    nodejs 22.18.0 ??
    25 Posts 3 Posters 6.2k Views 3 Watching
    • AssassinsA Offline
      Assassins
      Hello.
      I can only install up to node v22.15.0 but the new MM 2.33.0 is say " This release needs nodejs version v22.18.0 or higher"
      How can i install the right version ???
      S TAGinsideT 2 Replies Last reply Reply Quote 0
      • TAGinsideT Offline
        TAGinside @Assassins
        @Assassins
        You can try this
        Before check if you have a version installed yet
        node -v
        If yes uninstall it
        For install node.js 22 MAJOR
        curl -sL https://deb.nodesource.com/setup_22.x | sudo -E bash -
        sudo apt install nodejs
        At least check if you have the good version with node -v
          sdetweil @Assassins
          @Assassins
          See
          https://forum.magicmirror.builders/post/127340
          AssassinsA 1 Reply Last reply Reply Quote 0
            Assassins @sdetweil
            @sdetweil is not working to 22.18.0 is only install 22.15.0
              sdetweil @Assassins
              @Assassins what pi is? What pi?
                Assassins @sdetweil
                @sdetweil Pi3
                  sdetweil @Assassins
                  @Assassins what os
                  Phone correction grrrrr
                    Assassins @sdetweil
                    @sdetweil is a pi3 armv7l
                      sdetweil @Assassins
                      @Assassins no, do
                      lsb_release -a
                      S AssassinsA 2 Replies Last reply Reply Quote 0
                        Also try
                        nvm —help
                          Assassins @sdetweil
                          @sdetweil said in nodejs 22.18.0 ??:
                          lsb_release -a
                          Distributor ID: Raspbian
                          Description: Raspbian GNU/Linux 13 (trixie)
                          Release: 13
                          Codename: trixie
                            Assassins @sdetweil
                            @sdetweil is a new fresh install i dont can install 22.18.0, so i can not install MM 2.33.0
                              sdetweil @Assassins
                              @Assassins trixie 32 bit is trouble so far. I’d go back to bookworm
                                Assassins @sdetweil
                                @sdetweil i had the same problem yesterday with bookworm
                                  sdetweil @Assassins
                                  @Assassins did you use my script?
                                  I tested 32 bit on pi3 the other other day
                                    Assassins @sdetweil
                                    @sdetweil but is only install 22.15.0 and not 22.18.0 yesterday on bookworm, and today on trixie
                                      sdetweil @Assassins
                                      @Assassins flash sd card with bookworm , boot sd, run script
                                        Assassins @sdetweil
                                        bookworm 32bit on a freash install say :
                                        pi@EmptyImage:~ $ sudo npm install n -g
                                        sudo: npm: Command not found
                                          sdetweil @Assassins
                                          @Assassins yes, node/npm are not installed
                                            Assassins @Assassins
                                            You start by referring to another thread.
                                            Have you even read what I’m writing in this thread??
                                            Read further up, I’m writing that just install 22.15.0 on a fresh install, and you write back, after you wirte “flash sd card with bookworm , boot sd, run script” the another thread say
                                              the script, my script will install node/npm at the version we think matches inside electron, if necessary
                                              IF there is a problem, separately, outside my script,
                                              you can use n or nvm to update/change your node version
                                              n requires node and npm to be installed (as they are part of the n install)
