    Electron Install Error - Electron not found
    18 Posts 3 Posters 6.3k Views 3 Watching
      CLLA1972 @sdetweil
        CLLA1972 @sdetweil
        @sdetweil Here the result.
        S 2 Replies Last reply
          sdetweil @CLLA1972
          @CLLA1972
          show output of node -v
          run my upgrade script with force instead of apply (as u are on the latest release)
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            sdetweil @CLLA1972
            @CLLA1972 ok, I don’t get what is going on, but
            rm -rf node_modules/env-paths
            npm  install  electron@19.0.15
            C 1 Reply Last reply
              CLLA1972 @sdetweil
              @sdetweil Hi again. First of all, thanks for the great help. I am really in deep water here and I really do not want to reboot the whole PI and start from scratch. Here the result from the latest command and the log file. Again THANKS !!AA.JPG [2022-10-17T20_15_34_187Z-debug-0.log](Invalid file type. Allowed types are: .jpg, .jpeg, .png, .gif, .png, .jpg, .jpeg, .gif)
              C S 2 Replies Last reply
                CLLA1972 @CLLA1972
                @CLLA1972 574 timing build:link:node_modules/read-pkg/node_modules/semver Completed in 65ms
                575 timing build:link Completed in 83ms
                576 info run playwright@1.26.1 install node_modules/playwright node install.js
                577 info run playwright@1.26.1 install { code: 1, signal: null }
                578 timing reify:rollback:createSparse Completed in 3063ms
                579 timing reify:rollback:retireShallow Completed in 5ms
                580 timing command:install Completed in 329571ms
                581 verbose stack Error: command failed
                581 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                581 verbose stack at ChildProcess.emit (node:events:527:28)
                581 verbose stack at maybeClose (node:internal/child_process:1092:16)
                581 verbose stack at Socket. (node:internal/child_process:451:11)
                581 verbose stack at Socket.emit (node:events:527:28)
                581 verbose stack at Pipe. (node:net:709:12)
                582 verbose pkgid playwright@1.26.1
                583 verbose cwd /home/pi/MagicMirror
                584 verbose Linux 5.15.32-v7+
                585 verbose node v16.16.0
                586 verbose npm v8.11.0
                587 error code 1
                588 error path /home/pi/MagicMirror/node_modules/playwright
                589 error command failed
                590 error command sh -c node install.js
                591 error BEWARE: your OS is not officially supported by Playwright; downloading fallback build.
                591 error Downloading Chromium 106.0.5249.30 (playwright build v1024)…
                591 error | | 0% of 135.1 Mb
                592 error /home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:709
                592 error throw new Error(Failed to download ${title}, caused by\n${e.stack});
                592 error ^
                592 error
                592 error Error: Failed to download Chromium 106.0.5249.30 (playwright build v1024), caused by
                592 error Error: getaddrinfo EAI_AGAIN playwright-verizon.azureedge.net
                592 error at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:71:26)
                592 error at /home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:709:13
                592 error at async Registry._downloadExecutable (/home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:708:5)
                592 error at async Registry.install (/home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:672:9)
                592 error at async installBrowsersForNpmInstall (/home/pi/MagicMirror/node_modules/playwright-core/lib/server/registry/index.js:876:3)
                593 verbose exit 1
                594 timing npm Completed in 330071ms
                595 verbose unfinished npm timer reify 1666037734674
                596 verbose unfinished npm timer reify:build 1666037983317
                597 verbose unfinished npm timer build 1666037983330
                598 verbose unfinished npm timer build:deps 1666037983332
                599 verbose unfinished npm timer build:run:install 1666037983509
                600 verbose unfinished npm timer build:run:install:node_modules/playwright 1666037983511
                601 verbose code 1
                602 error A complete log of this run can be found in:
                602 error /home/pi/.npm/_logs/2022-10-17T20_15_34_187Z-debug-0.log
                  sdetweil @CLLA1972
                  @CLLA1972
                  repeat the last message instructions but change the npm install to
                  npm install electron@19.0.15 --omit=dev
                  karsten13K 1 Reply Last reply
                  • karsten13K
                    karsten13 @sdetweil
                    there is a typo in rm -rf nodel_modules/env-paths …
                      sdetweil @karsten13
                      @karsten13 dang phones
                        CLLA1972 @sdetweil
                        @sdetweil Did now the commande without the Typo :flushed_face: and god this one (similar to a previous one) . I am getting close to the solution?AA.JPG :-)
                          sdetweil @CLLA1972
                          @CLLA1972 I don’t know
                          make a backup
                          see my https://github.com/sdetweil/MagicMirror-backup-restore
                          then rename the MagicMirror folder out of the way, and run my install script. see if we can get running
                          see
                          if so, then run the restore to put back all the modules and config in the new mm folder created by install
                            CLLA1972 @sdetweil
                            @sdetweil Thanks! Great! That got me back on track again !!! THANKS !!! :clapping_hands_medium-light_skin_tone: :folded_hands:
