    CORS policy
    20 Posts 3 Posters 5.4k Views 3 Watching
      bicolorbore586 @sdetweil
      I’ve tried to do that, now get pretty much the same result, but with a slightly different bit at the end.
      Access to fetch at ‘https://api.weatherbit.io/v2.0/forecast/daily?lat=xxx&lon=-xxx&units=M&key=a…’ from origin ‘http://localhost:8080’ has been blocked by CORS policy: The ‘Access-Control-Allow-Origin’ header contains multiple values ‘*, *’, but only one is allowed. Have the server send the header with a valid value, or, if an opaque response serves your needs, set the request’s mode to ‘no-cors’ to fetch the resource with CORS disabled.
      api.weatherbit.io/v2…:1
      Failed to load resource: net::ERR_FAILED
      weatherbit.js:66 Could not load data … TypeError: Failed to fetch
      at Class.fetchData (weatherprovider.js:136:27)
      at Class.fetchWeatherForecast (weatherbit.js:53:8)
      at weather.js:184:27
      weather.js:150 New weather information available.
      localhost/:1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
        sdetweil @bicolorbore586
        @bicolorbore586 did u git pull, npm install after switch
          @sdetweil yes, followed your instructions to the letter
            @bicolorbore586 custom.css is because it doesn’t exist by default. if u used my install script I create it for you
            touch ~/MagicMirror/css/custom.css
              @sdetweil I used the MagicMirror installation instructions (assuming manual install) to install the software.
              Have just tried your git fetch origin
              But get fatal: Refusing to fetch into current branch refs/heads/develop of none-bare repository.
              (Sorry, you’re probably shaking your head, but I am a complete noob at all this)
                @bicolorbore586 there were two choices
                manual install
                git checkout develop
                git pull
                npm install
                or the other
                • karsten13K Offline
                  karsten13 @sdetweil
                  I think the cors proxy is not new in the weather module (but in newsfeed) so last release should work.
                  The cors proxy was not enabled for all weather providers, only for envcanada and darksky, so it must be enabled in the config for weatherbit by adding useCorsProxy: true, to the weather config.
                    sdetweil @karsten13
                    @karsten13 ah, I thought we went proxy everywhere
                      karsten13 @sdetweil
                      had to look in the code again … but may we should set default true for all providers …
                        sdetweil @karsten13
                        @karsten13 getting that way
                        localhost is usually allowed 0.0.0.0 ( I consider to be a bug to send this anywhere) is not
