    Calendar event same start and enddate wrong (Google Calendar)
    13 Posts 2 Posters 3.7k Views 2 Watching
      RobertM
      I have some events in my Google calendar with the same start and end date, example: 13:30 to 13:00 15.11.2022
      The calendar is configured with showEnd: true, timeFormat: “dateheaders”. This 0 minutes events are displayed from the calendar module: 13:30 - 23:59 or 13:30 - 00:59.
      Any idea?
        sdetweil @RobertM
        @RobertM yes, there is a 1 second subtraction to keep from rolling over into the next time slot… midnight is 00:00 TOMORROW, 23:59:59 is today…
          RobertM @sdetweil
          Sorry, i make a mistake: The events have the same start and end time, example: 13:30 to 13:30 15.11.2022 - so a event with 0 minutes.
            sdetweil @RobertM
            @RobertM download the ics file
            at the command prompt ctrl-alt-t
            curl -sL xxxx > somefile.ics
            xxxx is the url in the mm cal config
            find that entry in the ics file (it’s just text)
            and let me see
            BEGIN:VEVENT
            END:VEVENT
              RobertM @sdetweil
              @sdetweil here is the requested section:
              BEGIN:VEVENT
              DTSTART:20221121T123000Z
              DTSTAMP:20221120T074630Z
              UID:4anfmr8fbcgce4qsi1675tpgcq@google.com
              CREATED:20221120T074454Z
              LAST-MODIFIED:20221120T074454Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:XYZ-Robert (21.11.2022 13:30-13:30 MEZ)
              TRANSP:OPAQUE
              END:VEVENT
                sdetweil @RobertM
                @RobertM it has no DTEND or DURATION … so the module sets End to match Start
                from the spec
                https://icalendar.org/iCalendar-RFC-5545/3-6-1-event-component.html
                For cases where a “VEVENT” calendar component specifies a “DTSTART” property with a DATE value type but no “DTEND” nor “DURATION” property, the event’s duration is taken to be one day.
                For cases where a “VEVENT” calendar component specifies a “DTSTART” property with a DATE-TIME value type but no “DTEND” property, the event ends on the same calendar date and time of day specified by the “DTSTART” property.
                this second is the case for the event you provided
                  RobertM @sdetweil
                  @sdetweil Ok, that’s true for a single event.
                  If I modify the event to a series event. Then the calendar module shows a wrong end date.
                  In the ical file, the content is different.
                  BEGIN:VEVENT
                  DTSTART;TZID=Europe/Berlin:20221121T133000
                  DTEND;TZID=Europe/Berlin:20221121T133000
                  RRULE:FREQ=WEEKLY;BYDAY=MO
                  DTSTAMP:20221120T133538Z
                  DESCRIPTION:
                  LAST-MODIFIED:20221120T133406Z
                  SEQUENCE:1
                  STATUS:CONFIRMED
                  SUMMARY:XYZ-series
                  TRANSP:OPAQUE
                  END:VEVENT
                  I indented the lines to read the values better
                    sdetweil @RobertM
                    @RobertM great, thanks…
                    so, I’ve found it, I don’t know why this is there or side effects…
                    but
                    edit the ~/MagicMirror/modules/default/calendar/calendarutils.js
                    find line 430-ish ( i added debug so the numbers may be off
                    						endDate = moment(parseInt(startDate.format("x")) + duration, "x");
                    						if (startDate.format("x") === endDate.format("x")) {
                    							endDate = endDate.endOf("day");
                    add the // to the endDate = line, so it looks like this
                    							//endDate = endDate.endOf("day");
                      RobertM @sdetweil
                      @sdetweil yes, thats works - after restarting node - many thanks!
                      Would it also be possible to only show the start of such 0 minutes events?
                        sdetweil @RobertM
                        @RobertM i don’t think so… u asked to showEnd:true…
                        there is no conditional logic there
                        my settings and result
                        				showEnd:true,
                        				timeFormat:"absolute",
                        				urgency:0,
                        				getRelative:0,
