    Newbie to everything - Error in module and cant work out why!
    12 Posts 3 Posters 6.4k Views 4 Watching
    • E Offline
      erycken
      Hi all,
      I am a complete beginner at everything. Only been coding for a few months and it hasn;t even been in JS or HTML!
      Couldn;t resist trying to get a MagicMirror and with the help of a proficient mate here I am.
      So here is my problem…(see attached image)… I am not sure where it is other than it relates to the MMM-MyTraktSeries module, which shows ‘loading…’ when displayed on my mirror.
      Was wondering if someone could explain the issue to me (and possibly a solution?) so that I have better understanding on how to deal with this in the future!
      Many thanks from me!
      • P Offline
        postremalone
        what gave you this error? what were you trying to do? I started making a magic mirror a week ago and i can help with creating a basic magic mirror.
        • E Offline
          erycken
          This is the error that the log spat. The module (MyTraktSeries) loads on the screen but then is stuck in a constant state of ‘Loading’ (literally what it says on screen). The rest of the modules come up fine and work as normal. I ran the log to see if anything was happening behind the screens.
            sdetweil @erycken
            @erycken press ctrl-shift-i (lower case letter i) to open the debug console and select the console tab, you may have to scroll back to see if the module reported an error here
            • E Offline
              erycken @sdetweil
              @sdetweil I am sorry, but where/how am I supposed to do this? I have disabled keyboard/mouse access to my pi and SSH in due to its location.
              Edit : I have no idea how it was disabled as a mate did it.
                sdetweil @erycken
                @erycken bummer, u need keyboard access to the MM screen to do the ctrl-shift-i…
                you could restart the mm in dev mode to do the same thing, but u will need keyboard access to select the console tab
                • E Offline
                  erycken @sdetweil
                  @sdetweil Well… i just did the updates and it has given me a black screen… I think I may be able to get around the keyboard thing once I get back up and running!
                  • E Offline
                    erycken @erycken
                    Ok so my mirror is completely messed up since the update (might be partially my fault though I have no idea) so I am going to try and rebuild my mirror from scratch over the next few days…
                    I’ll update you all on if the rebuild helps the error I am currently experiencing or if it is still present. Thanks…
                    • E Offline
                      erycken
                      Completely remade my mirror (without doing updates this time) and still getting the loading issue… Just a little FYI.
                      @sdetweil I did as you suggested and I didn’t see anything stand out to me other than this :
                      0_1530845990867_80945c68-203d-4349-a6d1-6a078b69aab7-ScreenCapture.png ScreenCapture.png
                      Suggestion?
                        sdetweil
                        can u scroll back up in the debug log, to the top…
                        and also
                        minimize the mirror screen, alt-spacebar, n
                        to be able to see the console window
                        i just installed 2.4.1 on my new pi… and its working fine…
                        • E Offline
                          erycken @sdetweil
                          @sdetweil Here is the log. I did the update and it just black screened twice despite following all the instructions. Other people seem to be experiencing it still so I am gonna wait until its resolved before I update.
                          Anyway log below with a screen capture of the on screen issue.
                          ![alt text](image url)
                          Initializing MagicMirror.
                          translator.js:197 Loading core translation file: translations/en.json
                          translator.js:219 Loading core translation fallback file: translations/en.json
                          loader.js:182 Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js
                          module.js:469 Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.1.0 - Current version: 2.2.2
                          module.js:471 Version is ok!
