    DropboxWallpaper pictures are rotated to the left
    20 Posts 3 Posters 7.4k Views 3 Watching
    • D
      DJC27
      Hi Everyone
      I’ve got a problem with MMM-DropboxWallpaper when displaying protrait pictures in the ‘cover’ mode. Landscape pictures are displayed correctly, but the portrait pictures are rotated to the left. On dropbox they are correctly saved (upright). Anyone any idea why this happens? I have tried to rotate all the portrait pictures to the right, but on the mirror they are still rotated to the left.
      Many thanks in advance.
        A Former User @DJC27
        @djc27 When in contain mode also photos are rotated?
          A Former User @Guest
          @sean Too many days are gone, so my remembrance is not perfect. But as I remember, I didn’t put any rotation for pictures in the module. It means your original photos are taken as rotated. But your photo viewers could show automatically pictures in its right direction. But My module doesn’t check any direction information from the pictures.
          Anyway, I’ll check furthermore, if there is any possible fixing about that.
          • D
            DJC27 @Guest
            @sean Thank you for your quick reply. I have checked ‘contain’ and ‘hybrid’ mode and all the pictures remain rotated to the side… Your help would be much appreciated.
              @djc27
              First, In Dropbox API, there is no information about the direction of Photo. Maybe with EXIF parsing, I could abstract that info from photos. But additional EXIF parser routines should be added.
              Nowadays common digital cameras automatically save pictures with right direction. I guess, your photos were taken with somewhat older camera.
              And your manual rotating pictures might be not progressed in original files. current common photo viewers/editors (like Apple Photos) using a copy of the original file for manipulating and showing for the user.
              Anyway, I’ve found also my MMM-DropboxyWallpaer are using older version of API. I will update in somedays, but not promise.
              • D
                DJC27 @Guest
                @sean Some pictures were indeed taken with an older camera (approx. 6 years old) but some were taken with a recent smartphone. I encountered the problem with all of them. The dimensions of the pictures seem to change correctly, when they are manually rotated. But anyway thanks for your help. I might just try and safe some of the pictures in landscape mode with two black bars on the side so that the pictures will be shown the right way up and appear to be in landscape mode for the magicmirror.
                • richland007R
                  richland007
                  @Sean Same here all… pictures are rotated very few are the right way … the majority of photos are taken with a Samsung Galaxy S8+ and some with older camera
                  Denis
                    A Former User
                    @DJC27 @richland007
                    Could you send me some pictures with wrong orientations for a test?
                    My all photos are already rotated to the right orientation, so, I couldn’t test.
                    my email address is in my profile. I think one or two photos are enough.
                      A Former User
                      @DJC27 @richland007
                      V2.0.0 is beta-released.
                      https://github.com/eouia/MMM-DropboxWallpaper/
                      And… Please read the last section of README.md
                      D richland007R 2 Replies Last reply Reply Quote 0
                      • D
                        DJC27 @Guest
                        @sean Thank you very much. I’ll try that tomorrow and I will consider the README file.
                        • richland007R
                          richland007
                          @sean Thnak you will try it this evening as well
                          I did use your advise on the free photo editor and already saved my pics the right way and uploaded to dropbox so when i go home it will be easy to load the git clone the new version and try it out
                          thanks again in advance
                          • richland007R
                            richland007 @Guest
                            @sean we hit a bump i think i am getting this when i try to run npm install after the git pull
                            inside the MMM-DropboxWallpaper
                            Obviously an error of some sort but i dont know whether it has to do with syntax or something else such as versions miss match who are always a pin in the neck i am on the latest MM version 2.4.1 which has electron 2.0
                            Denis
                            ? 2 Replies Last reply Reply Quote 0
                              A Former User @richland007
                              @richland007 sorry, there is a syntax error in package.json i’all fix
                                @richland007
                                Remove last comma.
                                ’isomorphic-fetch": "^2.2.1’
                                richland007R 1 Reply Last reply Reply Quote 0
                                • richland007R
                                  richland007 @Guest
                                  @sean Hey things happen :) …what should we do clone it one more time or go and manually change something ??
                                  D
                                    @richland007
                                    just
                                    git pull
                                    npm install
                                    again. I’ve fixed already.
                                    • D
                                      DJC27 @Guest
                                      @sean Thank you very much, all seems to work, and the orientation of the pictures appears to be correct. There is only one small issue. Sometimes the mirror only shows a very small part of the pictures (approx. a fourth or so). Not always, but sometimes. I have got no idea what might cause that, because all the pictures were taken with the same smartphone.
                                        @djc27 that was what I said. ’transform:rotation()’ could make image rotated but resized. Hmmm difficult to explain.
                                        Assume a portrait photo with 1000px width and 2000px height but has 90 degree clockwise orientation.(you took the picture with camera vertically, and your camera hadn’t saved it as right orientation)
                                        It is recognized as landscape photo with 1000 height and 2000 width.(that was your prior problem)
                                        Now module can rotate with right orientation. But rotated photo should have same dimensions, h1000 and w2000. It means the real image size would be h1000 and w500 and extra black area w750 on left and right sides of image(total w2000 and h1000). photo is now resized by 1/4.
                                        Sorry, I couldn’t fix it any more.
                                        • D
                                          DJC27 @Guest
                                          @sean Yeah I see. No worries though, I still really like the module. Cheers
                                          • richland007R
                                            richland007
                                            @Sean works good thank you for your support and work
