    Modifying the Config File
    101 Posts 7 Posters 189.2k Views 7 Watching
    • BKeyportB
      BKeyport Module Developer @jimb
      @jimb that appears to be your windows computer, not the pi.
        sdetweil @jimb
        @jimb said in Modifying the Config File:
        only mistake I made was making the MM auto-install.
        u mean auto start??? install was my script
        ssh doesn’t work unless you enable it on the pi
        desktop, menu top left,
        preferences
        raspberry pi configuration
        then the itnerfaces tab, click the slide on the ssh row,
        then press ok…
        if latest os, then you don’t have to boot
        open a terminal window on pi
        type
        ip addr
        you should see like this
        pi@raspberrypi4:~ $ ip addr
        1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
            link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
            inet 127.0.0.1/8 scope host lo
               valid_lft forever preferred_lft forever
            inet6 ::1/128 scope host
        2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
            link/ether dc:a6:32:20:b0:94 brd ff:ff:ff:ff:ff:ff
            inet 192.168.2.44/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
               valid_lft 50521sec preferred_lft 36219sec
            inet6 fe80::a5a6:f1d1:50e7:1c5/64 scope link
        3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
            link/ether dc:a6:32:20:b0:95 brd ff:ff:ff:ff:ff:ff
        in this setup my wifi (wlan0) is not connected but my ethernet (eth0) is
           inet 192.168.2.44
        doesn’t matter what the PC says…
        do you have a guest network at home and did u connect the pi to that?
        can’t connect to it from home network if so… intentional firewall…
          jimb
          Sam, the Pi is connected via wireless. Yes, I meant autorun on my first post. I did change the Pi configuration to allow SSH. I have Eero mesh AP’s connected to my home network. I don’t know how to check if access is being blocked to the Pi. Since everything is fresh on the install it makes sense that the network is the culprit. The reason I went with a new install was to enable pasting config, etc. files here on the forum.
            sdetweil @jimb
            @jimb i understand… if you can use a terminal window on the pi, can you ping xxxx, where xxxx is the hostname or ip address of the windows pc?
            what is the output of ip addr ?
            i know it stinks, but you can post a pic, third icon from the right above the forum post editor
              @jimb I’d also suggest trying my MMM-Config module, which presents a form for config.js including outside modules… all done with discovery of the installed modules and there parms…
              some modules cause trouble… but there are ways around with some extra work… it may not be for you… another pile of work to learn, it it doesn’t work…
              https://github.com/sdetweil/MMM-Config
              it doesn’t help with module install, only configure
                jimb
                Sam,
                OK progress on the network front. I spent some time yesterday on the phone with eero tech support. At rhe end they suggested connecting my PC wirelessly and seeing if I could ping the rasberry. It works. I can ping and SSH/Putty into the pi, but have an additional snag. It accepts the login and sends a password request. BUT, I can’t enter anything- the keyboard is dead at that point.
                  sdetweil @jimb
                  @jimb ok, sounds like the wifi network is a guest, not connected to the regular ethernet network…
                  don’t use putty
                  open a cmd.exe window
                  ssh user_name@machine_ip
                  add one of the tools
                  winscp or bitvise ssh clients
                  they will give you a filemanager view of the files and an ssh window ,
                  per system you connect to…
                  bitvise also provides a filemanager view of the pc filesystem , so you can drag/drop files in either direction… (you would only do that for logs to pc, of special bug fix file , to pi)
                    jimb
                    Sam, success! I have d/l’d the SSH gui program and here is my config.js file. I have deleted my apiKey
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check",
                    						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "weather",
                    				apiVersion: "3.0",
                    				lat: 33.50872,
                    				lon: -96.612213,
                    				weatherEndpoint: "/onecall",
                    				type: "current",
                    				locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				apiKey: "8eca2aec"
                    			module: "weather",
                    			header: "Weather Forecast",
                    				apiVersion: "3.0",
                    				lat: 33.50872,
                    				lon: -96.612213,
                    				type: "forecast",
                    				apiKey: "8
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                      sdetweil @jimb
                      @jimb missing some at the bottom
                      I assume the apikey with a new line inside is a removal edit problem
                      always wrap config.js content in code block
                      paste into editor
                      blank line above and below
                      select pasted text
                      hit button </>
                        jimb
                        Sam, here is a copy of the config.js (with the apiKey deleted)
                        let config = {
                        	address: "localhost",	// Address to listen on, can be:
                        	port: 8080,
                        	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                        	language: "en",
                        	locale: "en-US",
                        	timeFormat: 12,
                        	units: "imperial",
                        			module: "alert",
                        			position: "top_bar"
                        			module: "clock",
                        			timezone: "America/Chicago",
                        			showPeriodUpper: "true",
                        			showDate: "true",
                        			module: "weather",
                        			units: "imperial",
                        			windUnits: "imperial",
                        			tempUnits: "imperial",
                        			appendLocationNameToHeader: "true",
                        			colored: "true",
                        				apiVersion:"3.0",
                        				weatherEndpoint:"/onecall",
                        				lat: "33.50872",
                        				lon: "-96.612213",
                        				type: "current",
                        				apiKey: "8acfbcab123ce212",
                        			module: "weather",
                        			units: "imperial",
                        			winUnits: "imperial",
                        			appendLocationNaneToHeader: "true",
                        			colored: "true",
                         				apiVersion:"3.0",
                        				lat: "33.50872",
                         				lon:"-96.612213",
                         				type: "forecast",
                        					apiKey: "8eca2acaacfbcab123ce212",
                        			module: "newsfeed",
                        				feeds: [
                        						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                        				showSourceTitle: true,
                        				showPublishDate: true,
                        				broadcastNewsFeeds: true,
                        				broadcastNewsUpdates: true
                          jimb
                          Sam, I tried to do the Ctrl-Shift_i keypress in the browser, but nothing happened. Do I need to do this at a certain point in time or from a certain place. The reason is because I’m still getting the 401-unauthorized messages if I perform the npm start dev process during application start.
                          S 3 Replies Last reply Reply Quote 0
                            sdetweil @jimb
                            @jimb weird… always works for me.
                            I meant to test w my apikeys today.
                            will get to it
                              sdetweil @jimb
                              @jimb well, I used your exact weather config, and used my openweather api key , and it worked perfectly
                                sdetweil @jimb
                                @jimb and you’ve got some stuff out of position
                                this is the more correct layout
                                                        module: "weather",
                                                       config:{
                                                           units: "imperial",
                                                           colored: "true",
                                        //              position: "top_right",
                                        //              config: {
        apiVersion:"3.0",
        lat: "29.8155405", //"33.50872",
        lon: "-96.0607878", //"-96.61",
        type: "current",
        //location: "Houston",
        //locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and fi>
        apiKey:""
                                  GNU nano 6.2                                                       config/config.js
                                                        module: "weather",
                                                        position:"top_right",
                                                        config:{
                                                            units: "imperial",
                                                          colored: "true",
                                                        //position: "top_right",
                                                        //header: "Weather Forecast",
                                                        //config: {
        apiVersion:"3.0",
        lat: "33.50872",
        lon:"-96.612213",
        type: "forecast",
        apiKey:"// "
                                  jimb
                                  Sam, that’s helpful, thanks! The items out of alignment happened when I deleted some of my apiKey. The original is perfectly straight. Since it worked with your Key, a couple of questions.
                                  1. Does your Key have 28 digits?
                                  2. Can you answer my question concerning the Ctrl-Shift-i keys to display the browser data. Can I stop the MM app and load the browser, or…
                                    JimB
                                    sdetweil @jimb
                                    @jimb my apikey has 33 characters
                                    it is the default key in openweather (I have multiple)
                                    i just brought up MM, and used my chromebook to bring up the page… and then ctrl-shift-i (letter sounds like eye) all at once, opened the dev window
                                    you can do those three keys on any webpage, its a toggle… on/off
                                    using normal chrome, you can use the 3 dot menu to get there too
                                      jimb
                                      Sam, why is it always the simple things :-)
                                      I found a simple link that allowed me to test the openweather api link:
                                      http://api.openweathermap.org/data/2.5/forecast?id=524901&appid={API Key}
                                      I saw the 2.5 and changed it to 3.0 and got a 401 error. I changed it back to 2.5 and it worked. I tried commenting out the 3.0 & /onecall items in config.js and got a “config.js not found” error when running MM. I had used (/*) in the leftmost column as a ‘ignore line’ comment. So, I deleted the 4 lines from config.js and it worked fine except for a teensy error “displaying Howe instead of Houston” in the display. I have no idea where that came from. I wonder why the fourth largest city in the US isn’t listed in the pull-down menu?
                                      Now, I’m going to see if I can add additional modules.
                                      Thanks for your very patient help!!
                                      S BKeyportB 2 Replies Last reply Reply Quote 1
                                        sdetweil @jimb
                                        @jimb awesome… making progress!!!
                                        • BKeyportB
                                          @jimb it’s always the simplest solution… ALWAYS.
                                            jimb
                                            Sam, into the weeds once again :-)
                                            I read the readme and comments on your MMM-Config module. I was stumped immediately by your comment: “clone this repo” into the config directory. I’m assuming this this is done via WinSCP remotely into the Pi, but have no clue. Some more Linux…
                                            • 4 / 6
