:
            [2024-04-16 16:55:07.682] [LOG]   Starting MagicMirror: v2.27.0
            [2024-04-16 16:55:07.781] [LOG]   Loading config ...
            [2024-04-16 16:55:07.784] [LOG]   config template file not exists, no envsubst
            [2024-04-16 16:55:07.788] [LOG]   Loading module helpers ...
            [2024-04-16 16:55:07.790] [LOG]   No helper found for module: alert.
            [2024-04-16 16:55:08.044] [LOG]   Initializing new module helper ...
            [2024-04-16 16:55:08.045] [LOG]   Module helper loaded: updatenotification
            [2024-04-16 16:55:08.046] [LOG]   No helper found for module: clock.
            [2024-04-16 16:55:08.078] [LOG]   Initializing new module helper ...
            [2024-04-16 16:55:08.080] [LOG]   Module helper loaded: MMM-OnSpotify
            [2024-04-16 16:55:08.372] [LOG]   Initializing new module helper ...
            [2024-04-16 16:55:08.373] [LOG]   Module helper loaded: MMM-Wallpaper
            [2024-04-16 16:55:08.518] [LOG]   Initializing new module helper ...
            [2024-04-16 16:55:08.518] [LOG]   Module helper loaded: calendar
            [2024-04-16 16:55:08.553] [LOG]   Initializing new module helper ...
            [2024-04-16 16:55:08.554] [LOG]   Module helper loaded: mmm-nest-status
            [2024-04-16 16:55:08.554] [LOG]   No helper found for module: compliments.
            [2024-04-16 16:55:08.555] [LOG]   No helper found for module: weather.
            [2024-04-16 16:55:09.387] [ERROR] (node:461193) UnhandledPromiseRejectionWarning: Error: Cannot find module 'core-js/modules/es.string.replace.js'
            Require stack:
            - /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js
            - /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/serialize.js
            - /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/directions.js
            - /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/client.js
            - /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/geolocate.js
            - /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/index.js
            - /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_helper.js
            - /home/ethanc/MagicMirror/js/app.js
            - /home/ethanc/MagicMirror/js/electron.js
                at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
                at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
                at Module._resolveFilename (/home/ethanc/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Module._load (node:internal/modules/cjs/loader:908:27)
                at c._load (node:electron/js2c/node_init:2:13672)
                at Module.require (node:internal/modules/cjs/loader:1122:19)
                at require (node:internal/modules/helpers:130:18)
                at /home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js:1:79
                at Object.<anonymous> (/home/ethanc/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js:1:807)
                at Module._compile (node:internal/modules/cjs/loader:1256:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1311:10)
                at Module.load (node:internal/modules/cjs/loader:1098:32)
                at Module._load (node:internal/modules/cjs/loader:945:12)
            (Use `electron --trace-warnings ...` to show where the warning was created)
            [2024-04-16 16:55:09.394] [ERROR] (node:461193) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
            [461368:0416/165511.309048:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.312293:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.316548:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.316877:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.317708:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.318247:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.319188:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.319768:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.320776:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.324256:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.324844:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.325187:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.325682:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.325976:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.333326:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.333741:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.334416:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.334818:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.335390:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.336180:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.348688:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.349704:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.350541:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.353427:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.356675:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.357100:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [461368:0416/165511.358117:ERROR:gbm_wrapper.cc(76)] Failed to get fd for plane.: No such file or directory (2)
            [461368:0416/165511.364225:ERROR:gbm_wrapper.cc(259)] Failed to export buffer to dma_buf: No such file or directory (2)
            [2024-04-16 16:55:12.797] [INFO]  System information:
            ### SYSTEM:   manufacturer: ; model: ; raspberry: undefined; virtual: false
            ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.26-v8+
            ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 18.19.0; npm: 9.2.0; pm2: 5.3.1
            ### OTHER:    timeZone: America/Los_Angeles; ELECTRON_ENABLE_GPU: undefined
            ^C/home/ethanc/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
              @ethanmaxim did you have it working then upgrade?
              E S 2 Replies Last reply Reply Quote 0
              • E
                ethanmaxim @sdetweil
                @sdetweil No i’ve never gotten this module to work properly. it keeps throwing off this error. Ive checked everything and cant seem to find why. API is valid etc etc.
                  @sdetweil try these steps in the module folder
                  don’t need yarn install
                    @ethanmaxim it’s a packaging error
                    • E
                      @sdetweil Just followed this im still getting the identical error as before :/
                      • E
                        @sdetweil No luck still. same error as before
                          @ethanmaxim bummer. module is broken
                          • H
                            HarrieV
                            npm ERR!
                            worked as well.
