    MM2 can get POST API?
    3 Posts 3 Posters 852 Views 3 Watching
    • H Offline
      hikano765
      I am developing a module of MM.
      By the way, I want to control one of these modules by an external client, and I want to do that control method by REST API method.
      For example, if an external client sends a POST API to MM2, the corresponding message is displayed on the MM2 screen.
      I don’t know because I haven’t read the MM2 code in detail, but as far as I’ve checked, the server also automatically turns on when running MM2, so I want to process REST API communication on that server as well, but which file should I modify and put a phrase related to REST API communication in order that?
      server.js?
      server_function.js?
      Examples of API codes that I want to put in are these.
      The API code is an API that stores the message as a txt file when a message is transmitted in a POST method.
      app.post('/api/saveMessage', (req, res) => {
          const message = req.body.message;
          if (!message) {
              res.status(400).send('Message not provided.');
              return;
          fs.unlink(`appid.txt`, (err) => {
              fs.appendFile(`appid.txt`, message + '\n', (err) => {
                  if (err) {
                      console.error('Error saving message:', err);
                      res.status(500).send('Error saving message');
                  } else {
                      res.send('The message was saved successfully..');
        sdetweil @hikano765
        @hikano765 you use express lib to set up a server.
        you can look at the node_helper in my mmm-config module, as I provide an API.
        https://github.com/sdetweil/MMM-Config
        I redirect , but u can do whatever
          // add express routes to allow invoking the form
          extraRoutes: function () {
            this.expressApp.get("/modules/MMM-Config/review", (req, res) => {
              // redirect to config form
              res.redirect(
                //this.config.url +
                "/modules/" + this.name + "/config.html?port=" + socket_io_port
          MMRIZE @hikano765
          @hikano765
          use this.expressApp in node_helper.js
          Of course, you can use your own express or fastify whatever by importing that node module.
