    MM very slow to charge
    12 Posts 3 Posters 692 Views 3 Watching
    • C Offline
      Canguingo
      Hi everyone!
      I have installed the MagicMirror and I have noticed that when I type pm2 start mm it takes like 2 to 5 minutes to start the MM.
      I have version 2.31.0 and Raspberry Pi 3 Model B Plus Rev 1.3
      For the rest I am not familiar with programming, so very grateful for your assistance AND patience!
      Thanks in advance for any ideas how to solve this.
      Cheers!
      • S Away
        sdetweil @Canguingo
        @Canguingo how did you install MagicMirror?
        can you open a terminal window and do
        free -m
        so we can see memory usage. the latest raspberry pi os, bookworm , will need about 2.5g w MagicMirror running
        the hardware is only 1 g as i recall
        • C Offline
          Canguingo @sdetweil
          @sdetweil Hi Sam, thanks!!
          This is what i got:
          total used free shared buff/cache available
          Mem: 906 592 65 38 345 314
          Swap: 511 278 233
          I believe it should be enough. I only use calendar, weather and a small solar PV module. Could it be that Electron takes too much memory?
          • S Away
            sdetweil @Canguingo
            @Canguingo what os version (seems too small)
            do
            uname -a
            lsb_release -a
            • C Offline
              Canguingo @sdetweil
              This is what I got:
              Linux raspberrypi 6.12.25+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30) aarch64 GNU/Linux
              No LSB modules are available.
              Distributor ID: Debian
              Description: Debian GNU/Linux 12 (bookworm)
              Release: 12
              Codename: bookworm
              It could be the SD-card? (I believe it is 5 years old…)
              • S Away
                sdetweil @Canguingo
                @Canguingo you are actively swapping, 250-ish meg, all that goes on the sd card.
                surprised the memory use is as small as it is…
                mine is about 1.5gig on swap file…
                • C Offline
                  Canguingo @sdetweil
                  @sdetweil ok thanks. So is there anything I could do?
                  S C 2 Replies Last reply Reply Quote 0
                  • S Away
                    sdetweil @Canguingo
                    @Canguingo on one of my slow systems i used a usb ssd stick
                    as the pi3 doesn’t support boot from usb, i found a way to boot from sd card, but run from the ssd stick.
                    ill have to find that again, been years
                    you could try s newer faster sd card, but they were designed for seldom write, frequent read
                    • C Offline
                      Canguingo @Canguingo
                      Ok thanks. i think i will sruvive with these 2 to 4 minutes, maybe somewhere in the future I’ll change the sd-card.
                      Do you think I will need to re-install everything again if changing the sd? I guess so…
                      Since it took me like 2 days to install this, i’ll wait and live with it…
                      thanks anyway!
                      S plainbrokeP 2 Replies Last reply Reply Quote 0
                      • S Away
                        sdetweil @Canguingo
                        @Canguingo if you have a usb adapter for an sd card, linux provides a command to copy disk to disk, dd
                        if you use the scripted installer it shouldn’t take more than an hour
                        use my backup/restore scripts to save the MagicMirror config and modules list . good for moving to new sd card, machine
