    MagicMirror Failing on Raspberry Pi Zero W Rev 1.1
    43 Posts 3 Posters 7.1k Views 3 Watching
      @davidgagne @butchkemper
      fixed
      but do
      free -m
      from command lineto see how big swap is
        @butchkemper said in MagicMirror Failing on Raspberry Pi Zero W Rev 1.1:
        You might consider moving from the SDcard to an SSD which will provide quicker data access and improved security against SDcard failure.
        If I connect an SSD via the data port and remove the SIM, will the 0 boot from the SSD? Or is there a way to configure the SIM to have it switch to the SSD or something?
          sdetweil @davidgagne
          @davidgagne pi 0 doesnt support boot from ssd/usb
          you can make a hybrid, boot from read only sd , run from ssd
          see
          https://forums.raspberrypi.com/viewtopic.php?t=251733
          • 5 / 5
