    Default Font Changed?
    14 Posts 3 Posters 5.1k Views 3 Watching
      sdetweil @unfriendlydevice
      @unfriendlydevice did u update manually or with my script?
      there was a css change a few releases ago that had similar effects which is why I was asking
      my script creates a log file of the upgrade which would tell versions…
      unfriendlydeviceU 1 Reply Last reply
      • unfriendlydeviceU
        unfriendlydevice @sdetweil
        @sdetweil I use the update function within MMM-Remote-Control, I expect this is the equivalent to a manual update.
          @unfriendlydevice thanks…
          what part is taking more room… I don’t see anything looking out of place…
          • unfriendlydeviceU
            @sdetweil It appears there is more space between the characters than the previous font and to me looks less neat and causes the Gmail module to overlap the clock when an email with a long subject is present. If this is the current look I guess I will have to experiment with setting custom fonts.
              @unfriendlydevice I’m not aware of any explicit font size changes , but we did move to fontawesome 6.1.1
              also see
              ~/MagicMirror/fonts/roboto.css
              which changed a bunch of different fonts
              • unfriendlydeviceU
                @sdetweil Thanks for the advice, I’ll mark this as solved.
                karsten13K 1 Reply Last reply
                • karsten13K
                  karsten13 @unfriendlydevice
                  @unfriendlydevice
                  the font looks wrong to me
                  may this is not sufficient or something went wrong.
                  You could try
                  • goto ~/MagicMirror/fonts folder
                  • delete node_modules folder with rm -rf ./node_modules
                  • run npm install
                  unfriendlydeviceU S 2 Replies Last reply
                  • unfriendlydeviceU
                    unfriendlydevice @karsten13
                    @karsten13 Thanks this fixed it, I can see a subfolder of node_modules has changed names following the npm install.
                      sdetweil @karsten13
                      @karsten13 I think I will add this to the upgrade script
                      • karsten13K
                        karsten13 @sdetweil
                        normally this is done with the npm install ... of mm (see postinstall script in package.json), no idea why this didn’t work in this case …
                          sdetweil @karsten13
                          @karsten13 I understand, but as u suggest , erasing the node_modules folder in fonts will force a clean rebuild…
