    iframe not showing external content (ip camera view)
    1 Posts 1 Posters 408 Views 1 Watching
      csongor.varga 0
      I am want to use MMM-HVIEW-Snapshot to bring a IP camera picture into my MM screen.
      In the log, I can see the following
      Failed to load URL: xxxx with error: ERR_BLOCKED_BY_RESPONSE
      I have the IP whitelist set to my complete home subnet:
      address: "0.0.0.0",
      ipWhitelist: [["192.168.1.0","192.168.1.253"],"127.0.0.1", "::ffff:127.0.0.1", "::1"],
      And the URL I am trying to load is also on the same subnet:
      http://192.168.1.82/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=abcd1234&user=xxx&password=xxx
      When I open my MM page in Chrome and check the errors, I see the following:
      Refused to display 'http://192.168.1.82/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
      I assume this is because the browser is not allowing the iframe to load a content from a different IP.
      How can I fix this? Or can you recommend an alternative module that would do the same?
