    MM will not start
    32 Posts 3 Posters 7.4k Views 3 Watching
      sdetweil @bworch
      @bworch if you used my script then
      the instance is labeled MagicMirror
      the other instance , mm is not running and could be deleted
      pm2 delete xx
      pm2 save
      xx is name or number
      now
      let’s fix the mm start problem
      pm2 stop all
      pm2 flush
      pm2 start MagicMirror
      wait 15 seconds
      pm2 stop all
      show the results of
      pm2 logs --lines=50
        bworch @sdetweil
        @sdetweil thanks for the info. I will try it and let you know. again thanks
          bworch @sdetweil
          @sdetweil once I delete the mm instance; can I rename the MagicMirror instance to mm. thanks
            sdetweil @bworch
            @bworch i do not know
            but you could edit the installers/pm2_MagicMirror.json
            (this is how I give the pretty name, not the script name)
            file and change the name to mm (check the paths as well)
              "apps" : [{
                "name"        : "MagicMirror",
                "script"      : "/home/pi/MagicMirror/installers/mm.sh",
                "watch"       : ["/home/pi/MagicMirror/config/config.js"]
            and then do (delete old, add new)
            pm2 delete MagicMirror
            pm2 save
            pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
            pm2 save
              bworch @sdetweil
              @sdetweil thanks for all your help.
                bworch
                I followed your instructions, and it still will not start. I also restart the pi. this is what I have now.
                thanks
                  bworch
                  I did a pm2 show and this is what I got.
                  thanks
                    bworch @sdetweil
                    @sdetweil followed your instructions, still will not start. I have this now.
                    did a pm2 show
                      sdetweil @bworch
                      @bworch do
                      pm2 logs --lines=100
                      may be better without pm2 for debug
                      pm2 stop all
                      npm start >somefile.txt 2>&1
                      wait 15 seconds
                      ctrl-c
                      edit the somefile.txt
                        bworch @sdetweil
                        @sdetweil couldn’t get the txt file to show. how would I edit it.
                        • 1 / 4