                          module.js:477 Module registered: MMM-Remote-Control
                          loader.js:152 Bootstrapping module: MMM-Remote-Control
                          loader.js:157 Scripts loaded for: MMM-Remote-Control
                          loader.js:197 Load stylesheet: modules/MMM-Remote-Control/remote-control.css
                          loader.js:159 Styles loaded for: MMM-Remote-Control
                          loader.js:161 Translations loaded for: MMM-Remote-Control
                          loader.js:182 Load script: modules/default/alert//alert.js
                          module.js:477 Module registered: alert
                          loader.js:152 Bootstrapping module: alert
                          loader.js:182 Load script: modules/default/alert/classie.js
                          loader.js:182 Load script: modules/default/alert/modernizr.custom.js
                          loader.js:182 Load script: modules/default/alert/notificationFx.js
                          loader.js:157 Scripts loaded for: alert
                          loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
                          loader.js:159 Styles loaded for: alert
                          translator.js:170 alert - Load translation fallback: translations/en.json
                          loader.js:161 Translations loaded for: alert
                          loader.js:182 Load script: modules/MMM-RPI-LED//MMM-RPI-LED.js
                          module.js:477 Module registered: MMM-RPI-LED
                          loader.js:152 Bootstrapping module: MMM-RPI-LED
                          loader.js:182 Load script: modules/MMM-RPI-LED/shared/enums.js
                          loader.js:157 Scripts loaded for: MMM-RPI-LED
                          loader.js:159 Styles loaded for: MMM-RPI-LED
                          loader.js:161 Translations loaded for: MMM-RPI-LED
                          loader.js:182 Load script: modules/default/clock//clock.js
                          module.js:477 Module registered: clock
                          loader.js:152 Bootstrapping module: clock
                          loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                          loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                          loader.js:157 Scripts loaded for: clock
                          loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
                          loader.js:159 Styles loaded for: clock
                          loader.js:161 Translations loaded for: clock
                          loader.js:182 Load script: modules/default/calendar//calendar.js
                          module.js:477 Module registered: calendar
                          loader.js:152 Bootstrapping module: calendar
                          loader.js:237 File already loaded: moment.js
                          loader.js:157 Scripts loaded for: calendar
                          loader.js:197 Load stylesheet: modules/default/calendar/calendar.css
                          loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
                          loader.js:159 Styles loaded for: calendar
                          loader.js:161 Translations loaded for: calendar
                          loader.js:182 Load script: modules/default/currentweather//currentweather.js
                          module.js:477 Module registered: currentweather
                          loader.js:152 Bootstrapping module: currentweather
                          loader.js:157 Scripts loaded for: currentweather
                          loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                          loader.js:197 Load stylesheet: modules/default/currentweather/currentweather.css
                          loader.js:159 Styles loaded for: currentweather
                          loader.js:161 Translations loaded for: currentweather
                          loader.js:182 Load script: modules/default/weatherforecast//weatherforecast.js
                          module.js:477 Module registered: weatherforecast
                          loader.js:152 Bootstrapping module: weatherforecast
                          loader.js:157 Scripts loaded for: weatherforecast
                          loader.js:237 File already loaded: weather-icons.css
                          loader.js:197 Load stylesheet: modules/default/weatherforecast/weatherforecast.css
                          loader.js:159 Styles loaded for: weatherforecast
                          loader.js:161 Translations loaded for: weatherforecast
                          loader.js:182 Load script: modules/MMM-MyTraktSeries//MMM-MyTraktSeries.js
                          module.js:477 Module registered: MMM-MyTraktSeries
                          loader.js:152 Bootstrapping module: MMM-MyTraktSeries
                          loader.js:157 Scripts loaded for: MMM-MyTraktSeries
                          loader.js:197 Load stylesheet: modules/MMM-MyTraktSeries/MMM-MyTraktSeries.css
                          loader.js:159 Styles loaded for: MMM-MyTraktSeries
                          translator.js:170 MMM-MyTraktSeries - Load translation fallback: translations/en.json
                          loader.js:161 Translations loaded for: MMM-MyTraktSeries
                          loader.js:182 Load script: modules/MMM-CalendarExt//MMM-CalendarExt.js
                          module.js:477 Module registered: MMM-CalendarExt
                          loader.js:152 Bootstrapping module: MMM-CalendarExt
                          loader.js:182 Load script: modules/MMM-CalendarExt/Configs.js
                          loader.js:182 Load script: modules/MMM-CalendarExt/Render.js
                          loader.js:157 Scripts loaded for: MMM-CalendarExt
                          loader.js:237 File already loaded: font-awesome.css
                          loader.js:197 Load stylesheet: modules/MMM-CalendarExt/custom.css
                          loader.js:197 Load stylesheet: modules/MMM-CalendarExt/preset.css
                          loader.js:159 Styles loaded for: MMM-CalendarExt
                          loader.js:161 Translations loaded for: MMM-CalendarExt
                          loader.js:197 Load stylesheet: css/custom.css
                          MMM-Remote-Control.js:21 Starting module: MMM-Remote-Control
                          alert.js:151 Starting module: alert
                          clock.js:40 Starting module: clock
                          calendar.js:67 Starting module: calendar
                          currentweather.js:94 Starting module: currentweather
                          weatherforecast.js:90 Starting module: weatherforecast
                          MMM-MyTraktSeries.js:22 Starting module: MMM-MyTraktSeries
                          main.js:422 All modules started!
