    wlan0 IP address in config file
    2 Posts 2 Posters 374 Views 2 Watching
    • H Offline
      hikano765
      I want to open the server with the first IP address of the wlan0 network by putting ifaces.wlan0[0].address in the address part of the config.js file. I modified the code to do this, but I get an error on the screen.
      const os = require("os");
      const ifaces = os.networkInterfaces();
      const wlan0Address = ifaces.wlan0[0].address;
      let config = {
          address: wlan0Address, // The first IP address of the wlan0 network interface
          port: 8080,
          // etc...
      If I write the code as above, I don’t know why, but when I open the server, I don’t see any module screen on the web server. So I thought the modules were a problem, so I modified the code as follows, and the modules come out well from the web server at that address.
      /*const os = require("os");
      let config = {
          address: "xxx.xxx.xxx.xxx", // static address
          port: 8080,
          // etc...
      The conclusion that I came up with through this process is
      I think the code in the above part is problematic, I want to know exactly what the problem is with this code, and how to fix the code to solve it.
      In addition, since English is not the main language, I hope you understand that my writing may have some grammatical errors.
        sdetweil @hikano765
        @hikano765 a better thing would be to change the address: to address:“0.0.0.0”
        then it will listen on all the active network adapters .
        you will also have to fix the ipWhitelist to allow apps from outside systems to connect
        while you are developing your mm solution it’s easiest to do
        ipWhitelist:[],
        to allow apps from any system on your local betwork
