    After restart and updating raspberry MM will not starting
    11 Posts 2 Posters 3.7k Views 2 Watching
      sdetweil @aldisachen
      @aldisachen this is a duplicate. don’t double post
        aldisachen
        Hello and sorry for this misstake,
        Please delete the other duplicate post. Sorry again. Thanks.
          @aldisachen done
            @aldisachen what is the address: setting in mm config.js?
            what url do you use to access mm?
              aldisachen
              Hello all togehter, the config.js starts with:
              /* Magic Mirror Config Sample
              • MIT Licensed.
              • For more information how you can configurate this file
              • See https://github.com/MichMich/MagicMirror#configuration
              var config = {
              // - “0.0.0.0” to listen on any interface
              // Default, when address config is left out, is “localhost”
              port: 8080,
              ipWhitelist: [], // Set [] to allow all IP addresses
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
              and it will follow with the language, time format and so on and so on witch all the settings to display for the MM. Thnaks.
                @aldisachen said in After restart and updating raspberry MM will not starting:
                this is a problem…
                it means ONLY apps INSIDE the same system can connect. ie, from INSIDE the container
                you want apps OUTSIDE the container to connect, the docker host or further away.
                so you should change that to address:“0.0.0.0”,
                meaning over any network interface, without having to specify what it is.
                then you can run container in network bridge mode. it will get IP address 172. something…
                  aldisachen
                  Hello, I don´t understand what is nessssary to change in the config file. Can you please write down the right settings at the config file ?
                  I have no experience with that. Thanks.
                    @aldisachen I did,
                    address:"0.0.0.0",
                      aldisachen
                      Hello together,
                      after change the Address from “localhost” to “0.0.0.0” and restart the MM is runing without problems.
                      Now I can update and upgrade the system every day and not every month. It was not funny to do the same steps after restart and running the MM again. Thank you very much.
                        @aldisachen cool… glad u got it…
