    Error 'failed to load kms_swarst' - can I ignore is screen is loading?
    2 Posts 2 Posters 629 Views 2 Watching
    • L Offline
      lillyhb
      Hi there,
      I’m new to raspberry pi but not MagicMirror. Due to the pi shortage I had installed MM on my mac to test things out with no problems but now I have the pi i’m struggling more than I thought I would!
      I’ve tried reinstalling and running out of the box (ie no extra modules installed, no changes to any files) and I keep getting a ‘failed to open kms_swrast’ error and no solutions I’ve googled have worked. Here is the entire output after I run npm start
      > magicmirror@2.23.0 start
      [21.06.2023 17:22.46.111] [LOG]   Starting MagicMirror: v2.23.0
      [21.06.2023 17:22.46.118] [LOG]   Loading config ...
      [21.06.2023 17:22.46.124] [DEBUG] config template file not exists, no envsubst
      [21.06.2023 17:22.46.132] [LOG]   Loading module helpers ...
      [21.06.2023 17:22.46.134] [LOG]   No helper found for module: alert.
      [21.06.2023 17:22.46.168] [LOG]   Initializing new module helper ...
      [21.06.2023 17:22.46.169] [LOG]   Module helper loaded: updatenotification
      [21.06.2023 17:22.46.169] [LOG]   No helper found for module: clock.
      [21.06.2023 17:22.46.522] [LOG]   Initializing new module helper ...
      [21.06.2023 17:22.46.522] [LOG]   Module helper loaded: calendar
      [21.06.2023 17:22.46.523] [LOG]   No helper found for module: compliments.
      [21.06.2023 17:22.46.524] [LOG]   No helper found for module: weather.
      [21.06.2023 17:22.46.562] [LOG]   Initializing new module helper ...
      [21.06.2023 17:22.46.565] [LOG]   Module helper loaded: newsfeed
      [21.06.2023 17:22.46.565] [LOG]   All module helpers loaded.
      [21.06.2023 17:22.46.588] [LOG]   Starting server on port 8080 ...
      [21.06.2023 17:22.46.895] [LOG]   Server started ...
      [21.06.2023 17:22.46.896] [LOG]   Connecting socket for: updatenotification
      [21.06.2023 17:22.46.896] [LOG]   Starting module helper: updatenotification
      [21.06.2023 17:22.46.897] [LOG]   Connecting socket for: calendar
      [21.06.2023 17:22.46.897] [LOG]   Starting node helper for: calendar
      [21.06.2023 17:22.46.898] [LOG]   Connecting socket for: newsfeed
      [21.06.2023 17:22.46.898] [LOG]   Starting node helper for: newsfeed
      [21.06.2023 17:22.46.898] [LOG]   Sockets connected & modules started ...
      [21.06.2023 17:22.46.981] [LOG]   Launching application.
      MESA-LOADER: failed to retrieve device information
      MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      failed to load driver: kms_swrast
      MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      failed to load swrast driver
      [21.06.2023 17:22.50.109] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [21.06.2023 17:22.50.130] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [21.06.2023 17:22.50.166] [INFO]  Checking git for module: MagicMirror
      [21.06.2023 17:22.50.537] [INFO]  Newsfeed-Fetcher: Broadcasting 18 items.
      [21.06.2023 17:22.52.804] [INFO]  Calendar-Fetcher: Broadcasting 7 events.
      If the screen is loading, can I just ignore the error? Any help would be greatly appreciated!
      Thank-you
        sdetweil @lillyhb
        @lillyhb yes. ignore this is electron trying to use the gpu. but it’s not configured like electron expects.
        you can get rid of the error message by adding
        export ELECTRON_DISABLE_GPU
        before doing npm start
        if you use pm2, then add it to the script pm2 uses to launch mm
