    News Feed doesn't update anymore after a while
    1 Posts 1 Posters 1.4k Views 2 Watching
    • Q Offline
      QArea51
      I have a problem with the news feed module. It doesn’t update anymore after approximately 24h.
      It’ll work again if I reload MagicMirror. (24h - then I need to reload mm again)
      Bad internet connection is normally not the problem because the wheater and calendar module working correctly.
      (Same problem: https://forum.magicmirror.builders/topic/944/newsfeed-only-loads-once-then-stops-udating)
      Configuration:
      module: 'newsfeed',
      position: 'bottom_bar',
        feeds:
                 title: "Het Laatste Nieuws",
                 url: "http://www.hln.be/nieuws/rss.xml"
      showSourceTitle: true,
      showPublishDate: true
      Error log:
      0|mm       | Use existing news fetcher for url: http://www.hln.be/nieuws/rss.xml
      0|mm       | Whoops! There was an uncaught exception...
      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
