    modules
    23 Posts 2 Posters 7.7k Views 2 Watching
      sdetweil @pat59
      @pat59
      node:internal/process/task_queues:84:21) {
      code: ‘EADDRINUSE’,
      errno: -98,
      syscall: ‘listen’,
      address: ‘0.0.0.0’,
      port: 8080
      that means something else is running using that address port combination
      usually this means starting another mm instance without stopping the prior one.
        pat59
        Hello
        I couldn’t get it to work, so I started all over again.
        now it works , i installed googlephotos and i get error message ,so it can not open google account browser to get code thanks for your help.
        pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node generate_token_v2.js
        (node:3448) UnhandledPromiseRejectionWarning: Error: The provided keyfile does not define a valid
        redirect URI. There must be at least one redirect URI defined, and this sample
        assumes it redirects to ‘http://localhost:3000/oauth2callback’. Please edit
        your keyfile, and add a ‘redirect_uris’ section. For example:
        “redirect_uris”: [
        “http://localhost:3000/oauth2callback”
        at authenticate (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/@google-cloud/local-auth/build/src/index.js:51:15)
        at generate (/home/pi/MagicMirror/modules/MMM-GooglePhotos/generate_token_v2.js:13:24)
        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GooglePhotos/generate_token_v2.js:27:1)
        at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
        at startup (internal/bootstrap/node.js:283:19)
        (node:3448) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        (node:3448) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        pi@rasp
          sdetweil @pat59
          @pat59 ok. it tells u the problem and how to work around it. did u do that?
            pat59 @sdetweil
            @sdetweil Hello and thank you for your feedback.
            no nothing do I can not understand what I have to do sorry thank you
              sdetweil @pat59
              @pat59
              “redirect_uris”: [
              the keyfile is the thing u downloaded from google
                pat59
                yes, I did download a file that I renamed credential.js and placed in the googlePhotos module of the magicmirror.
                that’s good what you’re talking about thank you
                  sdetweil @pat59
                  @pat59 did u edit the file and add the missing info?
                  if u do not understand the English text, translate it into your native language
                    pat59
                    no, I haven’t changed anything. Simply downloaded client ID and client secret code then placed in the googlephotos module.
                    I will try to find by searching and come back to you if I do not find I thank you in advance thank you my friend
                      pat59
                      I understand that it is necessary to modify the credential.js key by adding redirect_uris but I do not see where the site is.
                      {“installed”:{“client_id”:“315406544684-crlbfk6kon4bel61nkcpj59dt6s352dm.apps.googleusercontent.com”,“project_id”:“magicmirror-376414”,“auth_uri”:“https://accounts.google.com/o/oauth2 /auth”,“token_uri”:“https://oauth2.googleapis.com/token",“auth_provider_x509_cert_url”:“https://www.googleapis.com/oauth2/v1/certs”,“client_secret”:"GOCSPX -nqP06oYf_sZqPBlPJEw_hceNZhy2”}}
                        sdetweil @pat59
                        @pat59 yes, YOU have to add it along side the others
                        or go back to Google and add it there and download again
                          pat59
                          Good morning
                          ok I will look at this during the day, I would say thank you again for your patience.
                          thank you my friend
                            pat59
                            Good morning .
                            does the location of the https://localhost redirect uri have a specific place in the API key, thank you
                            Cordially
                              sdetweil @pat59
                              @pat59 not specific. but I recommend you go back to the Google console and add it there, and download the file again
                                pat59
                                Hello my friend
                                I returned to the googe console I managed to move on to the next stage, I copied the module in config.js I placed a photo in the album, it downloaded but nothing happened, it was looking for loading, what to do, thank you.
                                I did shift control. I went to console, nothing written in red20230206_101813.jpg
                                  sdetweil @pat59
                                  @pat59 you need to look at the output of npm start, or use pm2 logs --lines=nnn
                                  nnn is some number bigger than 15
                                  did u run the auth program after you fixed the credential file?
                                    pat59
                                    Good morning
                                    good here everything works thanking you for your help and your patience. Thank you again my friend