                          module.js:156 MMM-RPI-LED received a system notification: ALL_MODULES_STARTED
                          module.js:156 clock received a system notification: ALL_MODULES_STARTED
                          module.js:156 calendar received a system notification: ALL_MODULES_STARTED
                          module.js:156 MMM-MyTraktSeries received a system notification: ALL_MODULES_STARTED
                          module.js:156 MMM-RPI-LED received a system notification: DOM_OBJECTS_CREATED
                          module.js:156 clock received a system notification: DOM_OBJECTS_CREATED
                          module.js:156 calendar received a system notification: DOM_OBJECTS_CREATED
                          module.js:156 MMM-MyTraktSeries received a system notification: DOM_OBJECTS_CREATED
                          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: CALEXT_SAYS_READY from sender: MMM-CalendarExt
                          module.js:154 MMM-RPI-LED received a module notification: CALEXT_SAYS_READY from sender: MMM-CalendarExt
                          module.js:154 clock received a module notification: CALEXT_SAYS_READY from sender: MMM-CalendarExt
                          module.js:154 calendar received a module notification: CALEXT_SAYS_READY from sender: MMM-CalendarExt
                          module.js:154 MMM-MyTraktSeries received a module notification: CALEXT_SAYS_READY from sender: MMM-CalendarExt
                          module.js:198 currentweather is suspended.
                          module.js:198 weatherforecast is suspended.
                          module.js:205 currentweather is resumed.
                          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: CURRENTWEATHER_DATA from sender: currentweather
                          module.js:154 MMM-RPI-LED received a module notification: CURRENTWEATHER_DATA from sender: currentweather
                          module.js:154 clock received a module notification: CURRENTWEATHER_DATA from sender: currentweather
                          module.js:154 calendar received a module notification: CURRENTWEATHER_DATA from sender: currentweather
                          module.js:154 MMM-MyTraktSeries received a module notification: CURRENTWEATHER_DATA from sender: currentweather
                          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: CALENDAR_EVENTS from sender: calendar
                          module.js:154 MMM-RPI-LED received a module notification: CALENDAR_EVENTS from sender: calendar
                          module.js:154 clock received a module notification: CALENDAR_EVENTS from sender: calendar
                          module.js:154 MMM-MyTraktSeries received a module notification: CALENDAR_EVENTS from sender: calendar
                          https://api.openweathermap.org/data/2.5/forecast/daily?id=2144528&units=metric&lang=en&cnt=7&APPID=2bf262b7e02e653bcb20aac437a35919 Failed to load resource: the server responded with a status of 401 (Unauthorized)
                          weatherforecast.js:263 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154 MMM-RPI-LED received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154 clock received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154 calendar received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154 MMM-MyTraktSeries received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          MMM-Remote-Control.js:36MMM-Remote-Control received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154MMM-RPI-LED received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154clock received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154calendar received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:154MMM-MyTraktSeries received a module notification: CALEXT_SAYS_CALENDAR_MODIFIED from sender: MMM-CalendarExt
                          module.js:205 weatherforecast is resumed.
                            sdetweil
                            @erycken said in Newbie to everything - Error in module and cant work out why!:
                            so, from the log, your module is loaded and running…
                            so, what do you do to present info? how does your module respond to the getDom() method call?
                            that is how it provides data to be displayed…
