    Absolute Beginner Needing Help Installing Dependencies
    11 Posts 5 Posters 5.6k Views 5 Watching
      bhall321
      Hey, everyone.
      Hoping someone will be able to dive in and help me out. I’m really new to Raspberry Pi, and I’m pulling my hair out because I can’t get past this one last step. I’m running into issues trying to install MagicMirror. Here’s the command I’m using and the output I’m receiving. Any idea on how to fix this would be appreciated. I know practically nothing about how to code for Raspberry Pi, so very clear directions for what to try will be the most helpful. Thanks!
      pi@raspberrypi:~/MagicMirror $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                              \______/
      Updating packages ...
      Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
      Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
      Reading package lists... Done
      Installing helper tools ...
      Building dependency tree
      Reading state information... Done
      build-essential is already the newest version (12.3).
      curl is already the newest version (7.52.1-5+deb9u8).
      git is already the newest version (1:2.11.0-3+deb9u4).
      unzip is already the newest version (6.0-21).
      wget is already the newest version (1.18-5+deb9u2).
      The following package was automatically installed and is no longer required:
        realpath
      Use 'sudo apt autoremove' to remove it.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v5.1.0
      Installed Node version: v8.11.1
      No Node.js upgrade necessary.
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Enumerating objects: 302, done.
      remote: Counting objects: 100% (302/302), done.
      remote: Compressing objects: 100% (270/270), done.
      remote: Total 302 (delta 37), reused 170 (delta 22), pack-reused 0
      Receiving objects: 100% (302/302), 614.30 KiB | 0 bytes/s, done.
      Resolving deltas: 100% (37/37), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      (node:31309) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN deprecated express-ipfilter@0.3.1: This package is no longer being maintained and contains security vulnerabilities
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      successfully dowloaded and extracted!
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
      npm ERR!
      npm ERR! not ok code 0
      • L Offline
        leroyhab
        Hello
        I meet the same issue.
        I have run the installation bash on a fresh newly setup raspberry pi 3 B.
        After this error, I tried to installa previous version of electron
        sudo npm install -g electron@1.7.6
        Error log is the same :
        (node:1853) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "-g" "electron@1.7.6"
        npm ERR! code E405
        npm ERR!
        If you find some answer to this issue, I will be glad to setup my mirror.
          mdhenriksen @bhall321
          @bhall321 HI! I see you are using the automatic installer which - I seem to recall - is missing Node. I would recommend doing a manual installation instead. The steps to do it is on GitHub and they are very easy to follow :-)
          • L Offline
            leroyhab
            hello mdhenriksen
            Thank you for your answer
            I have run the automatic installer and the first error I got was “npm Command unknown”
            So I installed Node and Npm and re-ran the automatic installer .
            Then I got this error.
            I am setting the sdcard for the raspberry Pi from scratch then i will try the manual step by step.
            Thank you
            Best regards
            Habib
              mdhenriksen @leroyhab
              @leroyhab Great! I think you will have more luck with that. Let me know how it goes!
                sdetweil @leroyhab
                @leroyhab said in Absolute Beginner Needing Help Installing Dependencies:
                npm -v 1.4.21
                npm is downlevel… mine is 6.6.0
                google search on upgrading npm…
                • L Offline
                  leroyhab
                  Hello
                  I am reading the step-by-step from github
                  First thing missing is the installation of NPM
                  Raspbian Stretch does not come with npm preinstalled (neither in normal, light or full version)
                  Is there a recommended version of npm ?
                    sdetweil @leroyhab
                    @leroyhab whatever the latest is…
                    this is a failing of the install script to check and install/update to the right levels
                    execute
                    sudo npm install npm@latest -g
                    K 1 Reply Last reply Reply Quote 1
                    • L Offline
                      leroyhab
                      Hello
                      Wunderbar !!
                      npm is installed with node !
                      manual setup finished succesfully
                      thank you very much
                        sdetweil
                        awesome!
